MF 1440 rear remotes
/ MF 1440 rear remotes #1
frankd1
Lucknow, Ontario
MF1440-4 ,MF/GC2610TLB
Hello all, my first post here. I have tried to read as much as I could but have not found my answer.
I would like to put 2 sets of remotes on my MF 1440-4 with loader. It has a fender mounted joystick for the loader fed from the chassis with a 3 hard line assembly.(part# 4266-358-m91) My first question is can anyone tell me the designation of each of the lines as per a schematic?
My next question is, if I order a MF remote kit (part#3708-450-m93). Will that eliminate the hard pipe assembly(4266-358-m91)? Does the remote kit come with everything J need to tie my loader valve back into the hydraulic system.
Thanks
Frank :)
/ MF 1440 rear remotes #2
The MF remote valve kit will not utilize the loader plumbing. It fastens to the transmission and takes hydraulic pressure from there.
You could make your own kit with the power beyond line for the loader, you would need a valve to control it.
Thanks MFRED for your reply. My loader valve takes hydraulic pressure from the transmission now using the hard pipe assembly. Where would the power beyond line be and return line as there are no other ports on the loader valve?
/ MF 1440 rear remotes #4
Can you get a picture of it? It would be easier to identify as there were a few different versions
Here are a few pics of the loader valve and the 3 hard lines coming off of it. Also a pic of where the hard line assembly bolts to the transmission housing.
Thanks
Frank
/ MF 1440 rear remotes #6
Sorry to be a pain but can you get a little better lit picture of the first one
I will pull the rear wheel and get a better pic this week.
Thanks
Here are some more pics, Hope this helps.
/ MF 1440 rear remotes #10
Yes. Those will work. I'll do some thinking. The block usually goes where you're flange bolts on the transmission. I just need to remember how it goes there with the steel lines like you have.
Any Ideas?
/ MF 1440 rear remotes #12
I know how they're supposed to go on there. Just under that manifold block that feeds your loader. I know how I would do it, tap into that power beyond line with some compression fittings & feed an aftermarket valve. I just don't know how the factory kit would tie in to what you've got or if you can still get a factory kit anyway.
Sorry I'm not much help.
My dealer got a kit in for me to look at. It will not work on mine with the factory mounted loader valve, there is not enough room between my loader valve and my transmission to mount the kit valves, and also they do not provide any way of connecting the remote valves to the loader valves.
Now back to your idea of using the Power Beyond. What would be the best way to identify the Power Beyond line?
The first 2 pic are of my loader valve with the hard line assembly removed, the next 2 are where the the assembly bolts to the transmission. The lower port on the trany with the white rod pointing to it is the pressure port.( it spits oil when I crank the engine). The port directly above that would be your return.(from factory with out a loader or remotes these two ports are joined by a cover plate and the third hole to the right is blanked ) Third hole is used with my loader valve, for what, I do not know. :)
Thanks
Frank Oh yes! you are a big help!!
I made two adapter blocks to be able to put hose in the circuit instead of the hard lines. I put a pressure gauge in line to check each line pressure while moving the loader and 3 point hitch. On line #1 curl bucket to stop-around 2000psig, lifting 3 point hitch with tiller on (weight of about 550lbs) about 500psig until it reached the top and then the gauge dropped to 0. On line #2 bucket curl 0 psig and 3 point hitch lift was 500psig until it reached the top, then 0. Line #3 was 0 psig on both.
Now with all of that said, I assume that line #1 is my pressure line from my pump and that line #3 is my return to tank. Can anyone tell me if line #2 is power beyond? To install a remote valve, would it be best to feed the remote valve with line#1(pressure) and plumb the power beyond from the remote to the pressure in on the loader valve and drain remote to tank? Open to any suggestions.
Thanks
frankd1
It has been a while, but I have got back to working on my remotes. Plumbing is now done, just have to work on linkage now! :)
