40x60 Farm Shop Build
/ 40x60 Farm Shop Build
I would think the bigger pier, the better.
Looks like with a little more seat time, it wouldn't be too hard to make the pad bigger. Why don't you get or make more trusses to make the building as large as you want it? Seems it would be a lot cheaper to spend the money now to make it a little bigger then to build another building.
Eddie
I think I'll go with the 12" piers, the extra concrete won't be that much.
As for the size of the building, if I go any longer I'll be too close to the corn crib at one end and the barn at the other. Eventually there will also be a small milk house at that end of the barn, so space is at a premium. (plus this will give me an excuse to have a really large shop and another shed for equipment) :thumbsup:
A good resource for others who might be building a shop is this booklet Purdue University put out in 1980 about farm shops: AE-104
It has good info about size and layout, energy efficiency, heating/insulation, doors, equipping the shop, as well as other construction considerations. Being written 30yrs ago the layouts are smaller and more relevant to most of us compared to the mega farm shops that are being written about today.
/ 40x60 Farm Shop Build #23
I would go with the 12" piers. Having a big workshop and another building for equipment storage sounds fantastic.
Thanks for the replies.
We did end up going with the 12" piers and drilled the holes today. With some good help we were able to lay out the whole building in about 15min. With a transit and a 100' tape it's really easy:
1. Set the two pins (we use 16D double headed nails) for the back wall/long side with a tape measure and line them up with whatever you like. I lined them up so this building would be parallel to the barn.
2. Set the transit over the first pin using a plumb bob and get the second pin in the cross hairs. With the tape still stretched out, set the nails at the spacing for the piers or posts (12' OC in our case), using the transit to keep them in line between the two pins.
3. Rotate the transit 90* and set the next corner pin, which was 39'11" for this building.
4. Move the transit to the other corner on the long side and repeat step 3.
5. Stretch the tape between those two pins for the other long side and repeat step 2.
6. Check the square either by checking angle to the opposite corner, which was 39*45" for this building, or checking the diagonals which were 62' 5 1/8"
As we went we sprayed a small 2" circle around the nails with spray paint and set some reference nails 5' out at two corners so we could setup the transit again after the holes were drilled. The nails were then removed and the holes drilled with a 12" auger to a depth of about 48". Once I get the holes all cleaned up I'll make some little 9" square forms for the above ground portion of the piers. I'll see if I can get some pics up soon.
Question: I need to decide how high to make the piers off the ground, which will also correlate to the finished height of the concrete floor. That said, I will probably pour a 4" slab with radiant heat coils/piping, something which I have no experience with. Would it be advisable to insulate under the slab? What thickness foam board would I want to use? If I use foam board, would 2" of #57 gravel be enough for the base considering a well compacted and perfectly level clay base? I don't want my piers to be any taller than needed because the rest of the building without the floor will have a big gap under the tin. Thanks in advance.
/ 40x60 Farm Shop Build #25
With the TIN don't worry too much it is better to be HI as you can add TREATED Skirt Boards (T&G) around perimeter which keeps critters from digging UNDER the slab and or water weeds from rotting the bottom of the tin. EDIT IN attached a distance view of my construction, the POLES are no different than your concrete pour with metal attaching points, you don't want Metal too close to the ground anyways so adding the Skirt Boards around the perimeter will help you later if done NOW.
click pic for larger view
On mine I went with 16" of T&G Skirt Boards of which most of them on the high side had to be dug down to bury them, I then ended up adding 2 more layers (8" Treated T&G) for 32" in LOW side and 1 more on Hi side. This was where back fill gravel was contained, tamped, rolled and vibrated level. I added 3 layers of insulation, one layer of white 3/4" styrofoam, a layer of 1/4" Foil Bubble Bubble Poly Radiant Barrier insulation and a Final layer of 3/4" 250PSI Red Styrofoam. On all layers I/we taped the seems with poly box tape (free drop rolls from work off automatic boxing machines.) and used white poly tape for the Radiant barrier tape.
I ended up with somewhere between 4.5" and 5.5" of concrete in my barn, the thicker section is where my tractor drives in/out & planned. On top of the Styrofoam we placed 6x6 10awg Steel Concrete Mesh on Plastic Chairs on 2' x 2' grid and tied the Radiant Tube to that. It made even spacing real easy and the chairs were added prior to pouring crew getting there.
One thing is be sure to add some under ground PIPE Penetrations NOW! add floor drains, power in/out plumbing plumbing in/out penetrations. Even if they are never used NOW is time to do it. I WISH I had added two more as now I have future ideas that I should have included right off. Just missed planning enough.
From this pic click it and go to the photobucket site for a list of series starting on page 4 of the barn folder for all the stuff I've done.
