cut pipe for plow cutting edge
   / cut pipe for plow cutting edge #21
The 30T blade is for general steel pipe, angles, etc. The 50T blade is recommended for thinner material like sheet metal. They also have a 56T blade available for stainless steel tubing and sheet metal.
I don't really want to buy new tools (shocking!) so may just try the torch guided with a straightedge. It's not like it needs a glove fit; snug should be fine. Thanks for all the input everyone.
Jim
   / cut pipe for plow cutting edge #23
I have a metal cutting circular saw I bought at Harbor Freight. I haven't tried to cut the length of a pipe but it works good for cutting mild steel. If I were going to cut the length of a pipe with it I would create some sort of jig for both safety and keeping the cut straight. Mine is something like this. 5-3/8" Metal Cutting Circular Saw
Rated for 1 5/8" mild steel.... :shocked:
Man... death grip on those handles FOR SURE!! :laughing:
   / cut pipe for plow cutting edge #24
Know anyone with a plasma cutter? Tack a piece of angle iron on your pipe for a guide. Make first cut. Move and re-tack angle iron. Make second cut. Neat, clean, won't distort pipe, and about 15 minutes of time.
   / cut pipe for plow cutting edge #25
News flash: THERE IS NO NEED TO SLIT A STEEL PIPE FOR THIS PURPOSE. :confused3:
Weld some tabs on it, and bolt it on in front of the blade. If you do it right, you won't notice the difference, and neither will the plow.
Got a pic of how it's attached? Tab size and thickness? I'd rather not slit the pipe, for sure.
Jim
   / cut pipe for plow cutting edge #27
There are lots of different ways you can do this, without the difficulty of slitting the pipe.
You can make a U shaped tab that fits over the blade, and weld the pipe to the front side of the tab. Like this: oU
Or, the last one I did, I used 3/16" flat, and attached the tab to the front of the blade, and then I welded the pipe to it. Like this: ol
Works just fine. And it only took a few minutes. I have 2 of these tabs, on a 6' pipe.
Aligning the tabs with the existing bolt holes on the plow, makes it an easy job.
I will post a photo, when I get some time in the next few days.
   / cut pipe for plow cutting edge #28
thank you.
   / cut pipe for plow cutting edge #29
   / cut pipe for plow cutting edge #30
Somehow I have missed the purpose.... I presume its to keep the cutting edge from actually cutting in?
Is this to be used in place of shoes? or with shoes on the blade? Does it end up leaving more snow behind?
2014 Mercedes GL550 AWD SUV (A55758)
2014 Mercedes...
2023 Jeep Gladiator Sport 4WD SUT (A55758)
2023 Jeep...
Heavy Duty Jumper Cables (A55788)
Heavy Duty Jumper...
2007 GMC C5500 Landscape Dump (A47477)
2007 GMC C5500...
1996 Sunflower 1543-38 Folding Disk (A55301)
1996 Sunflower...
1998 FREIGHTLINER CST120 TANDEM AXLE SLEEPER TRUCK (A56129)
1998 FREIGHTLINER...
