Wood deck coatings
   / Wood deck coatings #1
DSM123
North Texas
MF203, MF135, IH2400A backhoe
It seems like the most damaging element here is the suns UV rays drying out the wood causing it to split. I have a wood deck off the back of the house and the part that is shaded from the house is in very good shape after 10 years. The areas that have been exposed to full sun have been replaced once already and are starting to look bad again.
I'm seeing the same with my trailer's decking and wonder what we can use to preserve them without making them too slick. I don't mind recoating every couple of years. Beats replacing the wood. I was thinking about using boiled linseed oil but I suspect it has little UV protection.
   / Wood deck coatings #2
You are absolutely correct regarding UV degrading wood. That's why stains protect better than clear finishes. I would suggest a "penetrating" type oil stain sometimes referred to as semi-transparent. It soaks in well and leaves a bit of protective pigment in the wood pores. It'll gradually wear off rather than chip or peel like solid stains/paint, at which point just apply another coat. Do read the directions, some have paraffin type repellents in them which can repel a second coat should you attempt to apply one after the first coat completely dries.
   / Wood deck coatings #3
As a log home owner, I have done lots of research here. Oil based works best for me, and not the stuff at big box stores. At the big box store you will find oil based stains that allow for water clean up. (so it's not really oil based is it?)
I pressure wash with bleach, and then use a titan paint sprayer and TWP 100 stain. It has UV protectors.
TWP 100 Stain by Amteco | Free shipping on all internet orders over 100
Would a darker color stain offer better UV protection? I'm not particular to the color.
   / Wood deck coatings #5
Don't know a thing about it but I hear them advertising some kind of ceramic paint on the radio here. They say it's guaranteed for life but that sounds a little too good to be true.
   / Wood deck coatings #6
It's basically the same stuff they use on truck bed liners.
Chris
   / Wood deck coatings #7
I just built this deck late last Summer and used a Valspar deck stain and it soaked in really well and repels water. It goes on like paint and the semi-transparent type I used shows a bit of the wood grain but contains a lot of solid particles. So far I like it much better than the translucent stains/preservatives I used on the older/ past deck. I plan to add another coat this next Spring to ensure good weatherproofing.
   / Wood deck coatings #8
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=357559"/>
I thought you had to wait a full season before sealing wood?
Chris
   / Wood deck coatings #9
In some areas that might be true but here on the Texas Gulf Coast this deck received 95F-100F temperatures for 2 months and 6 hours of hot western sunlight for 2 months before I applied the Valspar. The top decking which was treated 2X6 lumber with routed edges was screwed to the frame using furniture clamps where there was absolutely no space between the boards. Eight weeks later they all had a 1/4 inch gap between the boards so they had dried and shrunk enough to seal in my situation. Further north with moderate temperatures is a different case. In my area you can literally fry eggs on a Western facing deck for 4 months of the year from mid to late Summer.
   / Wood deck coatings #10
I've had good luck with Cabot's stain on decks for clients and have started using it on the cedar posts I use on my place. Something to consider is that if the deck is 5/4 wood, it is going to shrink for at least a year. I still use 5/4 for some things, but prefer treated 2x8's for my decking. After years in the sun, there is almost no shrinkage or cupping like you get with smaller lumber. I never use nails either. Screws for decking, bolts for joists and beams on a solid rest notched out of the posts. I only use 6x6's for posts. Nothing else remains straight. It's not about strength, it's all about how it holds up over the years and what has proven to work compared to what fails over and over again.
Eddie
2022 Big Tex 22GN-35BK+5MR 40ft T/A Gooseneck Equipment Trailer (A51691)
2022 Big Tex...
CAT 257D (A50123)
CAT 257D (A50123)
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2014 Jeep Grand Cherokee SUV (A51694)
2014 Jeep Grand...
UNUSED JCT 2 PRONG BALE SPEAR (A51248)
UNUSED JCT 2 PRONG...
2020 MACK PINNACLE DAY CAB (A53426)
2020 MACK PINNACLE...
