Gooseneck or stick with bumper pull ?
/ Gooseneck or stick with bumper pull ? #21
I agree that it isnt about the trailer type. Or about any one thing in particular. But it is about the WHOLE package. Truck, Trailer, Hitch, Load, AND MOST IMPORTANT...Driver.
If any one of those things dont match the rest, it is a recipe for disaster. Weather it is GN, bumper, 5th, or 18-wheeler.
I honestly think that BP trailers get a bad rap is because of poor decisions and poor drivers. It is VERY common for a vehicle to come from the factory with a hitch. And average joe schmoe can put an insert it and pull a trailer. But that dont mean he knows what he is doing.
When it comes to GN's, a much higher percentage of people know what they are doing IMO. Because they are far less common, and usually more expensive. And GN trailers and hitches are usually rated higher than the average reese hitch and BP trailer. Therefore more difficult for the average joe to overload.
So dont fault the trailer type. Fault the person behind the wheel making stupid decisions. And pulling a 14k BP trailer with a 6500lb tractor on it is far from what I would call a stupid decision.:2cents:
/ Gooseneck or stick with bumper pull ? #22
They both got there place. I purchased a used 14 k 20+5 this week for hauling pine shaving for the girls FFA chapter, 4-H, and our personal use which will be for haying, and other needs for our small cow/calf and pig operation. There are times you need both. I also can haul my tractor and crew ranger at the same time. Couldn't find a bumper pull long enough. I hate double tripping! LUTT
/ Gooseneck or stick with bumper pull ? #23
A lot of the weight on the gn goes to your truck's rear axle. Make sure that it can handle it.
That said, pulling a gn is a pleasure compared to a bp trailer. I have a 14K gn and fully loaded, I hardly even know it is back there.
/ Gooseneck or stick with bumper pull ? #24
IMO, as with most decisions, the OP has to define what his requirements are. There is no, universal, best solution.
/ Gooseneck or stick with bumper pull ? #25
Have plenty of truck . And know its dangerous deal on a bumper pull most likely on a receiver hitch . On one little pin . A bumper pull is no where as stable as a gooseneck load . Really dangerous with that kind of weight .
Hope you stay away from me on the road .
Think I have plenty of truck and trailer if need be .
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=365011"/>
Sent from my iPhone 5 using TractorByNet
Guess it all comes down to comfort level. We pull 25,000# of the bumpers.
As for a 5/8" hitch pin. The sheer point is north of 50,000#.
Chris
/ Gooseneck or stick with bumper pull ? #26
If I am hauling anything heavy I will use a gooseneck that I have access to. Anything under 12000lbs gets hauled with my standard trailers. My gooseneck got sold 2 years ago from lack of use. I hate to say bumper pull because "some" will friek out about that. There are hitches rated in excess of 18,000lbs for pickups so obviously it can be done. Like a previous poster said the FIRST thing to safe towing is the driver. If the driver is not comfortable with towing at the max rating of the equipment then I agree 100% I don't want that driver anywhere near me on the highway. So please if you don't know how to correctly haul something and don't want to learn leave it to the experienced ones who do. CJ
/ Gooseneck or stick with bumper pull ? #27
Interesting discussion
I agree - someone slammed me here because I used the term "bumper pull" referring to my Ford installed factory hitch rated for 12,000 lbs. w/WD.
But one thing going for the non-gooseneck is I've never seen a tailgate damaged when someone started to drive off without raising the gooseneck high enough. I've seen trailer tongues drop on the ground but tailgates don't get damaged :)
Which why I have an F250 badge on my duallie.
/ Gooseneck or stick with bumper pull ? #28
Chris
I have one of them pins that is bent from pulling under 8000#'s .
And I even have a receiver hitch that I broke with a little light swing of a short handled 8# hammer . The shock load of a 14,000# load would easily do the same .
But it's where the load is placed on the truck that makes it dangerous with 14,000# plus loads .
It's saver to have the load over the axle than 4-5 feet behind it .
/ Gooseneck or stick with bumper pull ? #29
I agree.
