Finally got my chain hooks on.
/ Finally got my chain hooks on. #1
Sysop
Elite Member
Fairmont, WV
Mahindra 4035HST purchased 2013 - Husqvarna TS348-D purchased 2019 - Craftsman 42" HST purchased 2003
Got three chain hooks last year but haven't had the tractor and a good welder within range of each other to do anything with them till now. Finally got them on yesterday. Thought I'd share!
Two for the front.
One for the rear.
/ Finally got my chain hooks on. #2
Looks like some great welds! nice work
/ Finally got my chain hooks on. #3
Do you have any pictures of the entire machine?
I liked the way those weld on hooks were made. They had a nice bevel on the edge making lots of room for multiple passes of nice thick bead. I think they're on there for life. :)
Pics of the entire machine? I have a few in other threads. Here's a couple from last year.
/ Finally got my chain hooks on. #5
By far I have definitely been concidering a Mahindra after the purchase of my new home. It will be for snow plowing, mowing/ brush hogging, and a machine that can gaurentee to get most jobs done. I would never spend 5 to $6,000 on a pickup truck plow and not be able to use it for just snow plowing. All our tractors are in Michigan at my dads house
Good looking machine.
/ Finally got my chain hooks on. #6
View attachment 367893 View attachment 367894 View attachment 367895
The welds are good! It's the metal next to them that will let down ;-)
Nice.......!
ps, I've become aware that to have a hook or two "face backwards" would sure come in handy. That would hold chain coming off the back of the loader bucket and so bring the load in a bit closer. Greater lift that way. I'll pick up some more weld ons....one of these days.
I've been pleased with my machine so far. I do have the issue where it stutters a bit after the advance kicks off at 20 minutes, I've not made an appointment to have the advance adjusted yet. Other than that and a weird hydraulic leak they took care of the first week, it has been flawless at everything I've needed to do.
I figured the chain in the hooks as they are, routed over the buckets, with the buckets as they are in the above images would give me the best max height. The top edge of the front bucket rolled forward (dump position) isn't quite as high as the front edge is with it rolled back, not to mention the fact if you start with the bucket rolled forward to dump, chain to what you want to grab, you can lift and roll back letting the chain wrap around the bucket and get over an extra foot of lift over what the loader itself reaches.
I agree chaining off the back of the bucket could hold a load in closer allowing for heavier lifts, but most times I want things out far enough they'll not hit the tractor. If I did one backwards, I'd be doing so to get the maximum weight lifting capabilities of the tractor. As was mentioned, the metal around the welds would be what would likely fail if anything, so trying to get the maximum weight the tractor can lift out of the tiny area the hooks connect to wasn't my goal. The steel on the top edge of that loader bucket is pretty darned thick, especially compared to some others I've seen, but I don't see me going after anything more than 1000# off any of those hooks. The hoe bucket I don't think will ever fail around the welds, it is a good 3/8" thick plate the hook is welded to. If I was to add one for maximum weight I would probably weld a hefty full-width flat bar inside the top of the bucket and center the "backwards" hook. Even fully ballasted with rimguard and backhoe I've lifted the rear end with the front loader on heavy lifts.
/ Finally got my chain hooks on. #8
Looks nice.
I had 3 hooks welded on the top of my bucket; a slip hook in the center and grab hooks directly in front of each FEL arm.
/ Finally got my chain hooks on. #9
What's the center grab hook for , light loads?
Haven't been able to locate someone with a large enough trailer to haul my tractor back to the farm after doing some work with it at another place, so I decided to test my new hooks on the largest item to date; my backhoe... Removing the backhoe and putting it on another smaller trailer to travel separately, I just chained the subframe to my two hooks, gave it a curl, and up it came. I should have put more air in the front tires while doing it and I'd not want to do it often with no rear ballast, but it got it done none the less. I was sure it would make for a comical picture, so I had to jump off and snap one before shoving it on the trailer.
/ Finally got my chain hooks on. #11
Great pic. Looks like a successful project
/ Finally got my chain hooks on. #12
Creativity at it's finest!
/ Finally got my chain hooks on. #13
Couple more braces, and maybe finding someone brave enough to sit in the hoe seat, and you'll be able to dig stubborn bird nests out of trees :D
/ Finally got my chain hooks on. #14
Until I read the post, I thought it might be a new method of attachment - ha,ha.
/ Finally got my chain hooks on. #15
For these reasons I put the hooks on my attachments as well. Not every attachment, but certainly the bucket. I also like to weld on a D ring so I have some additional attachment options.
2015 Isuzu NPR-HD Box Truck, VIN # 54DC4W1B3FS807576 (A65563)
2015 Isuzu NPR-HD...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
Iranch IRMT Mobile Restroom (A64127)
Iranch IRMT Mobile...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
2008 Chevrolet Silverado Pickup Truck (A62613)
2008 Chevrolet...
2006 Peterbilt 379 T/A Sleeper Cab Truck Tractor (A64194)
2006 Peterbilt 379...
