Red Torin 20 ton shop press mod
/ Red Torin 20 ton shop press mod
I saw a neat modification to a press. A 1/4" cable down each side with a small winch ( like they have on boat trailers ) to move the table up and down. Sure looked easier than manually lifting to pin it in place.
It's really not that heavy; I lifted the table last night one side at a time. But will consider it. As promised The pics from the straightened plate using the press.
A link to the blade in action with the plate/sides on the rear blade
http://youtu.be/kBzL1rj2aVQ
Another small mod today.
Trying to keep heavy objects from falling on my feet once the platform with casters is built.
Just drilled the pins and put in 3/16 hitch pins.
Here is another I was thinking about mounting the handle somewhere then it came to me. Cut it and pin it in place where it can't be misplaced!
/ Red Torin 20 ton shop press mod #24
Here is what I did with my press
Replaced the hand pump with an OTC air/hyd pump
Made a table lift
Made a carrage to mount the hyd cyl on so I can move from left to right
Made new plates for the table, the cast ones that came with it exploded!! Lucky i did not get hurt .
/ Red Torin 20 ton shop press mod #25
Sorry I don't know why the pic is upside down
/ Red Torin 20 ton shop press mod #26
Great minds think alike, look at the base of the jack, I put a knob on mine. :thumbsup:
Here is what I did with my press Replaced the hand pump with an OTC air/hyd pump Made a table lift Made a carrage to mount the hyd cyl on so I can move from left to right Made new plates for the table, the cast ones that came with it exploded!! Lucky i did not get hurt . Next project to make a safety cage for the front of the press.<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=348505"/>
Looks good.
Did you fabricate the lift or buy it?
Do you find it necessary for a press this size?
Great minds think alike, look at the base of the jack, I put a knob on mine. :thumbsup: <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=348526"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=348527"/>
Xfaxman;
You really don't appreciate such a small mod until you use the press a little.
Having to search for the bar to tighten and loosen the valve gets long in a hurry!
Next should be the platform
/ Red Torin 20 ton shop press mod #29
I built the lift from scratch. It works real nice, very little effort to lift the table and the ratchet mechanism holds it I place when you move the pins.
I have a 3 ton arbor press for light work and the 10 ton is good for anything else I do.
/ Red Torin 20 ton shop press mod #30
As for your question if you need a lift for a small press. Yes, that way I don't have to remove everything from the table when I need to change the hight of the table.
Do I need it no, but I I love to design and build things .
As for your question if you need a lift for a small press. Yes, that way I don't have to remove everything from the table when I need to change the hight of the table. Do I need it no, but I I love to design and build things .
I wasn't judging as I also like to build/modify/design things. Great job on the lift design and build!
/ Red Torin 20 ton shop press mod #32
That is the main reason that I want to make one for mine! :thumbsup:
I have some garage door cable pulleys that I could use with your design.
Got a bit more work done on the shop press. Built a stand out of 1-1/2x3"x3/16 rectangular tubing. Used 2 4" casters fixed/no brake and tapped the 1/4" plate on the legs to accept 5/16-18 thread rubber feet. This will allow me to easily move the air/hydraulic press while adjusting for any uneven surfaces.
I am not a professional welder and am still figuring out my MM252; should have probably cleaned the rusty steel before welding-not after.
Next step paint black
Thanks for looking
Mounting the press to the stand.
/ Red Torin 20 ton shop press mod #35
Loookin gooder! :D
It sure is handy to move it away from the wall, for clearance when straightening bent long items. :thumbsup:
/ Red Torin 20 ton shop press mod #36
Where did you get those screw on rubber feets? Looks good. Im going to need to make something like that for my press.
Loookin gooder! :D It sure is handy to move it away from the wall, for clearance when straightening bent long items. :thumbsup:
Yup I was thinking more along the lines of getting it out of the way when not needed.
EBay seller; repairparts
$8.50 US funds free shipping for 4 5/16-16 threaded rubber isolator feet.
Could not buy them anywhere locally.
/ Red Torin 20 ton shop press mod #38
Cool thanks. I haven't seen anything like that in a hardware store.
/ Red Torin 20 ton shop press mod #40
Nice work!!
Terry
SET OF PALADIN JRB 60" PALLET FORKS (A52707)
SET OF PALADIN JRB...
25 DUAL AXLE GOOSENECK TRAILER (A58214)
25 DUAL AXLE...
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
1995 Peterbilt 379 Tri-Axle Dump Truck (A59230)
1995 Peterbilt 379...
2013 Chevrolet Silverado 1500 Pickup Truck (A59230)
2013 Chevrolet...
Case SV280B (A60462)
