Choker Grab Hook
/ Choker Grab Hook #1
Gordon Gould
Super Member
NorthEastern, VT
Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
This may be to simple to post here but what the heck, it might give someone an idea.
I got tired of getting up close and personal to the butt end of a snowy log while I tried to push the pin end of a choker underneath and then grab it on the other side to pull it through. The pin always seems to be to short and to slippery. I had some time in the shop today so I made this Choker Grab Hook.
/ Choker Grab Hook #2
Nice job! I've thought about buying one of these for a while since all my choker pins are gettin pretty bent up. What did you make it out of?
/ Choker Grab Hook
I used stuff I had, I took a piece of 5/16" rod heated one end and formed a button like a nail head. Slid on a 5/16" washer then a 5/16" 1 1/4" dia fender washer and brazed the washers to the button to make a domed top. Took a piece of 1 1/4" fir closet pole and drilled a 5/16" hole down thru it and slid that on the rod for the handle. Then I took another fender washer, laid another standard washer on top of it, and stood a short section of 1/2" OD hydraulic tube on the washers. I brazed those together and slid the assembly on the rod against the handle. Then I brazed the lower end of the hydraulic tube to the rod to capture the handle. Last I heated the end of the rod and formed it around a 1/2" bolt to make the hook.
It is 36" long.
/ Choker Grab Hook #4
Nice idea!
/ Choker Grab Hook #6
Nice build.
Question unrelated to what you`ve built but in the pic, the slip hook on the chain, where did you get it and what is it`s proper name. I`ve tried to describe it to our local rigging supplier and all I`ve gotten was dumb looks.....Mike
/ Choker Grab Hook #8
Nice build.
It's called a Choker Hook. Try baileysonline.com
/ Choker Grab Hook
Nice build.
Thanks. Bailey's is good. Also if your closer to the east cost Labonville
Choker Hooks
Most chainsaw dealers here ( not box stores or hardware chains ) carry them and definately any logging supplier.
gg
EDIT: if you have 5/16" chain you will have to get this one. Standard size is 3/8" so make sure you check.
http://www.labonville.com/516-Choker-Chain-Hook_p_91.html
/ Choker Grab Hook #10
Thanks for the name, I'll try our local supplier now that I have a name and a pic......Mike
/ Choker Grab Hook #11
Nice tool, Looks similar to a king pin release puller you can find at truck stops. Drivers use them to reach the handle without having to get under the trailer. I have one made out of aluminum which would allow you to somewhat easily put a curve in it, It has a T-handle on it.
Eric
2023 Stearling Trailer (A60352)
2023 Stearling...
Massey Ferguson 2605 (A64126)
Massey Ferguson...
iDrive TDS-2010H...
213085 (A64276)
213085 (A64276)
2004 IH 5600I Snow Plow Truck (A62679)
2004 IH 5600I Snow...
2010 John Deere 7230 (A64126)
2010 John Deere...
