Ratchet Rake - ever seen/used one?
/ Ratchet Rake - ever seen/used one? #381
Might be worth sending them a note about it....you never know till you ask, they might take care of you on it.
It would also not be a difficult repair with a grinder and welder. Any local shop could do it in twenty minutes.
/ Ratchet Rake - ever seen/used one? #384
Ratchet rakes are located in Carlisle Pa.
Ratchet Rake LLC
Warehouse
405 N East St, Carlisle, PA 17013
(888) 850-6070
/ Ratchet Rake - ever seen/used one? #385
Just placed an order for the 72" version. Should get it sometime next week. I'm planning on using it along with my Befco grader scraper to keep my forest roads clean. We've had a lot of rain this year and the weeds grew too fast for me to keep up with just the scraper, so I used that as an excuse to get the RR.:D
/ Ratchet Rake - ever seen/used one? #386
Guarantee you'll never be dissatisfied with your purchase of the RR. You'll be shocked and amazed at how you made it without it. Mine stays on my bucket and I remove it in 2 minutes or less by myself when I need it off and reinstall it in 2 minutes or less by myself when I want it back on, which is most of the time.
/ Ratchet Rake - ever seen/used one? #387
:cool: I had a few hours to kill so I slapped on my RR to clear up some saplings and weeds. I took some before and after photo's but still have to go over it again in the morning before the storm comes. Sometime either Tuesday or Wednesday the ground should be dry enough to put on my Piranha so I can level the ground.
/ Ratchet Rake - ever seen/used one? #388
View attachment 384334View attachment 384335View attachment 384337View attachment 384338View attachment 384339
so it doesn't do well with leveling the ground?
how about gravel?
/ Ratchet Rake - ever seen/used one? #389
The lower teeth on my 68" RR protrude two inches. If you are content leveling in < two inch increments, it will level.
Backdragging with your FEL bucket, without the RR attached, will probably level more satisfactorily, depending……..
Leveling with a Rear Blade, Box Blade or Land Plane will be more satisfactory than the bucket.
RR works better grading gravel because it is a RAKE, sort of, and gravel is more amenable to movement than hard road dirt.
/ Ratchet Rake - ever seen/used one? #390
how about gravel?
I was surprised by his post. I don't have a piranha and need to see what it is, but I use my RR to level dirt and gravel.
/ Ratchet Rake - ever seen/used one? #391
The reason why I am changing over is because I am filling in huge ruts left over from logging trucks. Yes I use my rake all the time to level dirt and gravel but not for digging.
/ Ratchet Rake - ever seen/used one? #392
I bought mine to maintain over 700 ft. of gravel driveway , and all I can say is I wished I had bought it years ago . We just had an addition put on the house so I used it to level up the yard around where they backfilled and worked great for that also .
/ Ratchet Rake - ever seen/used one? #393
Oh, ok. Thanks for clarifying. I agreee. I dont dig either with the RR. I didnt get that you were digging.
/ Ratchet Rake - ever seen/used one? #394
I've been using the two different RRs (2 different sizes) for years to level out my dirt and some small patches of gravel.
I some times go forward into a high spot of clay dirt with lower teeth, fel locked and knock the top off and then back drag on float or locked with lower teeth to final level. Locked can peel a bit more off if needed and float will level to finished grade better.
I some times change angle of lower teeth, fel locked and back drag to cut more down and some times stop and dig with front or/and lower teeth by just angling the teeth and working the bottom of the bucket back and forth with FEL lever and tractor not moving.
I use the lower teeth most of the time but the front teeth can be used for various purposes, not just weed/brush removal. The RR is strong and is mostly limited by weight of tractor and strength of fel. Sure the Pirinha has the same limitations and is very strong.
/ Ratchet Rake - ever seen/used one? #395
OK thanks for a great update on how to level using the RR
now off to buy one
/ Ratchet Rake - ever seen/used one? #396
now off to buy one
They are great to level....and the little groves left by the teeth are perfect to re-seed they grass with...perfect depth.
/ Ratchet Rake - ever seen/used one? #397
I use mine to clean the roadside ditches of twigs and wet leaves, saving me lots of backbreaking hours of hand raking.
/ Ratchet Rake - ever seen/used one? #398
Mine will be here on my birthday next week! (thanks to this thread) I have a LOT of redwood duff to rake up, and a 300' driveway to re-gravel by winter too. I think it will be a nice match to the PTB.
/ Ratchet Rake - ever seen/used one? #399
After you get it you are going to thing how did I do this before.
2019 CATERPILLAR 259D3 SKID STEER (A62129)
2019 CATERPILLAR...
2015 CHEVROLET SILVERADO (A60736)
2015 CHEVROLET...
2016 Ram 4500 Wrecker/Snatch Truck, VIN # 3C7WRKAL4GG243467 (A61165)
2016 Ram 4500...
2012 DOOSAN G25 GENERATOR (A58214)
2012 DOOSAN G25...
TAYLOR POWER SYSTEMS SKIDDED GENERATOR (A60736)
TAYLOR POWER...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
