Bolt on cutting edge for BX
   / Bolt on cutting edge for BX #11
I have a bolt on cutting edge and its great. For the life of me I can't remember where I got it... Same company makes tooth bars. Its solid and was a great price.
Two bolts on the side..
I remembered where I got mine.. WR Long. No complaints. Has held up great to the asphalt and snow clearing...
Wear Blades WB and IWB
   / Bolt on cutting edge for BX #12
Here are some pictures of a tooth bar I made. I have not seen a commercial product that will do what these teeth will do. I can really dig with the FEL plus I spaced them so I could still use the clamp on forks. The 2 tabs in the center are to hold an attachment that is a class 3 trailer hitch. All so I do not need to unbolt the two bolts all the time. I seldom use the smooth edge anymore. The teeth are replaceable. The teeth help a lot when picking up rocks or limbs/logs.
Ron
View attachment 361416View attachment 361417
Yes Ron! Always impressive seeing the work you are done with your BX. I have a big pile of clearing debri at my place and you are an inspiration. :thumbsup:
   / Bolt on cutting edge for BX #13
Will these work on cutting down small cedar trees (<2")? Been looking for an easier way to clear a path
   / Bolt on cutting edge for BX #14
No, they are wear blades not a cuisinart, In fact they are more blunt than the oem edge... but that one reason your oem will wear faster... thinner ..
Skid Steer Sweeper (New/Unused) (A59225)
Skid Steer Sweeper...
John Deere 5105M (A53317)
John Deere 5105M...
Hydraulic rail grinder (A56435)
Hydraulic rail...
2022 Wacker Neuson PDT2A 2in Portable Diaphragm Pump (A55851)
2022 Wacker Neuson...
Volvo EC220DL (A57148)
2014 SKYTRAK 10054 TELEHANDLER (A58214)
2014 SKYTRAK 10054...
