BX25D. Mod #1 and continued.
/ BX25D. Mod #1 and continued. #1,461
Paul, always great to see more projects flowing (I know, flow isn't exactly the right word...) out of your mind and shop. I am curious how you fabbed the toothed parts? Ironworker, and lots of repetitious nibbles?
Well my friend the first thing I did is build a template of the tine I wanted. It was my intention to use the plasma to cut them but I knew that I needed each one to be consistent with the other so while I was pondering that issue an engineer friend of mine dropped into the shop and had a little discussion about it. He's always trying to do something for me so he said "Let me take that template and get them cut on a water jet for you". Reluctantly I said OK because for me it felt like I was cheating. Although CNC work has it's place, for me I feel like it's actually cheating and it takes away from the hands on that I like to have part in. Anyone can do anything IF all the parts are cut for you. All that needs to be done then is stick them together. CNC is great for production work and should be used in that case but this wasn't production work. Well that's my :2cents:
Anyway a week later my buddy dropped them off and they were done to perfection. I'm happy to have them cut but kinda feel guilty about getting them done via CNC. Everything else I hand did.
/ BX25D. Mod #1 and continued. #1,463
Well I'll keep this short and post a video on it one of those days but here's how my latest grapple project turned out. I Didn't need a dedicated grapple so I designed this. The tines are 1/2 thick, the duel independent hydraulic cylinders are 3" with plenty of force. I wanted to keep the top spill guard in place so that meant the tines had to be a little longer than normal. I have it all set up that if the grapple gets in my way its a ten minute removal with the linch pins. I've got some rock I need to clean up next summer so this should make it easier. I also fabricated a tooth bar that should make digging easier.
Nice work 4Shorts!!! How does it work?
/ BX25D. Mod #1 and continued. #1,464
that grappler looks to heavy for that kabota. You need somehting like a mahindra that lifts more on the loader. The design of the thumbs does not look like it will work very good. Did you use the long grappler bucket as a template.WR Long Bucket Grapple
/ BX25D. Mod #1 and continued. #1,465
So you are proposing the OP get a new tractor with grapple... You nuts??? Hope I am reading you wrong.
Thanks Papa, before I painted it I filled the bucket with dirt no problem. I grabbed a pile of brush no problem so I think it's going to be very helpful next spring for what I need to do. It got a nice smooth movement on the hydraulics, not to fast. Not jumpy so I'm very happy with it. It's exceeded my expectations. Like I mentioned back always. 8 linch pins and its all off and other that the brackets it's back to my regular bucket. It was a fun project.
You can see the template I used if you look back at the photos. I made it out of 1/4 panel board. It wouldn't be possible to use anyone's template or design in this situation because of the spill guard on the bucket and the added height.
Na. I'm keeping the Kubota. With 146 hours on it I think it will do me for another little while ;) It will be perfect for what I want to do and I always have the option to build more other types of Implements if needed and that's the beauty of building things yourself. ;)
I think he got mad because nobody commented on the stickers his old lady made.
I am surprised this time that you didn't make some kind of comment on my wife's stickers. You must be mellowing out :laughing:
/ BX25D. Mod #1 and continued. #1,467
I figure the design and execution of the work is so stunning that people miss the "little things" like the decals that by themselves could be a whole thread on perfection. I have always looked --very closely--at the decals and every one I have seen in all his photos has been flawless and perfectly positioned. Just my two cents but it's things like this that make a good project like this truly timeless.
/ BX25D. Mod #1 and continued. #1,468
"I am surprised this time that you didn't make some kind of comment on my wife's stickers."
Well, to the first time viewer, who didn't know the Specialty Repairs story, they would just look like they came from the factory that way. Except Paul's work is often better than factory grade.
/ BX25D. Mod #1 and continued. #1,469
/ BX25D. Mod #1 and continued. #1,471
Great work on the grapple, 4shorts! And, as always, Mrs. 4shorts exceeds perfection too! I love the "Tooth fairy" emblem!
Thanks Farmgirl. We appreciate that. The denturest just called and he was laughing so much. He asked how we did it and when we told him wifey does them he said "I got more work for you" So the joke turned into a paying job. Now that's cool :dance1:
/ BX25D. Mod #1 and continued. #1,473
4shorts---you haven't "worked" a day in that shop. You're having so much fun it should be illegal. :D
Well my friend your pretty close to the reality of it. I'd say its 75% fun and 25% work. I've had so many opertunties to go elsewhere for work but this place keeps calling me back but there were times it was close.
I know you love to restore things like I do so I found this photo of an old MF tractor I bought almost 30 years ago and fixed it up. It had a Perkins diesel and it was a brute. Had to split it because of oil leaks and I remember it had a crank problem but I eventually completed it.
I never had much to work with in tools or equipment back then but somehow I got it done.
Here's the photo of the day I literally dragged it home :shocked:
/ BX25D. Mod #1 and continued. #1,475
4shorts--Great before photo. Somewhere I have seen an after photo of that. It might have been your website or perhaps a prior post of yours but I think I've seen the after photo.
You just might have. It was a sore looking thing. It was buried in a old barn for 20 years and wasn't running when I got it. I'd NEVER tackle anything like that now.
Here's another view. My two dons were so young then but then again so was I :eek:
/ BX25D. Mod #1 and continued. #1,477
Wow what a talent, you never cease to amaze!
Thanks Jeff. I appreciate that :)
For anyone interested I'll attach a few more photos of the old Massy project. Keep in mind that this project was 25 years ago. The two little boys in the photos are my sons who are now in the military. The only welding unit I had back then was an AC Lincoln tombstone unit. Man that thing burnt lot of rods. I built the bucket with it as seen in the photos.
Today we got the BX out and put the forks on it to move all our summer outdoor stuff to storage for the winter. Now it's time to put up the Christmas lights. We used to put up thousands of lights a few years ago but our boy went over to Afghanistan and we never had the heart to put them up but this year we will put them up again seeing his home safe and sound. The lights will take us two weeks to run but the locals love them.
Wifey even bought me a new vacuum for Christmas today. I can't use it until Christmas but I did plug it in to check it out. Very powerful. :thumbsup:
/ BX25D. Mod #1 and continued. #1,479
4shorts--what great photos and what a youthful guy you were. The ladies must have been all over you back then, especially when you offered them a ride in your wheel loader. What a charmer.
Any more photos of the completed tractor?