If things go really bad, which would the puller have better control of.
/ Gooseneck or stick with bumper pull ? #30
I am with Chris on this one, but remember we both have 3500 trucks. Get the bumper pull and save you bed space for other things.
/ Gooseneck or stick with bumper pull ? #31
OP already has a bumper pull he is or was debating buying a gooseneck for more room . And you can still haul stuff in ya bed with a gooseneck .
/ Gooseneck or stick with bumper pull ? #32
I have pulled well over 100,000 miles trailers 10,000# and above. Almost all BP except maybe 3,000 miles with my GN. I have never once bent, deformed, or destroy a pin, ball, or bar. I did cracked the weld on my 2004 Super Duty's hitch but that was purely my own fault towing nearly 3 times what it was rated for and 1800# of tongue weight.
That must have been a cheap pin and bar!
Chris
/ Gooseneck or stick with bumper pull ? #33
Hard for me to give advice since I have 15 trailers . But I like goosenecks better than bumper pulls .
if I never pull another BP again I'd be happy. I MUCH prefer GN to BP
/ Gooseneck or stick with bumper pull ? #34
Can't put a box blade, plow, ect in with a GN. Look I had a 25' GN with tandem 12,000# axles. It's gvwr was 25,000# and weighed 6,500# empty. I found I had less room with its fold up ramps and dove tail than I did with my 20' 14,000# BP with slide in ramps. Then the bed space added to that was just a bonus.
Don't get me wrong, my GN had its place. But for loads under 11,000# it did not. The 14 bumper pull weighed half what the GN did, was easier to load, easier to manage, and handled 99% of my needs better due to the usable space being better. I have never felt once uncomfortable pulling it with my two 1 tons or two 3/4 tons I have owned.
Chris
/ Gooseneck or stick with bumper pull ? #35
Chris
What kind of hitch do you use for that much weight?
That seems kinda heavy for a pick up?
/ Gooseneck or stick with bumper pull ? #36
Chris
Well you have been lucky is all . The pin and bar was standard products anyone could buy .
And u just stated that its dangerous to pull bp trailers with them weights because your over loading the tongue weight . So over weighting the tongue weight makes it dangerous . Sorry you don't see your dangerous even though you stated ya was .
O and you need to get and pull more . Your way behind my pull'n miles . Lol
/ Gooseneck or stick with bumper pull ? #37
Chris
You could have easily stood your ramps up strait and had more room . Sorry you didn't know that you could do that . Or could easy use a slide in ramp with a dove . Then you could use the whole length of the trailer .
So the OP has a 18" bumper pull and is thinking 25 dove that he could easily use the whole length like I just stated . So I see 7' of useable room difference . He was looking for more room not weight carrying .
Your the one that has a weight problem . Lol
/ Gooseneck or stick with bumper pull ? #38
I call bs on breaking that hitch with one light swing from that hammer unless it was already fractured or damaged.
And I have done some serious pulling Jerking and yanking on seemingly immovable objects with my 8000# truck and a cheap 5000# rated tsc insert and never even slightly bent a pin. So unless you were using a homemade pin out of plain mild steel, I call bs on that one too since this seems to be turning into a pi$$ing match...
/ Gooseneck or stick with bumper pull ? #39
Nope I was a pretty light swing with the hammer pictured I was stunned it broke and it wasn't fractured or damaged i looked for that at the break . It was stuck in a hitch from rust so I thought I would tap it out and that's what happened . Heck I was going to use it glad it broke tapping it out and not hooked to a trailer .
As for as the pin it is a factory standard pin . I still have it somewhere .
And pissing match not really . Just means that there's dangerous people out there pulling dangerous heavy loads .
/ Gooseneck or stick with bumper pull ? #40
Think its worth the difference to go to the gooseneck ? Id gain more deck space, but loose some hauling capacity (12k vs my 14k)...
Call eTrailer.com and ask them what they recommend. Faster solution, without insults if you opt for a bp. It will also save posters in this thread the time they'd waste looking for pictures or videos of breaking a GN hitch with a tack hammer. :D
