Mowing GCD600T Grass Collector
/ GCD600T Grass Collector #1
Mavericksane
Taunton, UK
Kubota B2530HDB
Hi - I'm a novice owner of a (lightly used) Kubota B2530 which came with a GCD600T grass collector attached to its side-discharge mowing deck. I'm having problems getting the collector off the three-point hitch - the hitch doesn't appear to drop far enough to let the collector rest on its stands. What am I doing wrong?
Cheers, Mark
/ GCD600T Grass Collector #2
Hi - I'm a novice owner of a (lightly used) Kubota B2530 which came with a GCD600T grass collector attached to its side-discharge mowing deck. I'm having problems getting the collector off the three-point hitch - the hitch doesn't appear to drop far enough to let the collector rest on its stands. What am I doing wrong? Cheers, Mark
Does your model have a mowing deck hight adjustment? If so maybe try setting that all the way down to zero and the hitch should go farther down. On the BX series it's a knob on the left side below the seat.
Good luck!
Sent from my iPad using TractorByNet
Good luck!
Hi Bob
Thanks for your reply. I eventually figured out that the hitch was being prevented from dropping all the way by some "safety" chains which attached between the grass collector and the tractor. Once I removed those (they were slack when the hitch was fully raised), I was able to drop the hitch further and - eventually - disconnect the hitch. My next challenge is disconnecting the PTO from the tractor!
Cheers, Mark
2021 UTILITY VS2DX 53FT DRY VAN TRAILER (A59905)
2021 UTILITY VS2DX...
UNUSED INDUSTRIAS AMERICA F12T HYD TILT LAND LEVEL (A62130)
UNUSED INDUSTRIAS...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2019 Mitsubishi Mirage G4 Sedan (A61569)
2019 Mitsubishi...
2018 CATERPILLAR 315FL CR EXCAVATOR (A62129)
2018 CATERPILLAR...
(2) 460/85R42 TIRES W/8 LUG RIMS (A62130)
(2) 460/85R42...
