Eco Boost vs V8
/ Eco Boost vs V8 #221
When I got a GPS, I found that there was a 3 MPH difference between the speedometer and the GPS on my 2007 Jeep Liberty. Then I noticed the same thing on 2 rental cars, and on my '96 Silverado. I thought maybe it was the GPS, but then I ran through one of those speed checker/warning things, where they have a radar gun setup with a sign that says "Speed limit XX Your Speed YY". Matched the GPS exactly. Since then,and as late as today, I have been through a few more of them, and the speed always agrees with the GPS. Makes me wonder if there is some kind of deliberate error built in to the speedometers to fudge the mileage ratings, or maybe by secret government mandate to slow people down a couple MPH. Same error on 4 different vehicles seems a little to much of a coincidence. IF the GPS is accurate, all those vehicles read 3 MPH slow.
Speedometer will lose accuracy as tires wear. I have checked every vehicle I have owned for the last 20 years. None were more than 3 mph off at 70 mph at any given time.
Chris
/ Eco Boost vs V8 #222
According to the GPS and the portable radar trailer units, both our '08 Suburban and '99 Silverado Speedo and Odometer are dead on accurate. Our 2000 Honda Accord on the other hand is wrong. The odometer adds a mile to the odometer at roughly 9 tenths of a mile - which corresponds to the speedometer. At 30 MPH it is off by about 2 MPH - I.E. I'm actually only going 28 MPH. When it says 65 MPH I'm actually doing about 59 - 60. Honda was sued a few years ago over this. They said it was a deliberate attempt to limit warranties because people were accumulating miles quicker than they actually were. I blew it off at the time (I didn't have a Honda), but it kinda looks like they didn't change. Our '97 Accord had about the same error rate.
/ Eco Boost vs V8 #223
It is not uncommon for Japanese cars to be off so they will look more fuel efficient.
/ Eco Boost vs V8 #224
I think you mean Hyundai ... not Honda.
I've owned several Toyotas & Honda's, among many Ford's. I've found them all to be accurate (within a reasonable range).
/ Eco Boost vs V8 #227
Both my vehicles have had new tires installed since I have owned them, (2 sets on the Jeep). No change in the difference between GPS and speedo. Tire wear is not the issue. GPS agrees with the radar units, speedo is 3 MPH slow. And 2 rental cars showed the same error, although I didn't have the opportunity to compare to a radar unit.
/ Eco Boost vs V8 #228
Vw's are notoriously off by 10kmh or so. Our explorer was off by 12Kmh, but the odometer was bang on....
How can that be?? If the speedo says 100kmh and you are really only doing 90kmh then it should be reflected in total distance travelled over an hour; No?
So odometer says you travelled 100km in 1 hour when the speedo/gps says otherwise. Did you compare gps travelled distance against the odometer?
Sent from my iPhone 5s 64Gb using TractorByNet
/ Eco Boost vs V8 #229
In older cars, the odometer was gear driven off the speedo cable. For the speedo, the cable would spin a metal cup that surrounded a magnet attached to the speedo needle. The faster the cup spins, the further the magnet gets pulled against the spring and the speedo needle goes up. A small adjustment to the spring could adjust the accuracy on those units. So, yes, on those units, the odometer could be accurate and the speedo could be way off.
/ Eco Boost vs V8 #230
Check speed with GPS, check distance with mile markers. and you're right, it doesn't make sense. When we first got our explorer we were amazed at the lack of speed sensation.... and then we checked it with the GPS.
/ Eco Boost vs V8 #231
/ Eco Boost vs V8 #232
The gps is highly accurate (usually within 15 meters) when checking travel distance. No need for mile markers as the gps will do it all.
/ Eco Boost vs V8 #233
No need for mile markers. The gps is highly accurate and will do it all
Edit; **** double posts
2009 BOBCAT T190 SKID STEER (A65053)
2009 BOBCAT T190...
HARDEE LR40142 DITCH BANK MOWER (A64278)
HARDEE LR40142...
2007 International CE200 School Bus (A64194)
2007 International...
2022 EZ-GO ELITE...
2022 Timpte T/A Super Hopper Grain Trailer (A64194)
2022 Timpte T/A...
Lot of 2 ForeRunner 12-16.5N.H.S. Skid Steer Wheels and Tires (A64553)
Lot of 2...
