Bolt on cutting edge for BX
   / Bolt on cutting edge for BX #11
I have a bolt on cutting edge and its great. For the life of me I can't remember where I got it... Same company makes tooth bars. Its solid and was a great price.
Two bolts on the side..
I remembered where I got mine.. WR Long. No complaints. Has held up great to the asphalt and snow clearing...
Wear Blades WB and IWB
   / Bolt on cutting edge for BX #12
Here are some pictures of a tooth bar I made. I have not seen a commercial product that will do what these teeth will do. I can really dig with the FEL plus I spaced them so I could still use the clamp on forks. The 2 tabs in the center are to hold an attachment that is a class 3 trailer hitch. All so I do not need to unbolt the two bolts all the time. I seldom use the smooth edge anymore. The teeth are replaceable. The teeth help a lot when picking up rocks or limbs/logs.
Ron
View attachment 361416View attachment 361417
Yes Ron! Always impressive seeing the work you are done with your BX. I have a big pile of clearing debri at my place and you are an inspiration. :thumbsup:
   / Bolt on cutting edge for BX #13
Will these work on cutting down small cedar trees (<2")? Been looking for an easier way to clear a path
   / Bolt on cutting edge for BX #14
No, they are wear blades not a cuisinart, In fact they are more blunt than the oem edge... but that one reason your oem will wear faster... thinner ..
Honda ES 6500 Generator (A55973)
Honda ES 6500...
2015 FREIGHTLINER M2 BOX TRUCK (A58017)
2015 FREIGHTLINER...
MASSAGE CHAIR (A58214)
New/Unused SD Lanch 12x20 Enclosed Carport (A57454)
New/Unused SD...
Year: 2013 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A56859)
Year: 2013 Make...
2019 Ford F-550 Altec AT41S 40ft. Bucket Truck (A55973)
2019 Ford F-550...
