Buying Advice Bobcat CT 225
/ Bobcat CT 225 #1
MoPops
Center, Mo (small town, it exists)
Bobcat CT225, John Deere X540
I found a CT 225, new, loader, ez hookups, hst, either R4 industrial tires, or narrower "crop" type tires.. @$14,000.
I've been reading, looking, at various sites, for what seems an eternity.
Haven't bought it yet, but close.
First post, I can take blunt recommendations.. I've got 44 acres, just 10 tillable, the rest is timbered.
I need to do a lot of cutting and moving wood, building brush piles, feathering the field edges. Hauling junk away, old stoves, water heaters, etc.. I need to spread some gravel also, and maintain a gravel road. (300 yards)
Also, I'd maybe,, like to put in alfalfa in the 10 acres.. I'd leave the cutting and bailing to someone else.
Possibly I'd need to turn over the field? It's in no til beans right now..
Ok, what of the above, could the CT 225 handle?
Which tires should I go with?
What (besides the loader that it comes with) attachments/implements, would I need?
Is $14,000 too much for the CT 225?
I know, it's a lot of questions, especially for a first post, but hey, it's going to be spring soon, I need to make some decisions..
Thanks,
Jeff
/ Bobcat CT 225 #2
I own a ct225. It has been pretty solid.It is very comfortable and seems well made. It has good weight but just so-so power. I think it will do most of the jobs that you need,but tilling 10 acres will be a stretch. I have r4 tires and they are fine. They look better and are tougher. They are also good for loader work. R1 or crop tires will be fine as well. They give better traction in wet conditions. The price might be a bit high since Bobcat is out of the business and this tractor is a bit of an orphan.Retail was about 17 thousand, but a lot ere purchased with a free loader program,so that makes pricing vary. Mccormick and Kioti offer the same machines and Bobcat is still supporting the machines they sold, for now. I think You need a trailer or wagon for hauling and a box blade for the driveway. I think a plow and harrow for tilling and field prep. A tooth bar is very very helpful as is a set of forks that fit on the bucket.I would also think you would need a rotary cutter(Bushog) I think you can check the used market and find all this for about $3500.00 but it will take take some time. You may have to buy the forks and tooth bar new. If you have the extra cash, I would buy a new trailer instead of a used one.
/ Bobcat CT 225 #3
The Bobcat ct225 is a solid tractor. I'm convinced that Bobcat will support them for a considerable time.
I think the price is "on the money". As a reference, around here Bobcat ct230 models were selling out last fall at $15,500. There are none left at the dealers in my area.
/ Bobcat CT 225 #4
44 acres..I would want more machine personally, I would look at a DK 40/45/50series Kioti or equivalent machine at a minimum, get it plumbed up front for a grapple, for moving brush, trees, junk, etc.
Any tractor will save you alot of work... It is cheaper to buy a big enough machine the first time.
/ Bobcat CT 225
I was thinking this would be a comment, but budget constraints prevent me from looking at a new one this big. I've been looking for used, but haven't seen anything close. I'm just looking at 10 acres tilled.. I see what you are saying, but that's just too much $$ right now. Maybe if the government would buy it for me..
Just kidding
/ Bobcat CT 225
Thanks for all the info.. The guy I'm talking to said he bought 40 of the CT225s and is down to three. I don't think he'll take any more off. Nothing else new is in that price range. I called the local bobcat dealer and spoke with the service mgr. He is comfortable supporting it thru the warranty etc, and thinks bobcat will provide parts for a fairly long time.
/ Bobcat CT 225
Good to hear. There's no doubt I could always use bigger, and more hp, but this is my first tractor, if I screw it up (without getting hurt) I won't be out huge $$$
/ Bobcat CT 225 #8
Just kidding
Maybe if the government would buy it for me..Just kidding
You know, with out getting on a rant...the folks that live off the government probably know a way to do it:mur:
I here you, we have to make do with what we can afford at the time.
