Mowing GCD600T Grass Collector
/ GCD600T Grass Collector #1
Mavericksane
Taunton, UK
Kubota B2530HDB
Hi - I'm a novice owner of a (lightly used) Kubota B2530 which came with a GCD600T grass collector attached to its side-discharge mowing deck. I'm having problems getting the collector off the three-point hitch - the hitch doesn't appear to drop far enough to let the collector rest on its stands. What am I doing wrong?
Cheers, Mark
/ GCD600T Grass Collector #2
Hi - I'm a novice owner of a (lightly used) Kubota B2530 which came with a GCD600T grass collector attached to its side-discharge mowing deck. I'm having problems getting the collector off the three-point hitch - the hitch doesn't appear to drop far enough to let the collector rest on its stands. What am I doing wrong? Cheers, Mark
Does your model have a mowing deck hight adjustment? If so maybe try setting that all the way down to zero and the hitch should go farther down. On the BX series it's a knob on the left side below the seat.
Good luck!
Sent from my iPad using TractorByNet
Good luck!
Hi Bob
Thanks for your reply. I eventually figured out that the hitch was being prevented from dropping all the way by some "safety" chains which attached between the grass collector and the tractor. Once I removed those (they were slack when the hitch was fully raised), I was able to drop the hitch further and - eventually - disconnect the hitch. My next challenge is disconnecting the PTO from the tractor!
Cheers, Mark
2025 Pabreak Hydraulic Brush Cutter Skid Steer Attachment (A61567)
2025 Pabreak...
2006 STERLING ACTERRA CAB & CHASSIS (A60736)
2006 STERLING...
UNUSED INDUSTRIAS AMERICA 160R-16' SCRAPER BLADE (A62130)
UNUSED INDUSTRIAS...
2R FALLING PLOW (A62131)
2R FALLING PLOW...
2017 Ford Escape SUV (A61569)
2017 Ford Escape...
2008 Ford Ranger Pickup Truck (A61568)
2008 Ford Ranger...
