Pole building foundation question
/ Pole building foundation question #61
Back to compaction,
I've never seen a roller on tracks.
You realize a tractor also has big wheels to reduce ground compaction. Anything short of a vibratory roller is a compromise. A tracked skid steer will compact equally as good if not better than a tractor rolling back and forth. Neither are a vibratory roller but both work fairly well when used properly.
/ Pole building foundation question #62
I think material type and thickness of lifts would be critical.
Also something often forgotten in these discussions here on TBN, our members are from around the Globe. The method I swear by might not work at all for another member. Based simply on material type.
I built a pad for my house and shop. Used my Kubota pulling a 5.5 cuyd scraper packed with a sheep's foot pulled by my Ford. I had complete faith. Partially because of the available material, Missouri Clay with optimal moisture content. Partially because my lifts were thin. Partially because I made a Gazillion trips across that pad area.
/ Pole building foundation question #63
You’re right on on all accounts but I’ve yet to hear from a single person that actually owns a tracked skid steer say it’s useless for compaction. It’s easy to bash something you’ve never tried.
/ Pole building foundation question #64
Post #62
Just the normal compacting procedure. Has worked for many a year!
2015 John Deere 6155M (A64911)
2015 John Deere...
2007 JOHN DEERE 120C EXAVATOR (A65056)
2007 JOHN DEERE...
2018 Ford Explorer AWD SUV. (A66738)
2018 Ford Explorer...
2023 Dodge Challenger Coupe (A66738)
2023 Dodge...
40' High Cube Multi-Door Container (A64912)
40' High Cube...
Deere PA30B Auger (A64911)
Deere PA30B Auger...
