I use the HF QH and I love it after 40 years of doing it the old fashion way it sure is a welcome change. All, no most of my equipment is older and it needs modified I just do one at a time and as winter comes I will continue, I have to have some reason to be out in the garage. The only problem with the HF hitch is the center top hook isn't long enough and I have to extend it on mine, but for now as long as the top hookup on the implement is wide enough I just need to be lined up right which is good because that makes the two lower links line up perfect. All and all I think the quick hitch is the better route, that is as long as you have QH compatible implements, or can modify what you have, and if you have a hydraulic top link. Without the hydraulic top link and the ease of adjustment to extend or retract the center link to be parallel with the lower links (to match the specific implement) pats would probably be better. I had my QH for a year before I started using it because I didn't have the top link, and being old it just didn't make any sense that anything could ever be that easy.........well I was wrong! :confused3: I find myself going out and moving the equipment without any reason just because it is easy, yea I know that is pretty sad!
