Tiller Tillers; Why buy anything but County Line?
/ Tillers; Why buy anything but County Line? #1
Cub72
PA
International Cub, LS R3039H
I'm in the market for a new tractor. I was going to start getting quotes with a rotary tiller included. But from my research on here, it always seems like the tillers are made by King Kutter with different paint jobs. Like the blue LS tillers. LS Tillers are made by Taylor Pittsburgh and Taylor Pittsburgh is owned by King Kutter. King Kutter also makes the red tillers for Mahindra. I also read that King Kutter makes the County Line tillers sold at TSC which are only $1700 for the 5 ft model. So my question is: If I get a quote for a tiller more than $1700 am I getting ripped off? Or am I missing something?
/ Tillers; Why buy anything but County Line? #2
I know nothing about County Line tillers (or any other tillers for that matter). But, while it's possible that King Kutter makes identical models and just paints them different colors for different vendors, it's equally possible that they make different tillers to match the specifications of different companies.
Just like Bush Hog and other rotary mower companies make different lines of mowers (light duty, medium duty, heavy duty, etc.) Just because it's a Bush Hog brand doesn't mean it's the equal of every other Bush Hog mower.
/ Tillers; Why buy anything but County Line? #3
King Cutter does not make all of TSC's implements. There's another maker but the name escapes me at the moment. Check the label for the maker on the tiller itself, the ones at my local TSC are not KK.
/ Tillers; Why buy anything but County Line? #4
Around here in MA the TSC stores have Tarter brand name.
/ Tillers; Why buy anything but County Line? #5
Yep, that's it. Most of the Tarter stuff looks identical to the KK stuff, and they come in the same County Line paint colors and decals.
Here's the tiller link. Rotary Tiller - Tarter Farm & Ranch
That said, I would consider buying a KK because the reputation is good and you can order parts directly from KK. Just make sure its really a KK. I bought my box blade at TSC thinking it was a KK but it turned out to be a Tarter.
/ Tillers; Why buy anything but County Line? #6
I would recommend first decide what you are trying to do. Are you trying to get a King Kutter tiller at a big store price. If your trying to buy a King Kutter tiller then you should buy one that has a King Kutter name and decal on it. Your statement above is only partially correct. King Kutter does not make the Mahindra tillers. King Kutter has supplied some TS stores with tillers and so has other vendors. Sadly, many customers are finding out that SOME of the parts will not interchange. I have customers ordering parts for their TS tiller and using KK part numbers only to learn they are ordering the wrong parts. KEEP UP WITH THE SUPPLIED MANUAL SHOWING THE PART NUMBERS.
/ Tillers; Why buy anything but County Line? #7
I think most implements at TS are cheap crap and they don't back their products. jmo
/ Tillers; Why buy anything but County Line? #8
SWEETFARMS.COM
We sell the 5 Ft Tarter above delivered to a PA Business or truck terminal (Shipping Zone 2) for $1855. It is forward or reverse rotation. We also sell the Phoenix line, If you prefer Italian workmanship. Ken Sweet
/ Tillers; Why buy anything but County Line? #9
Find a Woods dealer. Go eyeball the tillers in all three ranges.
Then eyeball the wretched crap sold at TSC.
The Tillers sold under the LS sticker will have slight differences from the KK. Usually minor stuff.
Still solid, but you're not getting what you would from Woods.
Then consider dealer support, parts, and availability.
Weigh it all up while considering your use.
The cheapo TSC trash might be the better deal for a guy running 20-30hp on 2acres of loose ground twice a year.
**** sure don't hold up tilling an orchard of any size 3-4 times a year, behind a 50-100hp tractor.
The LS tillers are a bargaining point for the tractor dealers. They have a better margin on the impliments.
Always get them cornered on price without attachments first. Wait a day, and come back asking about tossing in other stuff.
The Local LS dealer has put a couple dozen of those tillers in the orchards around here.
They hold up just fine with heavy use(Abuse quite often) behind the 30-40hp tractors.
Just don't hook them up behind the 5525 and expect them to put up with munching prunings in the spring.
Good luck on the LS!!!
/ Tillers; Why buy anything but County Line? #11
wow I had never heard about Tarter, looks to me that it's the one to buy
/ Tillers; Why buy anything but County Line? #12
I just ran into these yesterday, there doesn't seem to be a manufacturer listed. I was wondering if anyone had any in put or maybe had one and knew about the quality. You just can't beat the price that is if it is any good.
Rotary Tiller, Rototiller, Tillovator | Agri Supply, 77711, Gear Driven
I also like the gear drive this actually seems to good to be true. Which means it probably is!
/ Tillers; Why buy anything but County Line? #13
After looking at all the tiller brands available around here, I ended up buying a 6 foot King Kutter II model from my local Atwoods for $1834. This was the best deal I found other than some of the Chinese made ones like Agri-supply sells. KK, Tartar and LandPride claim to be made in USA but I am sure they use some foreign parts. MY PTO driveshaft had a Chinese brand name booklet attached to it, so for sure it is Chinese even if other items are not which I have no way of knowing what else is imported. Just like other brands of tillers, I am sure there are parts supplied by foreign companies. At least we do have some USA jobs being maintained when the major fabrication is done here in USA. Tarter, King Kutter, Howse and Landpride all claim USA manufacturer. I decided against Landpride because of the chain drive system. I don't know if it is really better or worse than gear drive but I selected gear drive for my use as that is what most brands tout as being the better system.
