chain saw , saw chain sharpening
/ chain saw , saw chain sharpening #1
Den1952
Weyauwega Wi
InternationalHarvestor tlh
I made these two jigs for sharpening the saw chain.
the first 3 pics is a clamp to hold the spare chain. the chain itself gets clamped in the jig. the jig itself gets mounted into the bench vice.
the last 2 pics are for a stump vice that I made, for touching up the chain mounted on the saw. (parked on a convenient stump or log)
I didn't want the hassle of having to mount the spare chain into the saw for filing, this jig does work nicely. there are 3 moveable insets which clamp onto the drive tangs of the saw. loosen them up and slide the chain forward, and tighten them up.
I am surprised that I could not find a store bought jig for this purpose anywhere. for the loose spare chain that is.
/ chain saw , saw chain sharpening #2
Looks like a winner!
/ chain saw , saw chain sharpening #3
Interesting.:thumbsup:
I just use a c clamp on the bar when at home. Out in the field a piece of branch or whatever has to do.
I just use a c clamp on the bar when at home. .
I don't quite understand how a c clamp will anchor a loose-spare chain. the jig I was primarily interested in was to prevent having to swap chains on the saw just to sharpen it. this way I can touch up the one on the saw but also do any loose spares that need it.
/ chain saw , saw chain sharpening #5
That is a very nice jig you made...
I don't cut a lot of wood anymore but did in the past for home heating...
My daddy sold old Homelites back in the day...
He taught me how to sharpen a chain with just a file and no jig...
Couple years ago I went and bought one of those cheap harbor freight sharpeners for like $30...
If I was cutting a lot of wood I would keep 4 or so chains sharpened and ready to go before going to the woods...
Those grinders work well it is real easy to sharpen a chain too much with them...
Nice job...
I like filing also. I have nothing against the electric grinder machine sharpeners. my only complaint about those is , if you take it in somewhere to be sharpened, the guy absolutely insists that all of the teeth will be ground down until it matches the length of the shortest cutter. I always think that is a waste of lots of good teeth.
now that you mention the $30 grinder,, my son just bought one, it seems to do an excellent job of sharpening, however it came furnished with only one stone wheel, an 1/8" radius. we cannot find info about, which size stone wheel to use with different sizes chain. or if the radius of the stone is the same as the diameter of a file recommended for various size chain.
there are times the occasional sharpening with a machine is great for reestablishing the proper angle, same on all teeth. with hand filing it is possible to occasionally drift from the proper angle on some of the teeth.
/ chain saw , saw chain sharpening #7
Nice work on the stump vise. I just bring along extra chains and sharpen them with my grinder when I get home.
has anyone a chart for determining which grinder stone to use on various size chain teeth?
/ chain saw , saw chain sharpening #9
Nice jig! Suggestion: replace the bolts with 'toggle clamps' Much faster than loosening/tightening bolts.
MSI 12130 Vertical Quick-Release Toggle Clamps - Amazon.com
I have thought of (but never built) similar jigs and those toggles are the greatest. I used lots of them when I ran the drill presses in a fertilizer equipment manufacturing shop. They come in all types of configurations nd I could always find one where the handle moved in the right way for a jig.
Harry K
thanks for that tip. so far these 3 clamp locations need the allen wrench to work. actually a 1/4 turn is sufficient, so I had thought about welding an allen wrench to the screws.
I can see where toggle bolts would be nicer, if I can locate the perfect configuration.
/ chain saw , saw chain sharpening #11
Harry if you have a Menard's close to you the toggle clamps are about half the price. They are real handy for making all kinds of jigs.
2016 Nissan Titan XD Crew Cab Pickup Truck (A61573)
2016 Nissan Titan...
2025 Swict 78in Tooth Bucket Skid Steer Attachment (A66734)
2025 Swict 78in...
2003 VOLVO G720B MOTOR GRADER (A66091)
2003 VOLVO G720B...
2023 Del Morino Funny 132M Hydraulic Flail Mower Attachment (A66734)
2023 Del Morino...
2021 PETERBILT 367 (A67714)
2021 PETERBILT 367...
KENWORTH ROAD TRACTOR (A65053)
KENWORTH ROAD...
