Mowing GCD600T Grass Collector
/ GCD600T Grass Collector #1
Mavericksane
Taunton, UK
Kubota B2530HDB
Hi - I'm a novice owner of a (lightly used) Kubota B2530 which came with a GCD600T grass collector attached to its side-discharge mowing deck. I'm having problems getting the collector off the three-point hitch - the hitch doesn't appear to drop far enough to let the collector rest on its stands. What am I doing wrong?
Cheers, Mark
/ GCD600T Grass Collector #2
Hi - I'm a novice owner of a (lightly used) Kubota B2530 which came with a GCD600T grass collector attached to its side-discharge mowing deck. I'm having problems getting the collector off the three-point hitch - the hitch doesn't appear to drop far enough to let the collector rest on its stands. What am I doing wrong? Cheers, Mark
Does your model have a mowing deck hight adjustment? If so maybe try setting that all the way down to zero and the hitch should go farther down. On the BX series it's a knob on the left side below the seat.
Good luck!
Sent from my iPad using TractorByNet
Good luck!
Hi Bob
Thanks for your reply. I eventually figured out that the hitch was being prevented from dropping all the way by some "safety" chains which attached between the grass collector and the tractor. Once I removed those (they were slack when the hitch was fully raised), I was able to drop the hitch further and - eventually - disconnect the hitch. My next challenge is disconnecting the PTO from the tractor!
Cheers, Mark
Ford F-450 (A63689)
Ford F-450 (A63689)
New/Unused 3 Point Receiver Hitch (A65583)
New/Unused 3 Point...
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
2003 NOBLE 12000 GALLON WATER TOWER TRAILER (A65054)
2003 NOBLE 12000...
2019 K&K Trailer, VIN # 1K9PE2029KA175462 (A65563)
2019 K&K Trailer...
John Deere 660 Hay Rake (A66408)
John Deere 660 Hay...
