Carts or Wagons to Pull Behind Tractor
/ Carts or Wagons to Pull Behind Tractor #1
tarzane
Member
Leander, Texas
John Deere 1025r
Seeking advice on best cart/wagon to get to pull behind my 1025R JD, to haul bulk materials, dirt, firewood, brush, etc. Brand, size, feature recommendations are sought. Thanks.
/ Carts or Wagons to Pull Behind Tractor #2
I've found that a carry-all works as good for me as a tow-able cart for the materials you mentioned...they are very adaptable for different hauling applications...
...a self dumping trailer is another story...
Thanks, /Pine! Is carry-all a brand name, or could you tell me where you got yours so I can look at their products?
/ Carts or Wagons to Pull Behind Tractor #5
Another selection:
3 Point Carry All For Tractors
A thing to watch for: some have the rear horizontal bars connected near the end. Those work for building a platform on, but you can't use a pallet or use it like forks.
A trailer is better for long items like logs or tall brush. With a carryall you have to carry it crossways or drag one end.
Bruce
/ Carts or Wagons to Pull Behind Tractor #6
One advantage of a carry-all, if you haven't thought about it, is you can make the platform to do just exactly what you want it to do, and it will sure "back up" a heck of a lot easier than any trailer.:) And will turn a lot sharper too! Not to mention it will probably be cheaper to buy/construct too.
thanks for the excellent information. It is very helpful.
Thanks, James KOUA, good points I'll take to heart.
/ Carts or Wagons to Pull Behind Tractor #10
Much depends on your terrain. If steep hills are involved, a carryall is safer than a trailer, and a trailer is safer than a wagon. As alluded in an earlier post, that same order applies for maneuverability. And reverse order for capacity- generally speaking, wagons have the largest capacity and carryall the smallest.
/ Carts or Wagons to Pull Behind Tractor #12
I have an older Canadian MUTS single axle trailer which I mostly pulled behind my Kubota RTV500 utility vehicle. As the load is carried low, between the wheels, the MUTS is very stable loaded. The current, larger MUTS two axle trailers would be good behind tractors. THE TILT/DUMP feature is wonderful and has worked faultlessly for me the last thirty months. Well worth the substantial freight to get the MUTS to Florida from Canada.
If you telephone MUTS you speak to Larry Edgar, the designer, in person.
LINK:
MUTS - Multi-Use Trailer System for your ATV, Quad and 4 Wheeler - Welcome
/ Carts or Wagons to Pull Behind Tractor #13
I like the baby hay rack I made a few years ago. It's about 5'w by 9' long. Here is a pic of it with a load of walnuts.
/ Carts or Wagons to Pull Behind Tractor #14
View attachment 363027I built my own farm wagon. I bought the running gear( ten ton Horst Model 185) and with free plans obtained from the internet I constructed a box that exactly fits my needs. The running gear was $1600 and the box materials and tires were $1200. At first I thought it would be too difficult for me but the further I looked into the project - the more fun/interesting it became. It took me two weeks to complete the wagon - a total of about 12-14 hours. The only down side to this type wagon is since it does have front steering - exactly like a car - it is a bit tricky to learn to back up. Otherwise, its been a fantastic wagon and will carry anything I need moved.View attachment 363026
/ Carts or Wagons to Pull Behind Tractor #15
Check local CL for a "flair box or barge box" wagon.
If its a trailer you want/need, they can be had reasonably cheap with a Hoist to dump it if you have the remotes to hook it to...
Thanks, BCP, now it's becoming clear to me the difference between carry-all, utility cart and wagon and trailer!
Thanks, Lobsterman1, I watched the video on the T-Rex. Very well done.
