Red Torin 20 ton shop press mod
   / Red Torin 20 ton shop press mod
I saw a neat modification to a press. A 1/4" cable down each side with a small winch ( like they have on boat trailers ) to move the table up and down. Sure looked easier than manually lifting to pin it in place.
It's really not that heavy; I lifted the table last night one side at a time. But will consider it. As promised The pics from the straightened plate using the press.
A link to the blade in action with the plate/sides on the rear blade
http://youtu.be/kBzL1rj2aVQ
Another small mod today.
Trying to keep heavy objects from falling on my feet once the platform with casters is built.
Just drilled the pins and put in 3/16 hitch pins.
Here is another I was thinking about mounting the handle somewhere then it came to me. Cut it and pin it in place where it can't be misplaced!
   / Red Torin 20 ton shop press mod #24
Here is what I did with my press
Replaced the hand pump with an OTC air/hyd pump
Made a table lift
Made a carrage to mount the hyd cyl on so I can move from left to right
Made new plates for the table, the cast ones that came with it exploded!! Lucky i did not get hurt .
   / Red Torin 20 ton shop press mod #25
Sorry I don't know why the pic is upside down
   / Red Torin 20 ton shop press mod #26
Great minds think alike, look at the base of the jack, I put a knob on mine. :thumbsup:
Here is what I did with my press Replaced the hand pump with an OTC air/hyd pump Made a table lift Made a carrage to mount the hyd cyl on so I can move from left to right Made new plates for the table, the cast ones that came with it exploded!! Lucky i did not get hurt . Next project to make a safety cage for the front of the press.<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=348505"/>
Looks good.
Did you fabricate the lift or buy it?
Do you find it necessary for a press this size?
Great minds think alike, look at the base of the jack, I put a knob on mine. :thumbsup: <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=348526"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=348527"/>
Xfaxman;
You really don't appreciate such a small mod until you use the press a little.
Having to search for the bar to tighten and loosen the valve gets long in a hurry!
Next should be the platform
   / Red Torin 20 ton shop press mod #29
I built the lift from scratch. It works real nice, very little effort to lift the table and the ratchet mechanism holds it I place when you move the pins.
I have a 3 ton arbor press for light work and the 10 ton is good for anything else I do.
   / Red Torin 20 ton shop press mod #30
As for your question if you need a lift for a small press. Yes, that way I don't have to remove everything from the table when I need to change the hight of the table.
Do I need it no, but I I love to design and build things .
2012 Dixie Chopper Magnum 2460 60in Zero Turn Commercial Mower (A59228)
2012 Dixie Chopper...
2012 International 4300 Reefer Truck (A56438)
2012 International...
(INOP) 2019 KUBOTA SVL 95-2S SKID STEER (A52707)
(INOP) 2019 KUBOTA...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A59905)
2018 INTERNATIONAL...
2003 STERLING LT9500 SERIES DAYCAB (A58214)
2003 STERLING...
2022 Brush Wolf 7800-HF Skid Steer Brush Cutter (A56438)
2022 Brush Wolf...
