Bolt on cutting edge for BX
/ Bolt on cutting edge for BX #1
Happy Gilmore
Southeastern, MA
Ford 5610 Ford 4630 Ford 3930 MFWD w/ 7310 loader Ford 3930 Kubota BX1500 Kubota RTV 900XT Kubota F2680E 72"RD Ford 4610 Kubota KX121-3
I have tried searching the site as well as google for information on purchasing a standard bolt on cutting edge for my BX1500 loader bucket. I haven't had much luck. I'm not looking for a tooth bar, just a straight bolt on cutting edge. Any feedback is much appreciated, thank you.
/ Bolt on cutting edge for BX #2
Ya I did it. Put one on my BX25-D. Everyone said there wasn't one available so I bought a longer one from my Kubota dealer and cut it. Here's a few pics of the process and the part number.
Nice job 4shorts, what was the thickness? How much do you figure it weighed after cutting? Thanks
/ Bolt on cutting edge for BX #4
I can't remember off hand the exact thickness but it's around 5/8th. I figure it added another 40 lbs to the bucket plus I added a top spill guard and it had no effect on the machines ability to lift a full bucket of anything that I put in it.
I put the reversible cutting edge on because the OEM lip wears fast on these buckets. I do 3-4 of them every year for customers, I have to cut out the worn section and weld in a new piece. I had a few where the bottom of the bucket was bowed because of the wear so the cutting edge adds to its strength plus prevents wear on the bucket.
/ Bolt on cutting edge for BX #5
I have a bolt on cutting edge and its great. For the life of me I can't remember where I got it... Same company makes tooth bars. Its solid and was a great price.
Two bolts on the side..
/ Bolt on cutting edge for BX #6
Might have come from BXpanded. Does it look something like this?
/ Bolt on cutting edge for BX #7
I'm shopping for one at the moment as wel. My dealer offers one from W.R. Long (not a stocked item) that they claim will fit, but seeing the bxpanded one above got my interest as I would prefer one that uses the same mounting holes as my piranha bar over potentially drilling another set of holes.
/ Bolt on cutting edge for BX #8
Here are some pictures of a tooth bar I made. I have not seen a commercial product that will do what these teeth will do. I can really dig with the FEL plus I spaced them so I could still use the clamp on forks. The 2 tabs in the center are to hold an attachment that is a class 3 trailer hitch. All so I do not need to unbolt the two bolts all the time. I seldom use the smooth edge anymore. The teeth are replaceable. The teeth help a lot when picking up rocks or limbs/logs.
Ron
Nice looking job Tractor Seabee!
I'm happy to report after a seemingly endless search I have found a source for a 1/2" x 6 - 48" bolt on cutting edge complete with hardware. ATI offers one. :thumbsup:
/ Bolt on cutting edge for BX #11
I remembered where I got mine.. WR Long. No complaints. Has held up great to the asphalt and snow clearing...
Wear Blades WB and IWB
/ Bolt on cutting edge for BX #12
Ron
View attachment 361416View attachment 361417
Yes Ron! Always impressive seeing the work you are done with your BX. I have a big pile of clearing debri at my place and you are an inspiration. :thumbsup:
/ Bolt on cutting edge for BX #13
Will these work on cutting down small cedar trees (<2")? Been looking for an easier way to clear a path
/ Bolt on cutting edge for BX #14
No, they are wear blades not a cuisinart, In fact they are more blunt than the oem edge... but that one reason your oem will wear faster... thinner ..
