Think I can unload my EA box blade? BX25 + BXpanded Forks
   / Think I can unload my EA box blade? BX25 + BXpanded Forks #1
Biff09
MI
Kubota BX25D
Hi all,
I'm about to order the 48" EA box blade and thinking about the residential delivery option ($80). They require I be around during a time window and able to unload the blade.
I've got a BX25D with the BXpanded forks. The loader is good to 550-ish lbs at the bucket (and only under certain conditions). I haven't really had an opportunity to test how much this thing can really handle with dealing with pallets out farther from the bucket and looking for folks to weigh in.
The box blade is 310lbs + 50lbs for pallet and packing materials (called EA and this was their number) == 360lbs
What do y'all think?? I'd hate to be staring at the box blade on the truck and not be able to get it down.
Thanks in advance.
   / Think I can unload my EA box blade? BX25 + BXpanded Forks #2
As long as you have the hoe on the back, I think you will be fine. You could always grab a nice log with the thumb and put the weight of it further out to gain front lift.
Thanks Ryan. I was definitely brainstorming about something heavy I could grab with the backhoe, I'll keep thinking on it.
Anyone else?
   / Think I can unload my EA box blade? BX25 + BXpanded Forks #4
Anyone else?
I believe you will be fine with just the backhoe on the back.
   / Think I can unload my EA box blade? BX25 + BXpanded Forks #5
When my tractor was delivered, they took the box blade off, lifting it with chains and backhoe. But that was off regular pickup truck hieght.
   / Think I can unload my EA box blade? BX25 + BXpanded Forks #6
It probably depends on how is banded to the pallet as long as you can pick it up your full height to pin is only 71" a standard semi bed is 60" I have feeling you probably be able to lift it but your might be up near the upper limit of what you can lift assuming the center of mass probably going to be > 20" from your lower pins if it comes on a standard 48" sized pallet. if its narrow you might not have any problems assuming you don't have to pull it out lengthwise like the photo below. That would put the center or mass out 360 lb 24" out plus the distance of the pin to the the loader forks.
can you get liftgate delivery? that would solve your problem
Tractor data suggest you can lift
Lift to full height (at pin): 745 lbs [337 kg]
Lift to full height (at 500mm): 518 lbs [234 kg]
   / Think I can unload my EA box blade? BX25 + BXpanded Forks #7
I am in an agricultural county, 35 miles from Gainesville, Florida, not a big city. There are about six truckers that make local deliveries here, from freight depots in Ocala, Florida 65 miles distant. I have never had a truck arrive with an implement without a delivery lift on the trailer, so while I do pay for residential delivery, I do not pay extra for trailer-lift delivery. That is my experience. Your situation may be different.
CONSIDER SAFETY FIRST. If you do not have a good number of hours on the BX25 do not try a relatively high pallet/implement pickup, it can not only be intimidating and frightening, it can be highly dangerous. You must add the weight of your forks as part of the load. At the height of a trailer bed I would guess you are very close to max. Is the ground level, smooth and hard where you will have to position the tractor? You do not want to make a high lift from dirt or gravel.
If you are in doubt, pay the $80. After the load is off the lift you can experiment at leisure and you will know your capability when your next implement arrives.
I always tip the drivers $10 'for lunch' when the truck arrives. They never forget this unusual practice and are extra helpful. Have a rope handy, so the driver can help steady the implement from within the trailer, safely. (Load can't fall UP.)
I am sweating with anxiety for you as I write this.
PS: The freight depot knows where the truck is at all times. If you call the depot, and their customer service is good, they should be able to estimate delivery time accurately.
   / Think I can unload my EA box blade? BX25 + BXpanded Forks #8
When you pay the extra $80 for home delivery it is with a truck that has a lift-gate. You will receive it on the ground and not have to get it off the truck. I tried to lift a 550lb chipper out of the back of my pick-up last week and the rear wheels started to come off the ground, but I didn't have the hoe on there. You will be fine.
All -- thanks very much for your feedback so far! It seems like I am working at the edge of the envelope as far as this situation is concerned.
Per the EA website, it's $80 for residential delivery without a liftgate and $216 for residential delivery + liftgate service.
Link to EA website: EverythingAttachments.com has a huge free shipping zone!!
So I set about trying to figure out if I could save some $$.
I may try and figure out how to get 360lbs on a pallet and "test" a bit.
Other option, of course, is to drive to their depot and get them to stick it in my trailer. But it's a bit of a drive.
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A56438)
2022 Schulte...
2021 Billy Goat F902H Walk-Behind Debris Blower (A59228)
2021 Billy Goat...
1998 MACK DUMP TRUCK (A60430)
1998 MACK DUMP...
Case 950 8 Row Air Planter (A56438)
Case 950 8 Row Air...
CAT 930M (A58214)
CAT 930M (A58214)
154 (A52708)
154 (A52708)
