Finally widened tires-before & after pics
/ Finally widened tires-before & after pics #1
CobyRupert
Super Member
Washington County, NY
JD 5075E
Here's before and after pics of widening the 5075 another 15+ inches
Feels like a totally different tractor.
/ Finally widened tires-before & after pics #2
Stability wise it is a lot better. I always try to run mine as wide as is reasonable for the jobs I do.
/ Finally widened tires-before & after pics #3
Quite a difference :thumbsup:
Did you have to turn the rims around and remount the tires or were you able to get that much w/o doing that ?
/ Finally widened tires-before & after pics #4
Did the same with my NH. HUGE difference. Should be done at the dealership before they are sold.
/ Finally widened tires-before & after pics #5
Do you notice the extra width in the woods? Going from a 4' atv to the 6' tractor has required alot of trail work at my place, but I need to run my tractor as wide as it goes for the hills.
Sort of, if you mean by swapping the left outer rim and tire to the right side and vise-versa. That keeps the tread direction the same and no bead busting required.
Yes, definitely noticeable squeezing through the barn door or on the paths, but a lot less pucker fatigue when working the FEL on a side hill to pick up branches and tips with stumps (surprise!). Which are going to get even sneakier bidding under snow.
/ Finally widened tires-before & after pics #7
Does it affect the turning radius of your tractor? IMHO, I would think that the wider tires would take time to get used to.
/ Finally widened tires-before & after pics #8
Okay, so what did you do to widen the stance? Wheel spacers? B.
/ Finally widened tires-before & after pics #9
Ag type tires-rims normally have 4-5 different width possibilities built into the rim. So just by switching things around a person can get several different widths with no cost other than the time and labor it takes to do all the moving of everything around. :cool:
/ Finally widened tires-before & after pics #10
Thanks for posting. I learned something new.
/ Finally widened tires-before & after pics #12
Turning radius should not change... front tires still turn as far, the tire being spaced in a few inches shouldn't effect anything, if measuring to the center of the tractor. The additional wheel track width would be the extent of the change in "turning radius". Hit the brake on the inside tire... it'll turn!
2019 KUBOTA KX057-4 EXCAVATOR (A62129)
2019 KUBOTA...
KUBOTA KX033-4 EXCAVATOR (A65053)
KUBOTA KX033-4...
Adams Under Truck Conveyor (A63688)
Adams Under Truck...
2022 EZ-GO ELITE...
YALE FORKLIFT (A63291)
2022 CAT 289D3 Skid Steer (A62613)
2022 CAT 289D3...