I didn't really like the Howse one as it looked pretty cheaply made with an open drive shaft from the PTO gear box to the side gear drive, perhaps this was to facilitate the easy (relatively speaking) change to reverse rotation. No one around here stocks the reverse rotation, possibly due to our rocky soil in my area which may damage a reverse rotation shaft or at least the tines.
I have yet to test mine out as I am still waiting for the soil to dry out a bit AND the temps to get a little better.
I did like the Tartar video however I would have liked to see the shape the tiller blades was in after the demo chopping up CMU blocks. Surely any tiller would run over them, but without damage to the tines would be the thing to see. I did notice that when he dropped the shredder onto the steel bar that it was located so that it didn't hit the cutting edges, but impacted up middle ways between cutting edge and mounting bolts. Was this intentional to make one assume that their blades would chop steel and not damage them, most likely. Still OK torture test of the equipment to show it didn't break anything other than a shear bolt.
I thought the gate demo was pretty good though what with holding up a tractor, but the hay ring was a small failure seeing how it collapsed a bit.
/ Tillers; Why buy anything but County Line? #14
I did check pricing at my local NH dealer for a 5 foot tiller and it was $2500, about $1000 higher than I could find them at other places. I forget what they said the manufacturer was now when I asked back last summer, but I remember that it was one of the familiar ones like KK. Tractor dealers really are outrageously priced on their implements.
/ Tillers; Why buy anything but County Line? #15
I bought a 6' KK and love it. If you're a smart shopper, they run about $1500 new + tax. I have about 34 HP PTO, the 6' was rated 35-50HP so I wasn't sure… it was DEFINITELY the way to go. Even with my HARD clay soil it works the best and a 5' would have been too narrow.
I think the Tarter's are quite close to the KK's, would probably buy one of those too.
Wonder if anyone as attractive as Ann Tarter works over at KK… ;)
Thanks to everyone who replied! I have no problem paying a little extra for better service and supporting my local dealer. But $1000 is not a little money! I did a web search and found a tarter dealer about 6 miles away. I also know of a woods dealer not that far either. King Kutter dealer is a drive for me. I guess for now I'll just concentrate on getting the best deal on a tractor, and worry about a tiller this summer. I'll hint around it when I'm getting quotes, and if I get a great deal I may go for it. Thanks again.
/ Tillers; Why buy anything but County Line? #17
Wonder if anyone as attractive as Ann Tarter works over at KK… ;)[/QUOTE
The only ones I found for 1500 were on line and were charging about $400 shipping so ended up the same or more for the same tiller I could get locally at Atwoods. They had a 5 foot on sale last week for $1399 which is only $100 off normal sale price. I got the sale price (-$75) on my buy by asking for it even though the sale had expired last week. I was amazed that the 4 foot is about the same as a 5 foot and 6 foot is just a couple hundred more than a 5 foot. Each foot adds another row of tines and the KK has 6 tines per flange where some tillers only have 4 tines per flange. That is another thing to look at when selecting a brand. 6 tines will for sure run smoother than 4 and till better.
/ Tillers; Why buy anything but County Line? #19
If you want a reverse rotation tiller, you'll need something other than a KK.
I'm very happy with my Woods TCR68.
TC/TCR68 Landscape Equipment
According to their website, they recommend the reverse rotation tiller that they make over the forward rotation one. They make both types. Some brands of tillers are reversible by rotating the gear box (Howse is one of them) and changing the blade tine orientation which is a bit more work than I would want to do. I have not found any hard info from any tiller site that tells why one is better for use in certain circumstances. KK website just shows that reverse rotation does a better job of hiding the vegetation as shown in side by side comparison with two KK tillers and a competitors forward rotation tiller. I did find on TBN that someone said forward rotation was better on rocky soil which is what I have and when using them, they would climb up and over a large rock whereas a reverse tiller if it couldn't dig out the rock because it was too large, it would stall the machine, burn the slipclutch and/or break a tine if tractor continued pulling forward.
OTHER than rocks or stumps etc, is there other reasons for using a forward rotation tiller other than reverse.
On the Tarter tiller video, I think they were using a forward rotation tiller for their demo of chewing up CMU blocks.
/ Tillers; Why buy anything but County Line? #20
Last time I looked at TSC tillers the line they had there with the Country Line brand were made by Tarter
DITCH WITCH JT60 ALL TERRAIN HORIZONTAL BORING MACHINE (A60736)
DITCH WITCH JT60...
2025 Pabreak Auger Bits and Plate Skid Steer Attachment (A61567)
2025 Pabreak Auger...
2008 CAT 928H WHEEL LOADER (A60736)
2008 CAT 928H...
17102 (A56859)
17102 (A56859)
2010 Deere 318D (A60462)
2010 Deere 318D...
2012 MACK CHU (PINNACLE) (A60736)
2012 MACK CHU...
