Ratchet Rake - ever seen/used one?
/ Ratchet Rake - ever seen/used one? #381
Might be worth sending them a note about it....you never know till you ask, they might take care of you on it.
It would also not be a difficult repair with a grinder and welder. Any local shop could do it in twenty minutes.
/ Ratchet Rake - ever seen/used one? #384
Ratchet rakes are located in Carlisle Pa.
Ratchet Rake LLC
Warehouse
405 N East St, Carlisle, PA 17013
(888) 850-6070
/ Ratchet Rake - ever seen/used one? #385
Just placed an order for the 72" version. Should get it sometime next week. I'm planning on using it along with my Befco grader scraper to keep my forest roads clean. We've had a lot of rain this year and the weeds grew too fast for me to keep up with just the scraper, so I used that as an excuse to get the RR.:D
/ Ratchet Rake - ever seen/used one? #386
Guarantee you'll never be dissatisfied with your purchase of the RR. You'll be shocked and amazed at how you made it without it. Mine stays on my bucket and I remove it in 2 minutes or less by myself when I need it off and reinstall it in 2 minutes or less by myself when I want it back on, which is most of the time.
/ Ratchet Rake - ever seen/used one? #387
:cool: I had a few hours to kill so I slapped on my RR to clear up some saplings and weeds. I took some before and after photo's but still have to go over it again in the morning before the storm comes. Sometime either Tuesday or Wednesday the ground should be dry enough to put on my Piranha so I can level the ground.
/ Ratchet Rake - ever seen/used one? #388
View attachment 384334View attachment 384335View attachment 384337View attachment 384338View attachment 384339
so it doesn't do well with leveling the ground?
how about gravel?
/ Ratchet Rake - ever seen/used one? #389
The lower teeth on my 68" RR protrude two inches. If you are content leveling in < two inch increments, it will level.
Backdragging with your FEL bucket, without the RR attached, will probably level more satisfactorily, depending……..
Leveling with a Rear Blade, Box Blade or Land Plane will be more satisfactory than the bucket.
RR works better grading gravel because it is a RAKE, sort of, and gravel is more amenable to movement than hard road dirt.
/ Ratchet Rake - ever seen/used one? #390
how about gravel?
I was surprised by his post. I don't have a piranha and need to see what it is, but I use my RR to level dirt and gravel.
10' Container w/ Side Door (Damaged) (A60463)
10' Container w/...
2004 GMC Sierra 3500 Pickup Truck (A55973)
2004 GMC Sierra...
2010 Specialized Structure 1456 (A56858)
2010 Specialized...
2014 Freightliner M2 106 T/A Terex Commander C6060 60ft Digger Derrick Truck (A60352)
2014 Freightliner...
Wacker Neuson PT2 Water Pump (A59228)
Wacker Neuson PT2...
2014 Bolens 11A-020W765 20in Push Mower (A60352)
2014 Bolens...
