Midniteoyl
Super Member
- Joined
- May 20, 2013
- Messages
- 5,222
- Location
- N. W. Indiana
- Tractor
- Kioti CK3510SE HST, Ford 3400, Gizmow ZTR, Simplicity 7016H
The outcome after the first of the year.
Honey, I'm going to plow the field!
Done!
Couldn't have said it better myself, Poopy... I mean Pappy!I'm one of those. I don't have anything to contribute, but I'm fascinated by the process. I can't decide if it's like watching a train wreck or a great invention in the works. I guess time will tell.
I don't have the knowledge or tenacity to attempt something like this, and I admire Fred for having both.
I had to watch that video twice! What a hoot! :hot: Go Fred!!!Honey, I'm going to plow the field!
Done!
If you end up destroying the panel, the one for the other side (right) of my 4240 was $156.27 from Messicks. I'm sure the left side is close to that. It comes painted by the way.
I see Fred is using the "pastie" of the VIN world!
Or was it a poor masking job in preparation for a new paint job?
Thats the same banjo bolt my 5740 has and the turbo is still turning on it. There will be a lot of oil come from that at 60 psi!
Dos Equis. "I don't always complain about my tractor's horsepower. But when I do, I put a turbo on it." The most Interesting Tractor Owner In The World.
Kuboman could you pull it to verify hole size? I know it's a lot to ask. I work on so many turbo cars (mostly euro stuff) that has full holes through the banjo bolts, all the restriction is through the turbo plate/orifice.
I have pix just can not believe the orifice would be there and not in the turbo itself. 1.5mm hole is TINY! This is a single 1.5mm hole, not even drilled all the way through the udder side. Just one hole.
Thanks! Fred
Right. I noticed the naysayers are starting to be outnumbered by us Fred fans. I appreciate the work of the entrepreneurial members on this forum.
Fred, sorry to hear this. I've got the same tractor and overall I'm pleased with it. I've only got about 35 hrs on it so far though. I've mainly ran two implements so far, a 6 ft new Landpride cutter and an older 6 ft extremely heavy duty 35 series box blade. The box blade alone weighs roughly 1300 pounds. Believe me, loaded with dirt, it's a load.
At first, like you, I was disappointed in the power. But I'm figuring out how to use the HST+ to maximize power vs speed. I too live in a hilly terrain area and usually find myself in L gear when working an implement. I've also found when cutting tall grass or climbing hills when cutting tall grass it's best to disengage the throttle auto advancing feature and set the engine RPM to match 540 ish PTO speed. From there you can control the ground speed using the foot control or the cruise control lever. Depending on what I'm doing, for example mowing a large field or grading a long drive, I use the cruise lever. Using my left hand to control the ground speed gives me quite a bit of control, after I got used to it. I still leave Stall Guard activated, so if I hit tall thick grass suddenly, it just slows down.
I mowed the same 25 acre field with this tractor with 105 degree temps outside, air blasting, within 10 minutes of my best time on a 70 hp tractor. Ran the RPMs up manually, used cruise. Worked great. Someone recommended the DK-40. This would be a similar method of running that tractor. I've spent some time on a DK-40 cab too, I like the Kubota.
As to cold starts, I've never tried to start it using one cycle below 25 degrees or so. I always cycle twice below 25 degrees. Old habit starting a Ford 3000 Diesel. But, with two cycles mine fires right up even down around zero.
I have noticed, like you, that operating the FEL while moving can cause the a jerk in motion. I'm assuming that the HST needs hydraulic pressure to operate. Using the loader will cause a sudden drop in pressure. Of course the severity would depend on the pumps ability to recover, which, in this case, depends on RPM. Remember that using the throttle advance and the foot feed basically matches the engine RPM to the current load, nothing more. Other HST equipment I've ran has similar
results, unless it has two pumps. With other tractors, like the DK -40 for example, if you match the same conditions you will get similar results. That being said, I think the loader is a bit weak. But it really isn't causing the problem.
Without comparing your tractor to mine, from the seats, it's hard to tell. But, it sounds like you have something wrong. I'd call Kubota directly and see what they say.
I believe that is because there are really two separate issues:
1. Is the L3940 truly a "gutless wonder" or is there something wrong with this tractor?
2. Will adding a turbo increase power?
In reading the reviews and knowing someone who owns an identical tractor, no one reports the problems described in this and other threads. So many advocate making sure there are no underlying problems.
Adding a turbo has been used for years and is accepted as a good way to produce more power, so no real arguments there, just that adding a turbo will only enhance performance not fix an existing problem.
There appears to be several layers to this.