Do you need to load over the side of a truck? The smaller tractors are limited with the height of the loader.
Do what you need to do..But I would get the biggest machine that I could afford, and will fit where it needs to go.
/ Bobcat CT 225 #9
Also, I don't know how your planning on buying, cash or finance, nor is it any of my buisness.
But here is something to chomp on..Kioti has the free loader program going on....
Another member here just picked up a Kioti DK45 HST with loader for 21,500.
He was originally dealing on a DK40 HST, the dealer sold it and gave him the 45 for the same price.
If you are financing, maybe in the grand scheme of things the payment would still be in line??
Do a little more digging before you jump.
The thread is here...http://www.tractorbynet.com/forums/buying-pricing-comparisons/305007-kioti-dk40se-hst-vs-mahindra.html
I wouldn't worry about screwing it up...slow and cautious, once you get these home they shrink.
I would be more worried about wasted dollars by not buying the right machine the first time:)
Good Luck
/ Bobcat CT 225 #10
I also agree that you should be looking a little larger. I understand budgets, but you can spend just a couple grand more and get way more tractor from either Kioti (same tractor as the Bobcats), LS, TYM, Mahindra, etc.
You can get a new LS G3038 (38hp) with loader for around $15k.
General rule of thumb, especially on your first tractor purchase ... buy one size larger than you think you should.
/ Bobcat CT 225
Where can I find a deal like that? I'll check it out.
Thanks
/ Bobcat CT 225 #13
Thanks
I priced one for my brother in law at Marshfield, Mo, for about 15K and that was a hydro.. But Marshfield is a bit far for you... See if you can find an LS dealer near you.
Supposed to be one in Shelbina. and one in Freeburg mo.
Four R-D Repair
Address 351 Fairground Rd
Shelbina, MO 63468
Phone 573-588-4444
/ Bobcat CT 225 #14
My first reaction was that you need more tractor. But, the CT225 should be OK. The price is excellent. It loader height is plenty high enough unless you need to load a dump truck. One suggestion option: rear remotes. I'd get at least one, and preferably 2. Also, for your needs, I'd go AG tires. R4s are terrible in the mud. Good idea to check out LS. I also think a gear version might be a better match for you and save some money. Kioti has geared models of these tractors. Not sure if McCormick is offering geared versions.
/ Bobcat CT 225 #15
I don't use my tractor for 10 acre tilling. Forgive my ignorance, are you considering a rototiller or a plow to till the 10 acres? How much horsepower is needed for either attachment?
How much time does it take to till 10 acres? With more horsepower are you able to move faster and finish sooner? A ct225 is probably only going to pull a one (single) bottom plow, a two bottom or more will of course get the job done sooner.
/ Bobcat CT 225
I'll be calling these guys today.
Thanks
/ Bobcat CT 225
The guy I'm talking with about the ct225 seems like a buyer/reseller, he's got three left, I think there are no other choices. From all I've read, if I can afford the hst, I'm going for it. Just depends on how much more tractor I can buy by giving it up.
/ Bobcat CT 225
That's a question I seriously need to get answered. The Kubota dealer told me to go with a LS3800, and roto-till it, with a reverse tiller. I don't know if a ct225 could pull that off, as apparently, the Kubota can.
It's appearing as there is no sure fire right decision, unless you pull the $$$ out of the equation, then it's easy. Ha
/ Bobcat CT 225
Thanks.. There's a lot of junk back in the woods I need to try and pull, haul out, I'm thinking the HST will really help.
SEARS SUBURBAN SIX SPEED (A62131)
SEARS SUBURBAN SIX...
40' CONTAINER (A62131)
UNUSED KJ 20'X12' LIVESTOCK METAL SHED (A62131)
UNUSED KJ 20'X12'...
INOP/NON-RUNNING 2006 Freightliner M2 106 Day Cab Truck, VIN # 1FUBCXDC06HW03952 (A61165)
INOP/NON-RUNNING...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
2019 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 PETERBILT 579...
