Buying Advice New Tractor advice
/ New Tractor advice #1
Redblok
Member
Springfield Va
JD
Ok - Brand new to the site and looking to buy a tractor for a 10 acre - property. In my local area, there is only a John Deere and MF dealer. Kubota is over 80 miles away, NH is over 100 miles away. So I am looking at a John Deere. My property is mainly wooded with small trees ranging from 3-10 inches in diameter. The plan is to clear 5 acres and plant with pasture grass. I am not worried about pulling stumps out with the tractor, I have a 5 Ton 6X6 Army truck to pull stumps. I really need a machine that can run a small 55 inch root Rake grapple, brush hog and box scrapper. I will rent a PTO wood chipper for chipping the branches. I think that I want a Hydrostatic Transmission as well.
I am considering the following
New 2013 JD 3038 with 305 Loader and box scrapper with 1 hour for $18,000 with 0% fin
2012 JD 3520 with 300cx loader with 150 hours for $20,000 - 1.9% fin
New 2013 JD 3038 with 305 loader, Frontier Rotary cutter, box scrapper and 16 foot trailer for $22,000 with 0% fin
I do need to buy a trailer and have price them out (best price $1600 for 16 foot .
Do you all think the 3038e is cut out for the job and which deal would you go with. I look forward to your input - Oh - I have driven both the 3038 and the 3520.
Thanks
Rob
/ New Tractor advice #2
Get the 3520...hands down the better tractor with much better everything including lift capacity. You will kick yourself if you don't spend a little extra now to get the better machine. Trust me on this one...
/ New Tractor advice #3
Just wanted to give some friendly advice on the trailer. Most utility trailers come standard with #3500 axles. That will usually give you about #5000 available cargo to haul. Even with a compact tractor, if you add the bush hog and box blade at the same time, you could be overloading the trailer and will end up with axle bearing problems. I just had a new trailer built for hauling my zero turn mower and side by side, but I had it built heavier for a 55 hp tractor. Like I said, just friendly advice.
/ New Tractor advice #4
...and good advice! My advice would to scrap the trailer all together if you are just buying it to transport your tractor on rare occasions. Rent one for $50 a day..
My 3320 with loader, 2 implements, and loaded tires is more than 3 tons.
Never thought of that. That is a great point.
/ New Tractor advice #6
My 3032e has been a great tractor, but I have wanted more lift capacity more than a few times, especially when using the Frontier AV20H grapple (~380 lbs).
/ New Tractor advice #7
Of the choices you list, I'd also go for the 3520.
The 3038 does not have off seat PTO capability. There are simple workarounds...a 50 lb bag of sand will do, however. To me, a tractor is both a mobile tool as well as a stationary power source (the off seat PTO work). I, personally, would not buy a tractor with out this useful feature.
As far as renting a PTO driven wood chipper...that's going to be a tough one to find, I think. Powered wood chippers...no problem. I do suggest you keep an eye on Craigslist for a chipper...and since you have mostly wooded acreage, a chipper/shredder might be a better way to go. My unit is a Woods 5000 chipper/shredder. I use the shredder as much (or more) then the chipper. Since I have a wood stove now, I'll likely use the chipper less and the shredder more. I paid $1000 for this used chipper/shredder.
BTW, since you tried out both the 3038 and the 3520, which did you like best?
/ New Tractor advice #8
There are actually other dealers much closer than 80-100mi from Springfield (I'm in stafford, VA as I type this). There is a NH/Kioti dealer in Frederick, a Kubota dealer in Fredericksburg, an LS dealer in Culpeper, a Case/IH dealer near Leesburg, etc....none terribly far away.
The farm where the tractor will be kept is in Covington VA which is over 210 miles away from Springfield. Not much down that way except for Jd and an MF. I have yet to see anyone at the MF shop. Lot's of shiny new tractors that never even move on the MF lot.
Roy,
I like the 3520 with the eHydro. The one I found has the power reverser trans. I am not sure I want the PR tranny. I have not found any 3520 with eHdyro transmissions that were under $24K. Since I want the Hydro transmission, it is a $4K difference not including the interest I will have to pay on the 3520. I think I am going with the 3038e, 305 loader and a box scraper. I will have a diverter valve added so I can control the grapple. I am planning on going with the Everything Attachments 50inch Root Rake Grapple. For $1400 and weighing less that 300 lbs, I think I got it covered. The 3520 ehydro is nice. Also - Talking with JD today. The 3038e can be run without having weight in the seat. According to them, you place the machine in neutral, set the parking brake (do not sit in the seat) and start the machine. The PTO will work and you don't have any weight in the seat.
/ New Tractor advice #12
Roy,
The reverser is an outstanding transmission....the advantages of easy forward and reversing, yet no power loss from the HST. Best of both worlds.
