What About Bars?
/ What About Bars? #1
yomax4
Elite Member
Midwest
ISEKI TA 247. Stihl Saws Gravely Zt's Polaris ATV's State Of The Art Welding Equipment
Tons of info on Chains not so much on bars and after 55 cords of Oak last year, I need a couple new 20" bars for my Stihl 039 and 44 mag. Are the Stihl bars the best? there a dozen brands on e-bay but I have no idea what quality they are. Forester, Sandvik etc. What about those Stainless Steel bars? Any input from you pro's ?
/ What About Bars? #2
I'm only familiar with Oregon & Husky. No problems. If you're cutting 55 cords a year, by several different kinds and you tell us! Good luck.
/ What About Bars? #3
IME, the price difference between a Stihl bar and a good aftermarket isn't enough to worry about, I'll go with Stihl bars anyday. By the time shipping costs are added in, it's a wash.
The cheap aftermarket bars are just that, cheap. Had a couple of Bailey's "Arborpro" bars, the sprocket tips didn't hold up well and the grooves wore rapidly.
Ed
/ What About Bars?
Thanks Ed, That's the info I was looking for..
/ What About Bars? #5
For a Stihl saw, I'd just stay with Stihl bars.
I like Total, Cannon, Sugi Hara , Husky TechLite & Oregon ProLite...
/ What About Bars? #6
Stick to OEM Stihl bars. Flip bar every second chain sharpening to maintain bar grooves and tip wear. And best to have two bars to swap out one for another, if either gets any damage. After two bars wear out get new sprocket for next bar. Clean bar grooves with a bar groove tool and make sure bar remains flat and true. Loosen chain on bar at end of day's use to prevent pressure on bearings.
And don't forget to brush your teeth too.:laughing:
/ What About Bars? #7
I would also feel comfortable with bars from the chain manufacturers like Oregon, Sanvik (Windsor) and, maybe Total, although I haven't used their stuff much.
/ What About Bars? #8
Oregon, Windsor & Total make very good bars! It's the made in china crap that should be avoided, Forester, ArborPro, etc...
/ What About Bars?
Never have released chain pressure at the end of the day to relieve bearings.. Anyone else do that? The teeth brushing has been proven to work though..
Thanks.
/ What About Bars? #10
Thanks.
I never have, but then I don't run my chains tight enough to hurt the bearings?
/ What About Bars? #11
Thanks.
It's discussed in the newer owner's manuals for the Stihl saws. One doesn't have to overtighten the chain to stress the bearings. Many people tighten up the chain when the saw is hot and the chain becomes loose after working the saw for a while. When the saw cools the chain shrinks back to unstretched preheated size and the result can be excess tension on the bearings.
/ What About Bars? #12
I suppose it's possible, but it seems that if the chain is tight enough to hurt the bearings, it would be too tight to turn on the bar. I have a Dolmar 115si that is about 15 years old and has cut lots and lots of wood. I've never had to replace either a bar or sprocket on it. Bet I've used up 30 chains.
/ What About Bars? #13
It may not be as much of an issue with the old saws, but since everything made today is out of chocolate, the newer saws are probably more prone to turning into a pretzel. I'm just reporting what the manufacturer states as SOP.:confused3:
/ What About Bars? #16
I imagine it would depend on the lenght of chain. By the end of day running a 42 inch chain ,I have tightened it up at least once. This is with the oil set on max. I can see it being being a problem. Look at how many bars you see blued up before their time. Releasing does not hurt anything. I agree that it is seldom done because when your done you are usually ready to quit.
/ What About Bars?
After a little research and discussion with a large husky dealer, I was told that it was said for years by the factories to release tension on the plastic case saws. He said there were not many cases of failures but the engineers put it in the manuals of several brands as a fail safe. He said the metal case saw did not have the same verbiage.. So, Plastic case saws could or should be released, Metal case saws, not so much..
/ What About Bars? #18
Chocolate=plastic.
Must be a Stihl thing... :D
Sorry, wrong, it's a all saw brands thing.
LOL you beat me to it..
I run a fleet of Echo & Husqvarna saws, and I've never loosened up the chain when I'm finished cutting.
Fleet? Time to read the manual.
Makes sense, tired at end of workday.
Yeah, vindicated!:D YMMV.:confused3:
/ What About Bars? #19
Makes sense. I don't have any 'plastic case' saws & probably never will!!! :cool:
/ What About Bars? #20
The highest end cars are made of carbon fiber, which is way lighter AND way stronger than steel or aluminum.
Never is a long time, and manufacturers of saws, just like everything else today will make products out of what works best for them and the market they serve. Stihl will continue to lead, and Husky and others will follow in their footprints, albeit lighter stronger ones, of many different materials.
2013 FORD E-350 11 PASSENGER VAN (A65643)
2013 FORD E-350 11...
SHOPBUILT TRI-AXLE COMBINE HI-CYCLE TRAILER (A63291)
SHOPBUILT TRI-AXLE...
2018 JOHN DEERE 844K-III AG HANDLER WHEEL LOADER (A65053)
2018 JOHN DEERE...
1999 John Deere 5410 (A64126)
1999 John Deere...
2019 Peterbilt 567 Cab and Chassis Truck, VIN # 1NPCX7TXXKD273140 (A65563)
2019 Peterbilt 567...
CASE INTERNATIONAL 3330 HI-CYCLE SPRAYER (A63291)
CASE INTERNATIONAL...
