Claytonfarms
Member
I am having a new septic system installed, some of the things the installer is doing do not make sense to me so I have a couple of questions.
By the way our county would not let me install the system, I had to have a licensed installer do the work but I do not think he knows what he is doing.
First the inlet and outlet on the tank, the tank came with rubber boots and clamps for the pipes the boots were pushed into the tank when it was delivered. He did not use these. He left the boots on the inside and filled the outside with some type of cement, no clamps on the boots. After 3 days, the cement has cracked and is falling out.
Next the tank has 2 manhole covers. On the outlet end he did not put a riser on the manhole, he cut a hole in the manhole cover and put a 6" diameter extension pipe to above grade. The extension pipe is glued to the outlet tee so neither the pipe or the manhole cover can be removed but it is loose since the cement is falling out. By the way neither of the manhole covers are sealed to the tank. It is a 2 chamber tank with no other access to the outlet chamber except the 6" diameter pipe and the tank is 2' below grade. The inlet has no riser currently.
Last but not least we have clay soil where the tank is. We have had rain for 2 days since the tank was installed and partially backfilled.When I went there today there are streams of water coming thru the side walls 3 feet below grade and 1 foot below the tank, the water is filling the hole almost a foot deep. The backfill is so saturated I can push a 2x4 5' into the fill by hand. I did pump the water from around the tank into the tank so hopefully it will not float.
The county was there 3 days ago and said everything looked good and they passed the system.
So my questions are: Should I be concerned about the connections at the tank? Am I going to run into problems with the current outlet tee / manhole setup? Will the runoff water be a problem after the tank is completely backfilled and covered? I plan to live there for the next 10 - 15 years and I do not want any problems that could be fixed or prevented now.
Thanks in advance.
Thanks in advance.