Mark
Some progress pics and info:
Holes for piers were drilled down to a depth of 4' and a diameter of 12":
Building the forms, set using the transit and a string line, forms are built out of 2x8 and built to position the anchor bolts:
Finished piers, everything turned out square within 1/8":
/ 40x60 Farm Shop Build #27
Do you have to go down so far because of frost heave?
How far is the bottom of the ditch from your wall? It looks pretty tight to get in there and mow or maintain the plants from overgrowing the area.
Eddie
Eddie
I set poles and piers 4' deep partly because of the frost, but also to assure they are on undisturbed soil and not fill.
As for the bank behind the shed, it is pretty close at about 3'. The flat area close to the shed will be gravel and the bank behind the shed will be grass. I'll just weed-eat it a couple times a year or let the sheep and cows graze it.
Once the piers were cured it was time to start erecting the building. The first truss was brought over and hung using a jib crane on the M9540. Once suspended we installed the posts, and set it in place, bolted it down and secured it with bracing and some triangulated rigging:
The second truss was brought in and set in a similar fashion. The tractor and jib crane were used to hold it in position while we installed a few purlins to secure it:
The M9540 worked out great, with the jib crane fully extended it would reach to 25', the top of the building is about 22'. That said, these trusses with posts attached are about at max capacity weight wise with that boom so far out:
This bucket lift strapped to a trailer behind my B3200 was a real time saver. My father-in-law bought it at the same time we took down the building originally, we've used it for everything from attaching bracing and rigging to hoisting up purlins and tin:
More to come...
The basic structure took the three of us about 12hrs to build, with minimal bracing and about 4 purlins per section. Once that was up later in the week my brother and I set the remaining 25 or so purlins, the top wall girts and more of the bracing:
Lately the local quarry has been having troubles with their crusher, so getting gravel has been hit-or-miss. Finally I was able to get about 50 tons of crusher-run brought in and I got that spread. Working in that terrible mud was starting to get old:
This week we got started putting the tin on the roof and have about a third of it up. Progress has been slower lately due to lots of wind, rain and ice we've been having. More updates and pics to come as things progress.
/ 40x60 Farm Shop Build #31
Nice progress, it's always enjoyable to watch a building go up like this. Looks like you have a great source of equipment to work with.
/ 40x60 Farm Shop Build #32
Funny, but I was assuming you where using wooden posts. Seeing the metal posts clears it all up as to why you did the concrete footings like you did.
It sure looks good.
Eddie
Thanks,
Between my father, my father-in-law and myself we've accumulated some equipment over the years (plus I build barns for a living):thumbsup:
It sure looks good.
Eddie
Thanks, this is the first all metal building that I have done and it has surprised me how fast it is going up compared to a wood structure.
/ 40x60 Farm Shop Build #34
Looks great, are you reusing the siding and roof as well?
I am reusing the roofing as it is in really good shape and specially formed to fit the building. It has a nice curved over ridge and eves. The siding was in decent shape, but all my windows and doors will be in different locations so it will be easier to just buy new.
/ 40x60 Farm Shop Build #36
I can't wait to see it completed.
That makes two of us...:D
We've gotten about two thirds of the roof on. If I didn't have other projects going on we might have gotten it done this week. So far the roof has been going on pretty well, all the panels are pre-drilled and it uses metal clips that wrap around the bottom of the pulin to secure it. Originally they use wide flange machine screws with a flat head slot, but they were a major PITA to work with. I'm simply using a 1/4x1" bolt with a tight fitting washer under it and it looks like it will work well. A flange head bolt would have been best, but would have had to been ordered and would have cost about three times as much. It will take right at 1,000 bolts to secure the roof, I completely cleaned out all the 1/4" bolts that size that the local Tractor Supply had, lol. (TSC is a great place to buy hardware since it's by the pound. 1,000 bolts, nuts and washers cost about $50.)
/ 40x60 Farm Shop Build #38
Was the quarry you bought the stone from Shooting Creek? Nice looking barn by the way
Thanks,
Yes, Shooting Creek (now R&S Stone) is who I buy 95% of my rock from.
/ 40x60 Farm Shop Build #40
I heard that they were almost out of stone, thanks for replying
2007 BIG TEX 16 T/A UTILITY TRAILER (A65643)
2007 BIG TEX 16...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
2012 FREIGHTLINER M2 6X4 T/A GARBAGE TRUCK (A66091)
2012 FREIGHTLINER...
2017 Autocar Xpeditor T/A Heil V-161 28Yd Front Loader Garbage Truck (A61573)
2017 Autocar...
2011 CATERPILLAR 304D (A65643)
2011 CATERPILLAR...
2014 MASTER END DUMP TRAILER (A65643)
2014 MASTER END...
