Red Torin 20 ton shop press mod
/ Red Torin 20 ton shop press mod
As for your question if you need a lift for a small press. Yes, that way I don't have to remove everything from the table when I need to change the hight of the table. Do I need it no, but I I love to design and build things .
I wasn't judging as I also like to build/modify/design things. Great job on the lift design and build!
/ Red Torin 20 ton shop press mod #32
That is the main reason that I want to make one for mine! :thumbsup:
I have some garage door cable pulleys that I could use with your design.
Got a bit more work done on the shop press. Built a stand out of 1-1/2x3"x3/16 rectangular tubing. Used 2 4" casters fixed/no brake and tapped the 1/4" plate on the legs to accept 5/16-18 thread rubber feet. This will allow me to easily move the air/hydraulic press while adjusting for any uneven surfaces.
I am not a professional welder and am still figuring out my MM252; should have probably cleaned the rusty steel before welding-not after.
Next step paint black
Thanks for looking
Mounting the press to the stand.
/ Red Torin 20 ton shop press mod #35
Loookin gooder! :D
It sure is handy to move it away from the wall, for clearance when straightening bent long items. :thumbsup:
/ Red Torin 20 ton shop press mod #36
Where did you get those screw on rubber feets? Looks good. Im going to need to make something like that for my press.
Loookin gooder! :D It sure is handy to move it away from the wall, for clearance when straightening bent long items. :thumbsup:
Yup I was thinking more along the lines of getting it out of the way when not needed.
EBay seller; repairparts
$8.50 US funds free shipping for 4 5/16-16 threaded rubber isolator feet.
Could not buy them anywhere locally.
/ Red Torin 20 ton shop press mod #38
Cool thanks. I haven't seen anything like that in a hardware store.
/ Red Torin 20 ton shop press mod #40
Nice work!!
Terry
2007 Ford F-150 Ext. Cab Pickup Truck (A59230)
2007 Ford F-150...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
2015 Caterpillar Backhoe (A60352)
2015 Caterpillar...
2004 Ford F-250 Ext. Cab Service Truck w/ Liftgate (A59230)
2004 Ford F-250...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
2012 Mini Cooper Coupe (A59231)
2012 Mini Cooper...
