Alternatives to tire chains?
/ Alternatives to tire chains? #1
lhfarm
Central Indiana
NH TC40DA
We have a very long, steep gravel drive. There are a few times each year when snow turns to ice and getting even 4 wheel drive vehicles up and down the drive is scary. So I need extra traction for 1400'. Putting chains on and off for such a short trip would be a real pain I think. I've gotten pretty good at putting chains on my tractors, but that is in work clothes and before the snow/ice arrive. Does anyone have experience with tire chain alternatives?
Been search and have seen a couple of items. This one - http://www.flextrax.com/ may not be faster than chains, but at least is a drive-on option. Anyone used a snow sock on ice? http://www.multivu.com/mnr/60481-isse-snow-socks-for-tires-deliver-traction-on-snowy-and-icy-roads
Thanks
/ Alternatives to tire chains? #2
I understand where you come from!! My drive is a mile long and has a large valley running right across the center. Its not 1400' of icy road but its enough to really raise the pucker factor when snow turn to ice during a bout of freezing rain. All my vehicles are 4WD so I have always been able to do the dirty deed without chains. I've seen a lot of folks use those "clamp on" two bar nylon things. They are easy to install, seem to work OK but probably will only last one winter. I hated chaining up my little tractor - rear chains were way too heavy - and I'm sure as heck not about to chain up the Kubota. The Kubota is more than 4X larger than the little tractor was.
You know, during those few times when everything turns to ice I use a mixture of heavy sand & chippings from my Wollenstein chipper. I spread this mix up one side of the valley and down the other. The chippings will eventually wash off the driveway but the sand will not. Honestly, when I used to work and come home in the evening, the last thing I wanted to do was put some kind of "anti skid" arrangement on my vehicle tires. I would put it in 4WD and go for it. Fortunately I never skidded off the driveway into the valley. I found the "mix" worked just about as well as chains and has kept me safe for the thirty two years I've been here. I usually do the "spreading of the mix" twice a year and that's enough to take me thru the entire snow/ice season. I'm sure sawdust/sand mix will work as well. The advantages of having wood chips/sawdust is it will float on the water, over the ice, and remain as a good traction material when the driveway refreezes.
/ Alternatives to tire chains? #3
What about rubber chains seen them less than 300 dollars for set 17.5x24 just have no personal experience but should be less weight and minimum damage to asphalt or concrete
/ Alternatives to tire chains? #4
The last part of our gravel driveway is rather steep, about 500 feet long, faces North, and shaded on the east by large trees so it gets icy like you described. We have a closed locked gate at the bottom and found out years ago that our 4WD vehicles with anti-skid brakes were a real cheek squeezer to get down there w/o plowing into the gate.
If it is not too icy, we can put the vehicles in neutral at the top of the hill and go very slowly down without
losing traction. We do have a fresh layer, 84 tons of #4 limestone on 1600' of the driveway which is a big help.
But on slick, thick ice, if we have to go down there, we go along the edge of the driveway in the open field on one side. The snow and unpacked surface gives us good traction. Of course that is if the snow is not too deep to make a bobsled out of the pan guard under the jeep. :D
We have a 65 hp heavy 4 WD utility tractor with blade and FEL that we can use if the snow gets too deep but have found it is better to just drive on it until it gets deeper than 4". Blading snow is sometimes necessary but will often actually make the surface more slippery when trying to take it off without disturbing the gravel.
It is also awful hard on my old stiff neck. :)
IMO I don't think the products you show would work on an ice covered hill.
I also have an old 2WD tractor that I used to put big tractor chains on, a real PITA and hard on the tires.
It would slide down the sloped driveway even with the chains on and too slippery to get back up.
So there again, the field method...
/ Alternatives to tire chains? #5
There are some Steel Cable versions of tire chains as well if you look for them.
Those Nylon looking things I dont see how they would work on ice and maybe make it WORSE but there could be some sort of grit built in I didn't look too closely. There are "Diamond Patten" chains/cable designs that work better than straight bar type for ice.
