Using a CUT when building foundations/septic
/ Using a CUT when building foundations/septic #1
dochockin
Member
Merville, BC
Kubota B2920
I'm seriously considering getting a 25-30 HP CUT (Kubota, for geographic reasons) without a backhoe. We live on 5 acres, and are allowed to build a second home, which we'd like to do for rental income. One path I'm considering is purchasing a recycled house that will moved on to the property.
I'm wondering how viable it would be for me to use a CUT to reduce the amount of money I would spend on having a foundation/slab/septic built for a new house?
Obviously, serious excavation would require a serious excavator. I'm wondering if doing some preliminary or finishing work might save me some cash, and if so, approximately what percentage?
Thanks!
/ Using a CUT when building foundations/septic #2
Well, it is going to be impossible to give you a specific answer regarding the percentage you'll save. In fact, some contractors won't even want the work unless they are doing the dirt work, because they don't want their schedule to be dictated by another contractor, much less a rookie.
/ Using a CUT when building foundations/septic #3
I'm nearing the end of building a 40x64 shop/barn, and while the tractors have been handy, probably haven't saved me much money. I spread a lot of sand around before we poured the slab, and I did a lot of backfill work after the foundation was poured, as well as spreading gravel after both, but those jobs were mostly tracked in hours, not days. I did most of that work to save time, rather than save money...40 tons of gravel, Sunday afternoon...done. Otherwise, it wouldn't have moved until Monday, and every day you add seems to get compounded near the end.
The primary work of digging the trenches for the foundation, moving fill, etc was all done with an excavator, a skid steer, and a full-size backhoe. My neighbor came over with his backhoe when I was spreading gravel one time, and his bucket moved like four times what my LS does...no comparison. He helped me for maybe half an hour, and did as much work as I had done in probably two hours prior.
Don't get me wrong, it's been very handy having a couple of tractors to help out, and probably saved a good bit of time when everything is added up, but I don't know that it has saved me a lot of money...some, for sure, but not much.
Since everybody loves pictures, this was this morning before the steel was hung on the left side. We should have the rest of the steel up in the next few days, and I'm hoping the overhead door folks might be early next week before Christmas...we'll see.
/ Using a CUT when building foundations/septic #4
Did you have a contractor, or did you GC the job yourself?
/ Using a CUT when building foundations/septic #5
I would say to go ahead and get your CUT. But hire out the real big jobs especially if they are in the critical path to get the overall project of building the house done. You of course could still use your CUT during the build but I think you should rather be mainly considering it for your use in the long term. Depending on your contractor/build situation, as RockKnocker keenly pointed out... your plan of 'CUTing' corners might not work at all. But that said, I have no doubt your machine could physically do the job (but I would add the BH) if time and coordination with any contractors isn't a concern. :2cents:
/ Using a CUT when building foundations/septic #6
I did the GC with a lot of help from my two neighbors who have done a number of similar projects. It's been a huge learning experience!
/ Using a CUT when building foundations/septic #7
And that is possibly a different scenario than the OP might have wanted to do. I am assuming that he wanted to hire a GC, and then self perform work to save money. When you are your own GC, it all on you. You cut the grade, and when the foundation guy shows up and you're wrong, the back charge meter starts.
Currently there is no job, I'm just exploring how possible it might be, since I really have no idea yet how tough and capable CUTs are. The recycled house moving company claims they can deliver before a foundation is even built, and that it takes about 2-3 months from sale until delivery. Obviously exact percentages aren't possible to know. I'm just wondering if I could do enough of the work myself to make it worthwhile, or if I'd be wasting my time.
A BH is not in the cards; too expensive and I can rent one for fairly cheap... even the dealer told me the little CUT BHs aren't really worth it (unless money is no object) since a rental one is so much more efficient.
As for GManBart's neighbour's machine being four times faster, well, I don't have any friendly neighbours with large machines. I'd have to pay someone to show up and around here they charge transport fees, unloading fees... I talked to one guy this summer with a Kubota BX about mowing my pasture. He wanted $60/hr and $60 just to show up. I have big chunks of time off with my job, so spending a few days and saving $100s... works for me.
So if we ignore time spent and ignore interfacing with contractors... I'm wondering how much of the job a CUT could handle, given that my site is fairly flat pasture. I'm assuming that I can dig 2 foot trenches, level areas, backfill, spread materials, pretty much everything other than excavating deep holes.
And GMan, that's a sweet 'shed'
/ Using a CUT when building foundations/septic #9
That certainly could be the case. I don't think my machines saved me much money, but may have sped things along a bit. For example, there was one day my concrete guy was laying in the forms (it was a Sat, so I helped) and the skid steer was busy doing something else, so I started delivering the forms to them in stacks, rather than have them carry one at a time.
