cut pipe for plow cutting edge
/ cut pipe for plow cutting edge #21
The 30T blade is for general steel pipe, angles, etc. The 50T blade is recommended for thinner material like sheet metal. They also have a 56T blade available for stainless steel tubing and sheet metal.
I don't really want to buy new tools (shocking!) so may just try the torch guided with a straightedge. It's not like it needs a glove fit; snug should be fine. Thanks for all the input everyone.
Jim
/ cut pipe for plow cutting edge #23
I have a metal cutting circular saw I bought at Harbor Freight. I haven't tried to cut the length of a pipe but it works good for cutting mild steel. If I were going to cut the length of a pipe with it I would create some sort of jig for both safety and keeping the cut straight. Mine is something like this. 5-3/8" Metal Cutting Circular Saw
Rated for 1 5/8" mild steel.... :shocked:
Man... death grip on those handles FOR SURE!! :laughing:
/ cut pipe for plow cutting edge #24
Know anyone with a plasma cutter? Tack a piece of angle iron on your pipe for a guide. Make first cut. Move and re-tack angle iron. Make second cut. Neat, clean, won't distort pipe, and about 15 minutes of time.
/ cut pipe for plow cutting edge #25
News flash: THERE IS NO NEED TO SLIT A STEEL PIPE FOR THIS PURPOSE. :confused3:
Weld some tabs on it, and bolt it on in front of the blade. If you do it right, you won't notice the difference, and neither will the plow.
Got a pic of how it's attached? Tab size and thickness? I'd rather not slit the pipe, for sure.
Jim
/ cut pipe for plow cutting edge #27
There are lots of different ways you can do this, without the difficulty of slitting the pipe.
You can make a U shaped tab that fits over the blade, and weld the pipe to the front side of the tab. Like this: oU
Or, the last one I did, I used 3/16" flat, and attached the tab to the front of the blade, and then I welded the pipe to it. Like this: ol
Works just fine. And it only took a few minutes. I have 2 of these tabs, on a 6' pipe.
Aligning the tabs with the existing bolt holes on the plow, makes it an easy job.
I will post a photo, when I get some time in the next few days.
/ cut pipe for plow cutting edge #28
thank you.
/ cut pipe for plow cutting edge #29
/ cut pipe for plow cutting edge #30
Somehow I have missed the purpose.... I presume its to keep the cutting edge from actually cutting in?
Is this to be used in place of shoes? or with shoes on the blade? Does it end up leaving more snow behind?
/ cut pipe for plow cutting edge #31
Yes, the primary reason is to help keep the plow from digging in. This is of course, helpful when plowing gravel.
My plow has this pipe, and pneumatic casters in place of shoes.
The plow rides primarily on the casters. The cutting edge then can float along on top of the gravel, or since it is a loader frame plow, I can use the bucket tilt mechanism to adjust it so that it rides just above the gravel.
I usually try to pack down the first 3-4 inches of snow, then plowing my drive with this set up is pretty easy.
/ cut pipe for plow cutting edge #32
Thanks ray.... I think I need to make one for my new plow I just assembled then. The plow I made for the tractor has the primary purpose of clearing parts of the lawn - so I am on grass. I need to eliminate the potential for digging in as much as possible.
/ cut pipe for plow cutting edge #33
I would imagine this would also help to keep from spreading the gravel into the grass? That would sure be nice.
Ray, thanks for the pic. That was kind of what I imagined. As long as the tabs are pretty stout it should hold up all right. Soon, soon...
Jim
/ cut pipe for plow cutting edge #36
Jim
When you go forward, the force is pushing the pipe up against the blade, so the tabs really don't have much pressure on them.
The tabs only need to resist a lot of pressure, when you back drag the blade. Which we mostly don't do. And, only the bottom edge of the pipe is receiving that pressure, so that really isn't a problem on the ones I have done.
You could also use U shaped tabs, if you do have a problem with it bending from back dragging.
/ cut pipe for plow cutting edge #37
The plow rides primarily on the casters....
Did you find these somewhere, or was it something you made? I'd like to be able to swap out my shoes and slide in casters, but haven't found any that would fit.
/ cut pipe for plow cutting edge #38
I ordered the casters online somewhere, (don't remember where), and made the mounts myself.
You can't just swap them, because the casters need a lot more room to swing around. There also needs to be sufficient clearance between the plow and the tractor when it's angled, to leave room for the caster to swing.
The last thing I did to it was change the for the plow from a rigid mount to a hinged one, just like it mounts on a plow truck. That allows the plow to float up and down some.
The loader arms stay fixed, and the plow rides on the casters.
The bucket tilt cylinders allow me to set the desired height for the blade. Because, in the mounting hinges I put a stop to control how far the plow hinges downward. That way, I can keep it above the gravel, or set it down on it. The lower limit stops work to set the height the same way the chain does, that lifts and lowers the plow on a truck.
/ cut pipe for plow cutting edge #39
OK, thanks. I guessed you likely must have made something up. I may have to figure out a way to do that myself....
/ cut pipe for plow cutting edge #40
In case you haven't seen what they look like on my plow:
2020 Broyhill Load and Pack TD3.6 Mini Articulated Garbage Truck (A61568)
2020 Broyhill Load...
(1) New 7ft Chain Sling (A61166)
(1) New 7ft Chain...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
Adams 5 T Fertilizer Spreader (A63118)
Adams 5 T...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
