Flashing light on bx23
/ Flashing light on bx23 #1
glennm
Puslinch, Ontario
BX23, RTV 900 and Z122
I have an old orange flashing light ( the kind with a rotating reflector) that I want to use on the bx roll bars when I am moving snow. Any suggestion as to where I should take the power from? I was hoping there was something under the seat but I don't see anything? Also, do you think a magnet would work to hold it in place?
/ Flashing light on bx23 #2
A really strong magnet might work, but when I tried that approach on the B7500 I had, the magnet wasn't strong enough to keep the light in place. Since the tractor lacks a suspension the ROPS makes sharp movements when the tractor hits a bump. I now bolt everything to the tractor that needs to stay put.
/ Flashing light on bx23 #3
The may be a power source under one of the fender tail lights that's meant to be used for your hookup.... as I recall.
/ Flashing light on bx23 #4
Should be a work light connector, red and black wires just rear of the bottom of the seat, over the tank. Check for 12V with a meter. It is switched on with ignition as I recall.
Found the wire under the seat. Worked out great. Thanks!
/ Flashing light on bx23 #6
Try the welding magnets from harbor freight . I use them on bx24 for lights on roll bar. No problem
Has anyone put an LED light bar on the roll bar to use a a work light?
/ Flashing light on bx23 #9
That's where the hook-up is. It switches on with the headlights tho
/ Flashing light on bx23 #10
Yup :D
Front led light bar .
Rear, white and amber led 70 pattern strobe
Thanks Paul.
I have read the long thread several times, it is a lot of searching to find the led.
Can you give me the details on both the light and strobe? Do they work great? Is the strobe just a strobe? I would like to do this. It looks to me like you made a mount that hold both lights as well?
By the way, I love all the mods you have done!
/ Flashing light on bx23 #12
Thanks Paul.
Glenn the rear portion of the light module I built has (if I remember correctly) 70 flash patterns. One half of that light is amber and the other half is white, by toggling the switch you change the patterns but there's one that will keep the light on steady so it can act as a back up light.
The forward portion of the light module is a single row led light and it's super bright.
The module itself is fabricated out of aluminum plate and held on the ROPS via ubolts. I designed it as you see it because I was trying to achieve the lowest possible profile as I could build. I'm happy with with it and it really works great. I'm not a fan of having individual lights bolted to the ROPS so that's the reason I went this route.
Thanks. Glad you enjoyed the mods :thumbsup:
That's exactly what I am looking for. Can you let me know where you got the lights? I would like to order them. Where did you mount the switches? If they are fed by the wire under the seat I would guess you need to run some wiring up front if the lights are dash mounted?
/ Flashing light on bx23 #14
Well I've bought sooooo many lights in the last two years I'll have to check our files to see if I can find that info. I've not only modded this little BX but I've done our Kubota Grand L 5740 and believe me there's a lot of led lighting on it.
If you go back over my mod thread I might have mentioned where those lights came from. I can tell you that the rear strobes are controlled via switch down by the 3pt hitch dampening control (see photo) the rest of the lighting is controlled via switches on the dash. I ran an extra fuse panel, relays and custom wiring harness to do it.
The 5740. Lots of lights :eek:
/ Flashing light on bx23 #15
Go to Paul's website and you will see the results of his lighting additions. Great website by the way. Kathy's excellent work is evident also.
I just looked at the videos on the site. There are a pile of LEDs on eBay, I just don't want to buy a dog!
/ Flashing light on bx23 #17
Thanks for the compliment. You brought a smile to Kathy's face as well. We're taking some time off for the holiday season so that means I'll have more time for BX mods. Can't wait either. Got a few ideas I want to put down on metal ;)
Glenn when I'm looking for led lighting I look for the following. Grote, Rigid, Whelen and last but not least Cree. If you stick with those brand names you'll be ok. I NEVER had an issue with any of those products.
2022 EZ-GO ELITE...
CATERPILLAR D6N LGP HI-TRACK CRAWLER DOZER (A65053)
CATERPILLAR D6N...
2019 FREIGHTLINER M2 4X2 S/A 26FT NON CDL BOX TRUCK (A59914)
2019 FREIGHTLINER...
3098 (A63117)
3098 (A63117)
Landhonor ATS-ME18 Mini Excavator (A66285)
Landhonor ATS-ME18...
2008 PETERBILT 365 (A65643)
2008 PETERBILT 365...
