Grapple
/ Grapple #1
Chisum
Denton Texas
Cub Cadet
IMG_1438.jpgBuilt this Grapple for my tractor. Can do so much more than ever imagined. What do you think? IMG_1439.jpgIMG_1441.jpgGrapple working2.jpg
/ Grapple #2
Nice job, you do some very good work.
/ Grapple #4
What's the weight?
/ Grapple #6
Very nice work. Why is there two separate cylinders/sections? I don't know anything about this type of grapple.
thanks,
dave
/ Grapple #7
thanks,
dave
On the larger grapples, it is advantageous to have 2 lids to better pickup loads that are bigger on one end than the other. Think of perhaps a tree stump, one lid can close on the larger end, and the other on the smaller end. Or perhaps a rock that is unbalanced.
James K0UA
/ Grapple
Thanks! With it being 72" long it's Able to clamp on loads across the grapple. Both work on the same valve but once one hits whatever material your carrying then the other will continue on until it hits and pressure is applied to both equally giving it more Stability.
/ Grapple #10
That attachment is very cool.
/ Grapple #12
Awesome build. You have no idea how much you are gonna use this attachment.
It makes a very lazy man outta ya though. So be prepared for that. I'll work a minute or two trying to pick up a small branch with the Grapple rather than get off and pick it up by hand!!! ;)
If a person is gonna take the time to build a Grapple, you definitely want to build with two "jaws". As James said, it increases productivity dramatically. Even with Brush, it will pick up a bigger load. And most importantly, it will not drop brush all the way to the pile.
I've built a LOT of attachments and add-ons. None have a payback like a Grapple.
Again, great build!!!! You do quality work and should get many, many years use from this gear.
/ Grapple #14
Very nice! Did you get the writing/cutting done or did you do it yourself?
/ Grapple
HA! On the Lazy!! Noticed that first off. Thanks for the Compliment
/ Grapple #17
Nice looks like a ea wicked root grapple how much money and time do you have invested in it? Thinking of building one for my skid steer!
/ Grapple
Right at $1000.00 in materials. Metal, Hydraulics, hoses, fittings etc. Guessing around 30 hrs, does not include any design time. Nothing my tractor can do to tear it up. I Tried!! Its by far the best attachment Ive got. Thanks!
/ Grapple #19
How much would you charge to build me one??
Survey Kit (A64912)
Survey Kit (A64912)
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
John Deere 7300 6 Row Planter (A64911)
John Deere 7300 6...
2017 Mack Semi (A64047)
2017 Mack Semi...
2000 FORD F-650 SUPER DUTY (A63569)
2000 FORD F-650...
