Tractor Seabee
Elite Member
- Joined
- Oct 5, 2011
- Messages
- 3,911
- Tractor
- Kubota BX25
A friend of mine used to do tank pumping. He said he needed at least a 6-8" opening to get his stiff pumper hose into the tank. The hose has to go all the way to the bottom. For an adequate inspection procedure a manhole size opening is required. He said on older tanks in order to do the certified inspection sometimes they had to remove to whole tank lid if constructed prior to the requirement for manholes. Your MD codes must be different than out here in the peoples states on the west coast. Out here the ordinances require pumping and inspection every 3 years whether they need it or not. That is heavily ignored but catches up when you sell your property as a pump-out and inspection is required as part of the seller disclosure process. If you have an original certification for a 2 bedroom house and you have bootlegged another BR or two; then a new permit and complete new installation compliant with current use and codes all at the sellers cost. Oh for the good ole days when your house was your castle.
Ron
Ron
