753
753
aragon ga
753 bobcat
I have a 753 bobcat front loader and I'm having trouble with my hydrolics when I raise my boom up. It won't come back down, when I tilt my Buck it down it won't come back up
Does that bobcat has some sort of regeneration valve ? It puts oil in the cylinder but doesnt let it back out. You can extend both cylinders but not get them in anymore, pushing them out requires more oil than pulling them in because pulling means the surface of the piston rod misses. You have a return flow problem of some sort, probably in an additional valve like a regeneration valve.
One of the auxiliary solenoid stems is stuck "on".
/ 753
Thanks I pulled those aux selonoids out and checked that was my problem its now working again thanks .
12 in. WRXLS Excavator Bucket (A64194)
12 in. WRXLS...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A63118)
Case Wheels for...
2014 VOLVO A40G WATER TRUCK (A65053)
2014 VOLVO A40G...
2017 Mack Semi (A64047)
2017 Mack Semi...
Bobcat Pallet Forks (A64127)
Bobcat Pallet...
2001 KENWORTH W900 72" STUDIO SLEEPER (A62613)
2001 KENWORTH W900...