Then there are Studded Tires that you could put on for the winter as well, they are noisy on dry surfaces tho.
Keeping the snow off so you are not driving on it also will decrease the amount of Ice as compacting the snow into ice then a bit of freeze/thaw and that compacted snow is there longer after the ice forms.
Mark
/ Alternatives to tire chains? #6
i am going to bet that the flextrax are just as hard to install as chains.
if you practice putting on chains by laying them over the tire like the video of the flextrax you can probably install them just as fast as the flextrax. i can put chains on as kickers on the outside dual of a dually pretty fast. you just have to make up your mind you have to crawl under the truck to do it.
the trick is to have the chains laid out with the cross links all straight before you try to lay them over the top of the tire. crawl under and hook the inside and then hook up the outside. luck-ray
Mark
Here in central Indiana, it is tough to get it right on a gravel drive. Unless you push gravel with the snow, you have to leave some snow on the ground. We had 9" of snow a couple of weeks ago, then a few more inches and lots of cold. Yesterday, we started as snow and ended as rain. I started to plow as much as I could, but I left slush. It was 35 when I was plowing and 22 overnight. I ran the Cub up and down to get the chains to at least breakup the slush. The drive is solid now.
Not sure how long the snow socks would last on gravel. All the videos/reviews have been on paved surfaces. I have a set of emergency chains and may just order a couple of more sets.
Thanks,
/ Alternatives to tire chains? #8
Don't have experience with alternatives. Have 900" gravel drive. Got tired of installing/uninstalling so past couple of years just been putting the chains on in December and removing them in March.
/ Alternatives to tire chains? #9
You could try putting screws into the lugs or heavy parts of your tire treads. I did this on the Ag tires on my Gravely but really didn't have a good chance to try it out, as I bought my JD 4wd not long after that. You just screw some approximately 3/4" (or whatever you can get away with into the rubber lugs) sheet metal screws.
Ralph
/ Alternatives to tire chains? #10
Ralph
I may be wrong but I got the impression the OP was talking about an alternative to putting strap on chains on his car to get up and down the hill of his driveway.
He already has chains for his tractors, thus my answer early on.
Then when I look at his web site address at the bottom of his post he has a bunch of jeeps, so I am not sure what the situation really is all about?
Ralph
I have chains on the tractors. I'm looking, mostly for something for my Jeep Liberty and F150 4x4. Today is one of those few times that I'd feel better with more traction. I crept down with the Ford and didn't slide and did OK coming back up the hill. Don't think my wife would have tried it.
The picture shows one of problem areas. Making the curve going down or up can be ride!
The issue is ice. Jeeps go great, but stopping on ice is another issue. A vehicle starting to slide on that curve is very dangerous and hard on underwear. I have tried to break up the ice when possible, with the tractor chains and have even used a ratchet rake.
/ Alternatives to tire chains? #13
If you want to spend about $2000. Check these out
http://www.onspot.com/indhisfr.htm
I have seen these on light duty vehicles jeep, pickups etc
, they will lower your available ground clearance , but work with the flip of a switch, they do require annual maint or take them off in the summer
/ Alternatives to tire chains? #14
It looks like I did understand your situation then, if you look at post #4.
The picture adds even more clarity to your particular situation. I have another hill that is before the one described in post #4 that is not quite as steep
as yours but is 400' long and has a 90 degree curve like yours at the bottom. Luckily we have a field on the right side of it as well to slide into if it is drifted at that corner. Our jeep has a pan under the oil pan that becomes a big snowboard if the snow is too deep.
We usually put a roll of hay in the back of the 4WD pickup in deep snow and use it to get to the barn where the tractor is since the truck has lots of clearance.
Do you have room at the bottom of the hill near the road to have a parking spot?
You could leave or have your wife leave your town car there in these situations and have a jeep or your tractor with chains there to shuttle up and down the hill.
We have done that in the past with 2 WD vehicles.
