Wood deck coatings
/ Wood deck coatings #1
DSM123
Member
North Texas
MF203, MF135, IH2400A backhoe
It seems like the most damaging element here is the suns UV rays drying out the wood causing it to split. I have a wood deck off the back of the house and the part that is shaded from the house is in very good shape after 10 years. The areas that have been exposed to full sun have been replaced once already and are starting to look bad again.
I'm seeing the same with my trailer's decking and wonder what we can use to preserve them without making them too slick. I don't mind recoating every couple of years. Beats replacing the wood. I was thinking about using boiled linseed oil but I suspect it has little UV protection.
/ Wood deck coatings #2
You are absolutely correct regarding UV degrading wood. That's why stains protect better than clear finishes. I would suggest a "penetrating" type oil stain sometimes referred to as semi-transparent. It soaks in well and leaves a bit of protective pigment in the wood pores. It'll gradually wear off rather than chip or peel like solid stains/paint, at which point just apply another coat. Do read the directions, some have paraffin type repellents in them which can repel a second coat should you attempt to apply one after the first coat completely dries.
/ Wood deck coatings #3
As a log home owner, I have done lots of research here. Oil based works best for me, and not the stuff at big box stores. At the big box store you will find oil based stains that allow for water clean up. (so it's not really oil based is it?)
I pressure wash with bleach, and then use a titan paint sprayer and TWP 100 stain. It has UV protectors.
TWP 100 Stain by Amteco | Free shipping on all internet orders over 100
Would a darker color stain offer better UV protection? I'm not particular to the color.
/ Wood deck coatings #5
Don't know a thing about it but I hear them advertising some kind of ceramic paint on the radio here. They say it's guaranteed for life but that sounds a little too good to be true.
/ Wood deck coatings #6
It's basically the same stuff they use on truck bed liners.
Chris
/ Wood deck coatings #7
I just built this deck late last Summer and used a Valspar deck stain and it soaked in really well and repels water. It goes on like paint and the semi-transparent type I used shows a bit of the wood grain but contains a lot of solid particles. So far I like it much better than the translucent stains/preservatives I used on the older/ past deck. I plan to add another coat this next Spring to ensure good weatherproofing.
/ Wood deck coatings #8
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=357559"/>
I thought you had to wait a full season before sealing wood?
Chris
/ Wood deck coatings #9
In some areas that might be true but here on the Texas Gulf Coast this deck received 95F-100F temperatures for 2 months and 6 hours of hot western sunlight for 2 months before I applied the Valspar. The top decking which was treated 2X6 lumber with routed edges was screwed to the frame using furniture clamps where there was absolutely no space between the boards. Eight weeks later they all had a 1/4 inch gap between the boards so they had dried and shrunk enough to seal in my situation. Further north with moderate temperatures is a different case. In my area you can literally fry eggs on a Western facing deck for 4 months of the year from mid to late Summer.
/ Wood deck coatings #10
I've had good luck with Cabot's stain on decks for clients and have started using it on the cedar posts I use on my place. Something to consider is that if the deck is 5/4 wood, it is going to shrink for at least a year. I still use 5/4 for some things, but prefer treated 2x8's for my decking. After years in the sun, there is almost no shrinkage or cupping like you get with smaller lumber. I never use nails either. Screws for decking, bolts for joists and beams on a solid rest notched out of the posts. I only use 6x6's for posts. Nothing else remains straight. It's not about strength, it's all about how it holds up over the years and what has proven to work compared to what fails over and over again.
Eddie
/ Wood deck coatings #11
Eddie
Hey Eddie, I like the way you build, Build to last, Fortunately for those of us who re-build the decks from the 70's & 80's,90's didn't have them built to last or we would be out of business,;)
Have you ever worked with Ipe materials? I'm sure you have, It's not cheap but would be an alternative to using 2x materials for the actual decking, I use it in the higher end homes, ( Country clubs homes) etc,etc, it is very durable no shrinking, and can last 100 years if properly maintained, it's likely the framing structure will give way before the decking does,
No kidding regarding the shrinkage. I built a huge deck off the back of this house and the fit of joinery was "furniture quality" as mentioned by a few friends. Six months to a year later it looked as though I eyeballed the cuts and used a chainsaw. Gaps, twist, cupping... $7K worth of crap lumber. I'm done with wood. Next house I'll pour a slab.
/ Wood deck coatings #15
Not necessarily, whether the pigment is light or dark makes no difference (for instance white zinc oxide is a very effective sunscreen). There is a minimum amount necessary, light tints usually just have more white or light pigment.
What about shingle oil or linseed oil?
Linseed oil feeds the wood well the only problem is for outdoor use it's a "food" for mildew, mold, etc. Years ago effective poison was added (trace amounts of mercury for example) but those days are long gone. The newer mildew/mold additives don't seem to be as effective but work well enough for exterior oil stains. Generally better quality exterior stain/paint has more mildew preventatives than bargain stuff.
/ Wood deck coatings #16
Thats why i use old engine oil, in a 50/50% mix with carbolineum. For best effect, empty a bucket over it in the midst of summer so it gets soaked all up into the grain of the wood, and sweep it out with a broom.
/ Wood deck coatings #17
Olllotj, the Amteco web site says TWP 100 cant be shipped to NY and about 15 other states?? I see you're in NY. How do you get it?
2012 FREIGHTLINER 114SD ROLLOFF TRUCK (A59909)
2012 FREIGHTLINER...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Bucket Truck (A60352)
2018 Freightliner...
2021 UTILITY VS2DX 53FT DRY VAN (A59905)
2021 UTILITY VS2DX...
Gleaner N630 Corn Head (Allis Chalmer Branded) (A61307)
Gleaner N630 Corn...
2716SFL (A61567)
2716SFL (A61567)
2010 GREAT DANE SUP-1114-31053 T/A REFRIGERATED TRAILER (A59914)
2010 GREAT DANE...
