Lets talk leakdown
   / Lets talk leakdown #11
All of our attachments are sealed when we remove them with no pressure relief.
Ken
   / Lets talk leakdown #12
Hi JJ,
I heard the same thing from Terry and I have mentioned it here before. I have needle valves in line and if i lock those down, the lift arms stay.
I am not sure how other manufacturers deal with pressure relief when the circuits are closed. I suspect they just do not worry about it.
Ken
You have proved that your cyl are good
I believe you have answered your questions, and it is that your valve spools are leaking.
How much can you tolerate is what you have to answer.
You can't rebuild them, so a new valve should be in your thoughts, but only if you are worried about the lift arms falling.
Of course, if they are falling, they are leaking when you are trying to lift a load.
You can judge the leakage by looking at a hyd gage when you are lifting a large load and see if it can maintain a high pressure and not go into relief.
   / Lets talk leakdown #13
Carl,
A couple of years ago on my PT, i would catastrophically lose lift on my loader arms and would drop the load. It ended up being the steering cylinders that needed the rebuild. They got so bad that I could not steer. When I fixed them, then the catastrophic problem with the loader went away. Life is not nearly as exciting now that I no longer have to guess when my loader will fall down.
Ken
   / Lets talk leakdown #16
In general, you can say that about anything hyd.
However there is an acceptable leak down rate that they use to replace valves and cyl when new.
Prince engineers use 10 cc per min.
   / Lets talk leakdown #17
Given the size of the cylinders, 10 cc/min would be in the range.
I can tell you that it is a higher rate if there is crud under the check valve.
All the best,
Peter
Can someone give me instructions on how to clean out my control? From a standpoint of a novice? I have no clue what a check valve us.
   / Lets talk leakdown #19
If you are talking about load checks, they are usually located between the work ports.
The purpose of the load checks is to prevent the cyl dropping as you shift the lever, and also to prevent fluid from flowing back into the input.
This valve from Prince is an example what a load check might look like.
http://www.princehyd.com/Portals/0/valves/LvtInstS.pdf
   / Lets talk leakdown #20
My backhoe will leakdown sometimes within 5 to 7 sec while im trying to dig. I have checked ghe load checks and look to be good. Where do I need to loon now? I have noticed that if I put down pressure on boom and then raise it back up it will stay sometimes. Now im noticing the front bucket is trying to bypass it has more lifting power than other times I can try and lift something and say the third time itru it will lift.
2008 Ford F-350 Service Truck (A55788)
2008 Ford F-350...
JOHN DEERE 1705/6700 LOT NUMBER 20 (A53084)
JOHN DEERE...
2019 VOLVO VNR TANDEM AXLE MID ROOF TRUCK (A56129)
2019 VOLVO VNR...
Case-IH 370 Steiger (A53314)
Case-IH 370...
2015 Ford F-450 Flatbed Truck (A51692)
2015 Ford F-450...
5' Roller (A53316)
5' Roller (A53316)
