winch implement?
/ winch implement? #1
jomifo
Member
Northeast Ohio
BCS 852
Has anybody ever seen or made a mechanical winch (capstan or drum-type) for their 2-wheeled tractor?
I'm looking into building my own capstan winch when it dawned on me that the BCS seems like a good fit to drive a winch. I have an extra tiller I might be able to repurpose its gearbox for this. But then again maybe that would spin to fast for winching?
/ winch implement? #2
I had a fellow call me about a capstan winch attachment once. After a long discussion, we decided that he would be better off with a small purpose built capstan winch. They're very portable and can be used anywhere they can be anchored. A BCS might make a good power unit, but it would not be nearly as portable. It would still have to be anchored to pull anything over a couple hundred pounds.
The tiller spins at 290 rpm at full throttle. Looks like the capstan spools run about 32 rpm? I just took 3600 rpm engine and divided it by 110 to1 gear ratio on one I found online. But they're running it on a 50cc engine. You may be able to run the much larger engine at a lower speed to get a slower rpm at the tiller. I'd think it might be a fun project and you're not out much if you have on old tiller to play with. You might even be able to use one section of the tine hub for the spool.
I have an older BCS tiller box here with one side of the tine set broken off. If I get around to it, I may do some playing.
/ winch implement?
32 rpm sounds like in the ballpark. Now that I think of it, maybe it would be more practical to use the drive off the axle to hook the spool to. I wonder what the rpm of the wheel is for the various gears for my old bcs 715.
/ winch implement? #4
The old advertising said 10 to 1 in 2nd and 20 to 1 in first. So 29 rpm in 2nd or 14.5 rpm in first.
/ winch implement? #5
My old Gravely PRO 8 would have been good for that, with all its speed options on the PTO. But what would you use something like this for?
/ winch implement?
Thanks farmerboybill for those rpm numbers.
Industrial Toys- I'm wanting to pull logs out of a fairly steep ravine- 60ft rise over 100 feet run. Kind of crazy I know, but hard for me to see good fallen timber just sitting there to rot.
TimberXX- Thanks for the link.. I have been scanning CL for similar things, but haven't had much success. I did see a capstan winch off of a tug boat.. Tugboat Capstan: 24" Diameter Vertical Capstan A bit overkill I think. Hehe.
/ winch implement? #8
If your unit is electric start would you consider a winch off of a small pleasure boat and run it off the battery? Marine batteries are much bigger but maybe someone can chime in.
/ winch implement?
Good thoughts. I actually already have a 4 wheeler with a 3500lb electric winch, but I don't think it's quite up to the task. For one the winch on the 4-wheeler only holds 40 feet of line, so I'd have to go down hill (which is pretty steep) and reattach the winch line to make the complete 150+ feet pull. Also, electric winches have a low duty cycle. Something you don't have to worry about with a mechanical setup.
/ winch implement? #10
I am starting at this Toyota transfer case and was thinking if I could use it to build a capstan winch. Too rednecky? Figure I'll build a platform for the 3pt, purchase an appropriate length PTO driveshaft from TSC, build an adapter the Tcase coupling and find a capstan drum on EBAY. This Tcase has a 2.5:1 low reduction, couple that with the typical PTO speed option, I should be able to a decent RPM option.
2021 VERMEER S925TX STAND ON SKIDSTEER (A52709)
2021 VERMEER...
2020 HAMM H7I COMPACT LINE SMOOTH DRUM ROLLER (A59823)
2020 HAMM H7I...
Kubota BX25D (A53317)
2020 BOBCAT E42 MINI EXCAVATOR (A60736)
2020 BOBCAT E42...
2022 FORD F-150 XLT CREW CAB TRUCK (A59823)
2022 FORD F-150...
2011 INTERNATIONAL 4400 (A60736)
2011 INTERNATIONAL...