/ Using a CUT when building foundations/septic #10
Been there, done that! I GC'd my first house because I thought it would be easy since I designed it. The coordination and importance of relationships with reliable 'subs' was something I greatly underestimated.
/ Using a CUT when building foundations/septic #11
Sometimes you need to hire out but now I do most of the work myself except when it comes to hauling lots of material. As an example my house addition and 2 machine sheds are all built on slabs. I spent way more time than a contractor would getting the gravel spread and compacted just the way I wanted it, leveled to a gnat's eyeball. The time I spent would drive a contractor crazy and also drive cost but having time available (both my wife's and mine) I could do it. I did investigate contractors before I started first construction in 2002 when I bought this place from my father. Now I wish that at that time I had more time than money because their work needs tweaking. Do whatever you can yourself. You're the one who has to live with it and the trend is to do more quality work.
/ Using a CUT when building foundations/septic #12
Yep time and the right tools is most of the equation. The rest is knowing what the heck you are doing. Experience goes a long way in reducing time.
/ Using a CUT when building foundations/septic #13
A CUT should do all of that, but the trenches might be wider than you want/need...it's not always easy to cut a trench from the side with a scoop bucket. Have you thought about whether you'd do a trench footing, or formed? A tooth bar will definitely help the bucket cut, and dig.
Thanks....it's finally showing real progress!
I'm looking at a few FEL implements: tooth bars, rachet rake, rip and dig, pallet fork 'shovel'. I'm still trying to decide how much some of these might overlap. I'm also going to be digging ponds (I hope) and planting plenty of fruit and nut trees over time, so all of these implements should come in handy for multiple uses.
As for wider trenches... well if that part of the operation won't work... so be it.
/ Using a CUT when building foundations/septic #15
Digging 2ft trenches with your FEL won't be nearly as easy and clean as with a BH. Whether you rent, hire, or buy, I think you will almost assuredly need a BH/excavator. I assume you are talking about buried water/power line ditches? Yes a BH is a bit of a luxury long term but I am finding it very useful in my landscaping projects on my 1.5 acre (lots of slope). At worst it is a great counterweight for your FEL... just kidding :laughing: The FEL on a CUT is not a powerful digging machine compared to a BH but adding a tooth bar changes that greatly. Stumps and ditches make the BH worth it. Sorry... I know you said that was out of the question but just wanted you to give it a little more thought if you haven't done so already. Many folks here do without and once the 'big' jobs are done, might not use them much. BUT! If you do the site prep and ditching yourself, then the BH seems almost a must to me.
/ Using a CUT when building foundations/septic #16
.......I spent way more time than a contractor would getting the gravel spread and compacted just the way I wanted it, leveled to a gnat's eyeball. The time I spent would drive a contractor crazy .......
Maybe, maybe not. While you could have been out there with a old optical level and a ruler, contractors can have GPS or laser grading tools. You may think getting a perfect grade is onerous and entails getting on and off the machine a thousand times, it could be routine for a guy with all the gizmos that are common for professionals
/ Using a CUT when building foundations/septic #17
I don't find contractors here having laser and GPS equipped machinery if they are doing septic system and rural home sites. Sure if it was a multi-million dollar project. Then again let's take a centimeter accuracy GPS controlled dozer with an 8' blade. The blade will be spot on but that does not guarantee all the material across the span of the blade is evenly touching the blade, nor does it guarantee even compaction across that width. I had to redo part of my sewer line because the contractor screwed up slightly on the grade in part of a 120 foot run and I ended up with a frozen sewer line my first 2 winters. By then I had my own mini-excavator and laser so I could correct the job. If a person has the proper tools to do a job, although they may take more time than a large contractor, they are able to do the job as well or better.
/ Using a CUT when building foundations/septic #18
I see dirt guys doing foundation work using lasers, whether a SFR or a monstrosity of a type V multi-use building
/ Using a CUT when building foundations/septic #19
I am building up a laser set up for my tractor and box blade currently. Very few building contractors in my area who have used more than a rotating laser with a stick. I hope that having automatic machine control will help, we will see. Building a good roller too that is about 400 lbs/ft since you have to have firm ground to know what you have.
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
2001 Kubota L3300F...
6 1/4 INCH OD 90 DEGREE ELBOWS (A65643)
6 1/4 INCH OD 90...
Vermeer S540TX (A64126)
Vermeer S540TX...
2024 JCB 35Z-1 EXCAVATOR (A65053)
2024 JCB 35Z-1...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
2018 ALLMAND MP40-8B1 PORTABLE (3) PHASE GENERATOR (A63276)
2018 ALLMAND...