Once the ice has formed or been packed it is going to be a waiting game with trees on both sides of your lane. Time to put on the boots and walk up to the house. We have done that a few times as well.
/ Alternatives to tire chains? #15
That's a tricky looking hill and turn for sure.
Would you consider widening the turn and putting some asphalt in that stretch? It would melt faster and drain better, leaving less time it is iced up maybe.
/ Alternatives to tire chains? #16
Onspot - The Automatic Tire Chain
Wow thats interesting. I've never seen anything like those. If they work or not, no idea, but neat.
To the OP do you have a loader on your tractor? Maybe you can get a load of 1/2 gravel delivered before winter every year and spread it in the scarry spots throughout the winter. It would not be a waste as you probably have to add a bit of gravel to maintain it anyways.:2cents:
/ Alternatives to tire chains? #17
Buy a tandem load of small gravel and leave it in a pile at the bottom. Occasionally spread it on the ice. It doesn't take much to get great traction.
/ Alternatives to tire chains? #18
In the subdivision I have been looking to buy in CO, there are 2 "major" steep hills.
There is pretty much nothing to stop your slide all the way to the bottom, and both have switchbacks where you can go over the side pretty quick. This photo taken mid summer and it was just within the ability of my 2wd Dodge Ram to handle traction wise...
In speaking to residents there, they say that typically there are 2-3 months of the year where access by car of any sort is simply impossible. To remain mobile they park on the county road (which is serviced) and take a snowmobile up to the homes on top.
/ Alternatives to tire chains? #19
You need to cut some trees and maybe add a bit of camber to the turn (bank it so it isn't quite so bad). Winter is a great time to cut trees, especially in your mild climate. :)
/ Alternatives to tire chains? #20
I've got a mile of gravel road that goes up and down two hills, one very steep and one moderate. In both cases there is a nearly 90 degree turn in the middle of the grade - the road was dictated by an estate settlement, not common sense. It is a lovely forest drive when there is no ice or snow. Ice and snow are bad. And, since the drive cuts down the side of a hill in most cases, sliding off would probably mean a roll-over or total loss. I have chains for all four wheels of my F-150 - loaded with firewood, and two chains for my old Jimmy 4 X 4. My wife drives a Subaru Outback that is fine in a few inches of snow.
I have to take any snow off the slopes asap because running over it will pack it into ice quickly. Chains work with most ice, unless it is very cold following ice over snow. I've slid about 80 feet with good, square cut chains because they could not find a grip.
My response is pushing snow as soon as it accumulates. I also have a drive that is somewhat wider than average so I can scrape it down to the gravel - picking up gravel but moving it into a pile still on the gravel. I come back after the melt with a box blade or grader blade and put the gravel back.
I have also carefully placed large logs along the downhill side of the road along all my drive. These logs, average about 15 inches diameter, are held in place where necessary with locust stakes pounded in behind them. Actually, when there is ice, they are frozen to the ground anyway and won't move.
Since my sliding is usually quite slow, sliding out and bumping one of those logs will bounce you back onto the road and you can slide on down the hill. I believe I'd have to be going pretty fast to go over the logs.
When I have ice on the hills, I also attack it with my ratchet rake. I just run up the hill, put the blade down and back down to bring up gravel. It tears up the gravel, but gives you traction. Then I go back after the snow has melted and smooth it over.
Generally we only have a few really bad times each winter here in Virginia, and I also just try to not go out. If I have to, I park the Outback at the end of my drive and take my truck out to it - with chains on.
All that said, I am planning to buy chains for my little CUT simply for extra traction when I have to work ice. I have an indoor place to mount the chains, and will probably hold putting them on any given winter until the first weather forecast that would make me think I'd really need them... Then leave them on for the rest of the winter. Some winters that might mean I never put them on.
Living in the county with a long, hilly, curvy drive means you will never have an assured solution to egress under all conditions. You just work the storm and accept the problem as the price of living where you want.
