Laser grading hydraulic valve issue.
   / Laser grading hydraulic valve issue. #71
I am curious if this matter was ever sucessfully resolved?
Got it hooked up today. I put the valve in the line just to verify that there is no more pressure.
Right away, it started spewing oil out of the vent hole in the fill cap. I called my guy at the machine shop, and he will try to fabricate another connection with a diverter welded inside to make sure the return oil goes down, and doesn't spew out of the vent hole.
No, it has not. My guy at the machine shop is supposed to be fabricating a fitting similar to the one in my pic above, but with a 'baffle' welded in it to keep the oil from spewing out of the vent hole. He hasn't got that for me yet.
   / Laser grading hydraulic valve issue. #73
Is the return pipe below the fluid level.
Dumping into the air space in a reservoir is not recommend for any hyd system.
Is your reservoir at the correct level with all cyl filled?
No it's not below the fluid level. It dumps into the fill cap. If what you are saying is true, then I'll have to start over. I don't want to start over.
   / Laser grading hydraulic valve issue. #75
Why start over, any return line should be returned below the fluid level, just extend the line going further down into the fluid.
   / Laser grading hydraulic valve issue. #76
The trick will be doing that inside the tee while leaving the vent intact...
To test, you might cap off the vent and loosen the dipstick.
Aaron Z
I had a new fitting made hoping to direct the oil flow downward so that it wouldn't spew out of the vent. You can see the new fitting on the left and the old one on the right.
It didn't work. As soon as I got the rpm's up on the tractor, oil began spewing from the vent.
The picture below shows the vented cap in place with the dipstick where it should be.
I replaced the vented cap with a non-vented cap and pulled the dipstick out just a little hoping that this would be enough to 'vent' the system. I'm headed to work on a field early next week with it like this. Hope it works.
I also checked with my Kubota dealer to see if there is any kind of 'power beyond' kit available for this tractor, and they said there is not. I would have to go to an aftermarket system. I've gotten so many different stories about how I should handle this, that my head is spinning. I'm going to try it like this, and if this doesn't work, I'll hook it back to my New Holland tractor to finish this job.
   / Laser grading hydraulic valve issue. #78
I suspect that set up above will entrain so much air to cause system damage. Not familiar with Kubota plumbing but it would seem to be better to tee into the lower drain plug than to go thru the vent/fill.
Hope you can get this resolved and put all of this to work.:thumbsup: I am waiting on a PVG 32 dual valve set up for a new laser system in the making right now.
What sort of damage to the system would it cause?
How would I know if there is too much air in the system?
   / Laser grading hydraulic valve issue. #80
I would be concerned with pump cavitation and heat. When you compress the hydraulic oil with air bubbles in it you can get a lot of heat generated, clear oil without the bubbles isn't going to compress/expand much.
I would watch carefully for the pump over heating, might wan't to buy an infrared thermometer. Does your tractor have a transmission temperature gauge? If so that should provide you with some indication of rising fluid temperatures.
Glad I found this thread as it is difficult to find much information on machine control systems for the small tractors. It is easy to see that a tractor with closed center hydraulics is a much better choice, might wan't to look for an older Deere 2wd tricycle 3020. That might be a lot better choice than my current 4520 for this work as I need the 4x4 engaged to pull the box blade and it it has open center hydraulics.
The gentleman who has Laser Grade did suffer a bad injury that is causing him to shut down his business. He was the most helpful person I have found on machine control systems on the internet. I have spoken to his wife early last year and hope for the best for Dan and his family.
1985 Miller Wildcat 350-D Welder (A51691)
1985 Miller...
CID 72" Skidloader Heavy Duty Mower (A50775)
CID 72" Skidloader...
1996 Elgin Pelican Series S Street Sweeper (A55787)
1996 Elgin Pelican...
2007 Yamaha Rhino 660 (A55301)
2007 Yamaha Rhino...
2017 FREIGHTLINER M2 106 (A55745)
2017 FREIGHTLINER...
2021 VOLVO VN SERIES DAY CAB (A55745)
2021 VOLVO VN...
