Ballast box
/ Ballast box #1
avillahdw
Avilla, AR
2013 LS U5030
Morning Everyone,
I would like to build a ballast box for the 3pt on my U5030 but cannot find any info in the loader or tractor manual to give me an idea of the preferred weight. I am thinking in the 1500-1700# range. Any insight would be greatly appreciated.
/ Ballast box #2
Morning Everyone,
How much can you lift? or better yet what is the weight of the BH that fits it?
/ Ballast box #3
To me that would seem like an offal lot of weight to be hanging off of the rear of the tractor as a counter balance I would think 1K and loaded tires would be fine but I guess that all depend how much you can lift. But what do I know I don't have anything but my 500# (maybe) tiller on the rear and no loaded tires, I just try and hold on with my but cheeks :shocked: as the rear gets light! But really I just haven't done anything yet so I am pretty interested in what others will have to say, because I know I have done some stupid things while moving large logs, I mean really large!~
/ Ballast box #4
I think that u5030 only lifts a couple hundred lbs more than my R4047 ... yet also weighs 500+lbs more than mine.
That said, I haven't found anything that'll raise my tires now with my HD 8ft back blade attached. I'm not exactly sure what it weighs, but I've got to guess 700-900lbs.
I would think 1000lbs would be more than enough for you.
/ Ballast box
I've searched the manuals (which are lacking in some info) to find the lift capacity. My purpose in the ballast box is to distribute the working load, especially when using the double bale mover on the FEL (approx 1509-1600#). Even with my box blade or 8' bush hog, I feel a ballast would work better and cut down in potential front end issues. I don't have a BH on this tractor at this time. Realizing that the perfect ballast ratio is going the vary with the FEL load, I would rather err to the rear end heavy side rather than too light.
/ Ballast box
Just heard from Scott Holland at RCO tractor that the lift capacity on the U5030 is 4039 lbs so a 1700 lb ballast could easily be handled.
/ Ballast box #7
No question that the 3pt will lift 1700lbs, but what he meant was what is the lift capacity of the Front End Loader. And that is 2650 lbs. What you need on the back is about 1000 to 1300 lbs depending on if you have loaded tires or not.. Remember when you are box blading you wont have your ballast box on there:) So a balanced approach to the weight is called for in my opinion. If you absolutely don't want to have the loaded tires then you should have a bit more on the 3pt. And of course the loaded tires don't do anything for decreasing the load on your front axle when you scoop up a big load of gravel, only the 3pt weight will help "unload" that front axle. If you had the rear tires loaded and 1000 to 1300 lbs on the 3pt you would have a balanced tractor that you would feel much safer on when doing loader work, and also would pull well when doing boxblading or other ground engaging work. Of course these are just my opinions...YMMV:)
James K0UA
/ Ballast box #8
Actually the U5030 uses the LL5102 loader, rated for 2900 lbs
/ Ballast box #9
My tractor requires 1100lbs Ballast for full FEL lift of 2700lbs. So yours would be quite close to mine. I also have loaded tires.
/ Ballast box #10
Ok, so maybe the 1300+ depending on whether loaded tires or not. then. Thanks.
James K0UA
/ Ballast box #11
The counterweight I made for my R4047 started out as a 1,300lb (weighed at the scrap yard) block of steel, then I added the draw bar, top link bracket, and legs/box on the bottom...it's probably 1,350lbs minimum, and makes a big difference when using the FEL. I can finally max out the FEL, and not lift the rear tires. I also notice it's more stable when I lift full buckets of gravel/dirt (doing a lot of that to backfill around the foundation around the new building. I like that it's compact....
/ Ballast box #12
Gmbart. do you have loaded tires too?
/ Ballast box
I thought perhaps he had given me the wrong numbers also but according to the specs (http://www.lstractorusa.com/upload/U series Literature.pdf ) that is the correct "hitch lift capacity", not that I will ever think about anything that heavy. Any idea what else this could refer to? In regards to the loaded tires, I prefer not to do that, primarily for hauling capacity. As it is, I can haul the tractor in my trailer but with loaded tires I would be too heavy. If I needed the ballast to go with me, I could put it in the truck with the tractor on the trailer. Thinking in the 1500 lb range still.
2019 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A64556)
2019 Peterbilt 579...
2018 AUTOCAR XPEDITOR GARBAGE TRUCK (A63276)
2018 AUTOCAR...
2025 Electric Cart (A64557)
2025 Electric Cart...
130 BBL VAC TRAILER (A63569)
130 BBL VAC...
2018 Volkswagen Passat Sedan (A64557)
2018 Volkswagen...
2018 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A65053)
2018 CATERPILLAR...