My Deere 4400 has a reverser transmission. Mine is what the call a Sync-Reverser. The main difference is I have to clutch to shift directions...not required on the Power-Reverser. IMHO, these are the most versatile transmissions Deere uses. Basically, it has 12 speeds forward, 12 speeds in reverse. There are 4 speeds and 3 ranges. Like the eHydro,you do need to stop to change ranges. Speed changes within a range can be done on the fly.
Frankly, there's not that many times I need to shift gears, once one is selected for the task. However, reversing can be quite frequent.
Personally, I think you'd really like it!
As far as the 3038e...this is directly from the Deere manual:
Using Rear PTO
NOTE: The Rear PTO is only operational with the operator on the seat.
Engaging Rear PTO
1. Sit on operator’s seat.
2. Stop machine motion, remove foot from forward and reverse travel pedals.
NOTE: The starter will not crank if the PTO knob is pulled to the engaged/on position. If the operator leaves the seat with the engine running and the PTO engaged, the safety interlock system will stop the engine.
3. Reduce throttle setting to 1500 rpm.
4. Pull the PTO knob to the engaged/on position to engage the rear PTO.
5. Adjust the hand throttle lever forward to the desired speed for implement used.
NOTE: The PTO icon on the tachometer indicates the correct engine rpm for a standard 540 PTO .
Disengaging Rear PTO
1. Adjust engine rpm to low idle speed.
2. Push the PTO knob to the disengaged/off position to disengage the rear PTO.
Here's the link to the manual:
OMLVU20279_L8
Thanks Roy - Before I buy anything, I am going to play hookie tomorrow and test drive tractors again.. I find it interesting that the JD sales rep was telling me the work around. I will have to check that out. I definitely would like to run a PTO generator when the power goes out and maybe a chipper /shredder.
I was wrong on the 3520- The out of state dealer now told the finance rate was 4.9% and that the $19900 was the cash price, $21900 of the financed deal plus whatever the finance rate is.
I guess that one is out. Looks like the 3038e is probably the winner, but I am going test driving tomorrow.
/ New Tractor advice #15
/ New Tractor advice #16
You are really going to do some heavy work to start with ! Clearing 5 acres ? Different machines for different jobs . The John Deere 3038 or 3520 are good tractors, for cutting pasture or yard or general farm use, I have a 253 mf 4 wheel drive .4 in 1 bucket loader attached 50 hp or better ,it has help clear off some lots , I have been and still are a heavy equipment operator , for over 40 years ,The 3520 I believe can handle a backhoe attachment , not heavy duty and costly. With the 3520 and the 5 ton truck , if you take your time , you can clear the 5 acres, if you have never done any clearing before you will learn just take your time . If you get bit by the equipment bug , it is a life long disease , not a bad thing to have. Best of luck!!!! Keep on Tractoring!!!!!!
Diesel 3 - Thanks for the advice. I do plan to take my time. Years ago I had done some clearing. If I had the budget - I would just buy a decent Crawler/loader with a 4/1 bucket to do the work, but I also need a CUT 4x4 to do work on another property as well.
Thanks
/ New Tractor advice #18
Redblok I purchased an Everything's attachment grapple with the 3rd function hyd kit for my L3540 and installed it myself. It's a great attachment and no complaints. It's tuffer than the Kubota FEL which I bent/twisted pulling on a tree with the grapple. The hyd won't allow curl, lift and clamp at the same time.
OK - I did my test drives - I like the eHydro and HST over the Power Reverser. I have my choices narrowed down to the JD 3038e and the 3320. I really like the larger size, extra weight, lift capacity and increased breakout force of the 3320. That being said, the 3038e has more overall HP and PTO HP. Both tractors will have a WR long diverter valve kit installed. So hear is the question - Is the 3320 worth the extra $6000 in price (including taxes)?
My budget for a tractor is about $22K. The 3038e comes in at $21 500K not including $1,400 for the EA Root Rake Grapple. The 3320 is coming in at $27,500 not including the grapple. I know the 3320 is a much nicer tractor and the extra weight is helpful, but is it worth paying 25% more?
I look forward to hear what the members have to say. My heart says one thing, but my wallet says another.
Thanks
/ New Tractor advice #20
Is it worth 25% more? It was for me. That is a decision only you will be able to make. If you get the best the first time, you wont have to look back in regret.....Your miles may vary.
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2017 Ford F-550 Signalier ATR 45ft Bucket Truck (A61568)
2017 Ford F-550...
2019 John Deere R-4038 (A61307)
2019 John Deere...
Toro Greensmaster 3150-Q Riding Mower (A56859)
Toro Greensmaster...
2012 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2012 DRAGON 150...
2018 INTERNATIONAL 4300 26' BOX TRUCK (A59906)
2018 INTERNATIONAL...
