How do you store you logging/tow chain?
/ How do you store you logging/tow chain? #101
Big plastic cat litter container. Dump the chain in, spray with WD40, and leave it until I need it again.
In error, I left a chain out and it got all rusty and that bothered me. I put it in a 5 gallon bucket, sprayed it with a 30%-70% mix of clean oil and diesel fuel, let it sit for a few days and it now looks as good as ever, is rust free and makes me feel better.
/ How do you store you logging/tow chain? #102
You can line your Tube holes in your loader with cpvc and make caps for ends. then put you chain in there.
/ How do you store you logging/tow chain? #103
Well I certainly found some good ideas in this thread and thought I would take advantage of one. I used 4" PVC pipe and put the cap on the bottom with 2 small screws. I figured it would be just a matter of time before I would drop something in there that I couldn't reach or it would fill up with dirt and debris that I would want to empty it out so I didn't want to glue the cap to the bottom. I have 3 chains stored in it, that should be enough for most cases, if not it will be a trip to the barn.
/ How do you store you logging/tow chain? #104
/ How do you store you logging/tow chain? #105
You can also just hook you chain behind something and drag it around for a few mins and all the rust will be gone . A dirt drive works the best and only takes a few mins .
Sent from my iPhone 5 using TractorByNet
/ How do you store you logging/tow chain? #106
Looks good. How did you secure the pipe to the loader frame?
/ How do you store you logging/tow chain? #107
Velcro dots! :D <jk>
I liked the orange chain so much I went searching at Lowes on-line. Item 348436 ($32.98) has the hooks:
Shop Blue Hawk 12-ft Welded Orange Chain at Lowes.com
and item 348268 ($3.34 / foot) is just the chain (looks to be a different orange)
Shop Campbell Commercial 1-ft 5/16 Welded Hi-Visibility Orange Steel Chain (By-The-Foot) at Lowes.com
/ How do you store you logging/tow chain? #108
Hang the spare "tow" chain off the safety screen and the chokers off the winch.
/ How do you store you logging/tow chain? #109
There was a bolt hole at the top and I drilled another at the bottom, had enough clearance that the loader does not hit nuts on backside. 1" bolts and nylocks worked great.
/ How do you store you logging/tow chain? #110
/ How do you store you logging/tow chain? #111
This is my Homer box.
/ How do you store you logging/tow chain? #112
Good deal;will definitely try to do the same. Thanks!
/ How do you store you logging/tow chain? #113
I have a Kubota Grand L 4330 with the LA853 loader. I seal the tubes on the bottom of the loader frame with 4" pipe plugs and store my short chains in there. But, make sure that you plug the back side of these tubes as well, or your chains can slip out. Because of the tight space there I had to disassemble the inside plugs and reassemble them in place.
I have a short chain that I use all of the time. About 2 feet long, with grab hooks on each end, and a slip hook on a clevis. This fits securely in the tube on the left side, right where I need it as I climb off the tractor.
On my tractor there is a long tube brace between the loader arms but it is of a slightly larger diameter. You can sleeve this with 4 inch PVC and use standard pipe plugs there too.
I also fabricated a mount for an ammo can, fits perfectly for the location to the right of the floorboard. I never climb on the right side anyway because of the loader joystick so it was dead space. Haven't painted my mount yet because i am still brainstorming what else to add to it. I designed it to attach to the loader frame using holes that were already there.
Frame Rear View.JPG Front View.JPG 20140408_001101.jpg 20140408_001131.jpg 20140408_001146.jpg
/ How do you store you logging/tow chain? #114
don't the chains knock around and drive you crazy in those pvc holders? no, the tractor doesn't ride like the Buick, but to avoid a lot of clanging, i'll just drive to the shed to get the chain when needed. I don't run far distances nor have lots of call for impromptu chaining anything usually. neat ideas, but wary of the clanging!
/ How do you store you logging/tow chain? #115
Chains in PVC holders don't clang. They never move.
/ How do you store you logging/tow chain? #116
Sometimes I wrap the chain around the 3 pt. lift arms
/ How do you store you logging/tow chain? #117
The other day I tie-wired some antifreeze jugs to the box blade... has worked out ok so far. Easier than wrapping chains around stuff and hopin they stay put. Short term fix... quick and free!
/ How do you store you logging/tow chain? #118
I leave my chains hooked the hooks on the bucket hooks and it works for me. There are times when I have used plastic jugs and I find the orange colored laundry detergent containers from Tide to be the most rugged.
/ How do you store you logging/tow chain? #119
Re: How do you store you logging/tow chain and tow strap?
In a old ammo box bolted to the tail light bracket.
And a choker chain in the boom safety support.
/ How do you store you logging/tow chain? #120
Hi there Xfaxman,
In you last picture, is that a home made/improved version of a chain hook safety clip, or is that something you bought somewehere?
?..and what is the deal with that big ring, just to grab it outen the holder, or some other special purpose?
Thanks,
Thomas
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2002 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A61567)
2002 Bobcat 863...
2012 Great Dane 53ft. T/A Reefer Trailer (A61568)
2012 Great Dane...
2007 MACK CTP (GRANITE) WINCH TRUCK (A60736)
2007 MACK CTP...
2019 PJ TRAILER 32FT GOOSENECK (A58214)
2019 PJ TRAILER...
