snow removal help
/ snow removal help #1
firecat6
st. cloud , mn
none
Hi everyone I'm new to the forum. I'm looking to buy a compact tractor for snow removal and mowing lawn in the summer. I have a long driveway about 1500 feet how big of a tractor and a blower would be the best for this I would like to use a front mount blower. Does anybody have experience with these? do they work good or should I get a plow on my pickup instead? I'm currently looking at a used new holland tc33 it has a 72inch belly mount mower and a fel but I would have to buy a blower for it. Would this tractor be big enough or should I go bigger? I don't want to spend all day blowing my driveway.
/ snow removal help #2
Welcome!
When sizing a tractor you should start with the applications first, then pick the implements, then choose a tractor "one size up" from that. You mentioned a 1500' driveway and a preference for a front mount blower. I also noticed you are located in Minnesota. Since you probably get more than your fair share of snow there and likely have to deal with snow drifts as well, a blower is practically a must. With a plow, you are more limited on the depth of snow you can move at one time and you may run out of places to put it as the season drags on. A front mount blower is the Cadillac option, but with a 1500' drive and fairly frequent snow removal, it is probably money well spent. How wide is your drive? Assuming a nominal 9'-10' width, a 72" blower will allow you to clear full width in two passes no problem. 60" may be cutting it close since you will need some overlap. Is your drive gravel or paved? That will dictate your equipment setup and technique.
How big is the area you want to mow? Lawn or field grass? Hilly or flat? Open or full of obstacles? How often do you mow? Those answers will help determine what type and size mower you need. Your tractor mounted options are a belly mower, rear finish mower, flail mower, or rotary cutter. Keep in mind, a dedicated zero turn mower is hard to beat, but its a second machine and they can be expensive.
/ snow removal help
Thanks the reply acedeuce your right drifting is an issue that is the main reason I want a blower I currently plow with a pickup and it doesn't work well with large snows and drifting. driveway is gravel 12' wide. As far as mowing its about 5acres of lawn mostly flat and open but the slopes on the drive do get steep currently do it with a garden tractor. I have tried my friends zero turn it does work sweet but I would like to just have one machine for everything and not have to have a plow on my truck.
/ snow removal help #4
i have a loader mount blower and it works great on my 45 HP tractor. But i had to get a rear pto powered hydraulic powerplant to power it up. They do make units that mount to the front of a tractor AFTER you remove the entire loader assembly, but i didnt want that. i want to be able to swap out the plow or blower or bucket in a few minutes, and thats what i have.
The kind that mounts inplace of the loader uses a shaft and gearbox that attaches to the rear PTO....OR if your tractor had a foreward facing mid pto thay have units that attach to those.
Both of these options cost $$$
A rear mount snowblower is way cheaper.
/ snow removal help #5
There are a lot of good choices that can do those jobs for you. I'd want at least a 48" front blower with a soft cab so perhaps something about 20 HP. And a 20 HP tractor will certainly carry enough mower for that much lawn. Of course as it's not my money I'd go bigger and wider, maybe a 60 HP utility tractor with factory cab and an eight foot blower with rear pump and tank to get it in just one pass up and back. Might be a little tough on the sod when mowing though.
Have fun shopping and reseaching before you buy.
/ snow removal help #6
Welcome!
A lot of the members have and use garden tractors with front blowers
on long driveways that are paver or simply gravel.
With a front or rear mount snow blower your going to want to let
the snow on the ground freeze if possible to have a good base.
Many of us use wheels bolted to the snow blower body to avoid gouging and
I have not put mine on my front mount yet ;^0
As you have said you time is a concern but you have to decide how much
money you can spend before you do anything
Many of us have monster drive ways and small mules with either front or a rear blower.
Growing up I used a 12 horse cub cadet with a single stage snow blower and it
had a hydro transmission and chains and we had a huge driveway with pavement
on a hill and it worked great.
The kubotas with the hard cabs- B3030 etc can use a front blower and a mid mount mower in one example
you can put a hard cab on a BX2360 and use a mid mount mowr and a front blower but you talking north of 13,000 +-
As it is snow season already the issue is going to be availability and unless a dealer has hoarded front mount snow blowers they will be nearly impossible to find versus a rear mount and a tractor with a hydrostatic transmission
The horse power and acreage recommedations are just that period.
I would ask your neighbors what they use before I spend any money
or at least buy a used one with afrint blower from a dealer and see how the winter goes.
You will want a cab after the first winter though if you buy a used one with out a cab.
Check with your neighbors and see what they use before you make a decision THAT MAY HAUNT YOU!!!
/ snow removal help #7
/ snow removal help #8
A new JD X530 will run a 47" front mount blower and sports a 54" mower deck for about 10K$ Or you could go for JD 2032R 24 HP tractor with a 54" front mounted snow blower and a 72" mid mount mower deck and spend $25K before you get to a soft cab. Lots of competition in lots of other colors so it comes down to how much the OP wants to spend and how long he wants to be in the seat each storm.
/ snow removal help
Looking to buy something used around 15k I think a garden tractor would to small would be fine for mowing but would take to long to blow driveway
/ snow removal help #10
Here is my tc33d blowing through a dense drift. I had to creep pretty slow for this much snow. I ended up getting the neighbor with the end loader because it was taking way too long. The blower is a 5' Lorenz and works good. I usually use a back blade because it is much quicker with the smaller snows. snowblower1.jpgendloader.jpg
/ snow removal help #11
About how much snow do you get year?
Drifting snow problem?
If went to plow truck setup there enough room to keep banks push back?
Front or rear blower?
/ snow removal help #12
The tractor you are looking at is more than capable of clearing your driveway and mowing. A plow for your truck would be much cheaper if price matters but that won't be any help mowing. A front mount blower is definitely more expensive than a 3 pt. and has the advantage of not having to drive in reverse. You could also look for a plow blade set up for the tractor.
/ snow removal help #13
The tc33 the OP mentioned would certainly work well but I would take the belly mower off during the winter. It's just going to get in the way. The FEL and PTO is the only issue with a front mount. A rear 3ph mount will be half the price and allow the FEL to stay on for stacking snow and other chores. Front mount is much easier to handle (and on the neck) but it all depends on how much you want to spend. Regardless, I wouldn't go much bigger than 5' with the blower though. With a 6' unit, a tc33 would probably have enough power to handle small snows but deep and/or heavy wet snow, or packed drifts will quickly overwelhm that sized tractor.
/ snow removal help
How much is a tc33da worth with a mid mount mower fel and a backblade
/ snow removal help #16
I run a Lorenz 72" on my TC25D. The hydro trans helps out a lot as I can better control the speed at which the blower is fed. I wouldn't mind the 33 engine but the 25 gets the job done.
SEARS SUBURBAN SIX SPEED (A62131)
SEARS SUBURBAN SIX...
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
(2) Good Year 16.9-24 Rear Tractor Tires (Turf) (A61166)
(2) Good Year...
UNUSED WOLVERINE MAD-12-12D 12" MINI HYD AUGER (A62131)
UNUSED WOLVERINE...
John Deere 4650 Tractor (A64047)
John Deere 4650...
TAKEUCHI-VIRNIG TRRG72 - 72" HYD ROOT RAKE GRAPPLE (A62129)
TAKEUCHI-VIRNIG...
