anybody own a pull type blower?
/ anybody own a pull type blower? #1
flyingcow
aroostook county maine
I'm curious of anyone has owned or had first hand experience use of a pull type blower?
I own a 4 wheel drive NH TN75da. I now have a typical 3 point mounted 7 1/2ft Lucknow. If I could stumble across a pull type (used) cheap enough i might buy it. I understand that it's not ideal, but in less than a foot storms it'd be ideal.
thanks
/ anybody own a pull type blower? #2
We had one 40+ years ago and it worked OK with dry snow. Heavy wet snow would not feed into the blower since ours was basically a V with the fan in the middle. This was used on a 2WD 2510 JD.
/ anybody own a pull type blower? #3
I use an old Arps V type pull behind blower on a Ford 860 and it works OK. Dry snow is easier than wet. When it is wet it helps to let it lay a day so it dries or freezes. I also use a 6 1/2 foot Erskine pull behind on a Ford 4000SU. It is great as long as the tractor can get through the snow. If the snow is too deep I still have access to a traditional blower used backing the tractor up. PS. All the tractors also have front mounted blades.
/ anybody own a pull type blower? #4
My dad still uses one and claims it's no different to our newer ones really . Just if it'ds deep a 2wd is useless .
/ anybody own a pull type blower? #5
On my L4200, I have a agro-trend 72" pull type blower.
Would never go back to a push type, my neck just can't handle it anylonger.
I paid $2500 plus taxes, second hand but almost new condition, hydraulic chute and rotate.
Well worth every penny, and your machine can handle these no problem.
In your situation, I'd get a larger one, 78" at least.
Mine can throw snow 30 to 40 feet easily and can handle 2 foot "banks" left over from my front blade.
Love it, you get what you pay for, new they go upwards of $3000.
Really prefer not to buy new, just yet. Looking around for one in my region, who knows if i will find it. I want a 90 inch, covers my tracks good.
I'm all set with what i have now, putting a back up camera has helped some. I looked into putting the blower i have now on my FEL, but really would like to keep that end free for the bucket, or maybe a pusher if i find a sweet deal. May end up putting a 8ft blade(w/hydr switch) on the FEL. As you can see, I'm all over the place.
Just looking for some first hand experience with the pull type. I think with the exception of a few storms the pull type will work good. Pull type with a blade would be ideal.
/ anybody own a pull type blower? #7
Yup..... TL100A New Holland with a Normand 92-280 Inverted blower.
/ anybody own a pull type blower? #9
https://www.youtube.com/watch?v=8ou6IOxwJCk&feature=youtube_gdata_player
Check out this video.... normally this driveway takes less than 1 minute. But, because no one lives there, I let it sit through a 3 day storm. The snow was about 36" deep at the deepest point. But it was also packed and drifted from 4 days of 25+ mph winds. I'll see if I have another video of me going through more drifts. I get TONS of drifting out by my biggest account, which is why I went to an inverted blower.
/ anybody own a pull type blower? #10
This was another driveway that was not cleared for over a month. 2 companies with pick up trucks tried and gave up. Entrance to the drive was 40" of packed snow from the county plow trucks. 225 feet long, 12 feet wide with a side load garage took 12 minutes.
/ anybody own a pull type blower? #11
Very cool. Does yours have the poly/urethane/plastic rear blade edge, or steel?
/ anybody own a pull type blower? #12
I burned up the standard steel edge in the first 12 or so events, then had a Hardox steel edge made. I have used up almost half of the Hardox edge now. We have been out close to 35 times so far this year. I don't run any shoes at all. I want it to scrape as well as possible because I maintain a few miles of roads in a subdivision, so vehicle traffic is always packing the snow.
I looked into using the Tivar 88 edge, but they don't scrape very well.
The first pass did you need to keep the blower up part way? And how much weight do you have on the front end?
/ anybody own a pull type blower? #15
Wow, that's some serious wear!
/ anybody own a pull type blower? #16
No weight on the machine at all. And no, I didn't keep the blower off the ground. Just pick the right gear, maybe lock the differential, and let her eat!
I am pretty happy with how the Hardox edge is wearing. The steel edge did what I expected..... wear out quickly.
I think I put on about 8-10 miles per day of blowing roads open. Then I pick up about 40 driveways and finish up helping my partner a my church, where I blow the roads and driveways open.
/ anybody own a pull type blower? #18
I have to say this about rear pull blower's,
if your tractor can't drive through the snow your going to blow,
then get a rear push.
/ anybody own a pull type blower? #19
Have used pull type snow blowers on the farm since the 60's. Works very well as long as there is more snow than the that tractor manage to run in. If you buy V type so make sure it is straight walls on it and not curved as there is a huge difference in how wet snow it manages.
Now I have one two stage snow blower that can be pulled or reversed, it has perforated wear steel on it so there is no problem with the wheels of the tractor packs the snow before going into the snowblower. Pull type or front mounted snow blower is the most common over Norway, has been involved in a few that can be reversed or pulled simultaneously without re connect tractor
2017 Mercury SeaPro 115HP Outboard Boat Motor (A61574)
2017 Mercury...
2019 GMC SIERRA HD 3500 (A63569)
2019 GMC SIERRA HD...
2006 Cadillac Superior 6-Door Limousine, Ultra-Low 20396 Miles (A63689)
2006 Cadillac...
2015 Chevrolet Silverado Pickup Truck, VIN # 1GCNKPEH7FZ334229 (A65563)
2015 Chevrolet...
2012 International Prostar (A63118)
2012 International...
40in. Skeleton Bucket Excavator Attachment (A61567)
40in. Skeleton...
