7.3 role call
/ 7.3 role call #41
What I run my business out of every day:
1997 F Super Duty.
3 inch Diamond Eye downpipe, DP Tuner 4 position chip, K&N hardware/NAPA 6637 filter intake, Riff Raff intake boot.
/ 7.3 role call #42
Does anything rust in central FLA ?
the moisture state? sure.. stuff rusts. but paint doesn't rust.
start with clean, unrusted metal.. and paint it.. and it don't rust.
/ 7.3 role call #43
here is my F450 dump 115,000 miles only thing I have done to it was shorten the frame and put a 10' dump on it. No engine mods other than straight pipe or chips and will still out work most trucks.
I just don't use it much anymore. So I listed it in the for sale section.
/ 7.3 role call #44
Heres my 03 F250 XLT.. 7.3 with automatic and its a 2wd.. Loaded with every option I think, even bucket seats with center console.. Got it used with 106K miles and now has 164K and runs like its new... Its quick, will pull anything you hook to it, but will get 20mpg on a trip (no trailer of course)... Just noticed I dont have a updated picture of it with the 05-07 style Harley lights...
/ 7.3 role call #46
Ductape, I had a 96 F250 super cab bout that same color.. It had a purple tint to it in the sunlight, does yours do that? I have seen some that dont but mine did.. That shade of blue is very sharp on the OBS trucks..
/ 7.3 role call #47
Here's my early '99. 298k and still pulls strong and rolls coal nicely :D The only mod is a Hypertech tuner. I picked up another work truck, so the SD will go into semi retirement pulling my wife's two-horse trailer.
/ 7.3 role call #49
just curious what rear you have? 3.73? that's darn good milage!
/ 7.3 role call #50
'94 F350 4x4srw 7.3 IDI 92,000 miles. Bought it new and have had it out in just about every snow pushing a Fisher plow. Original oil pan, exhaust,springs,and transmision !
/ 7.3 role call #51
How many of you guy's wish that you had bought a 97 F350 reg cab 4x4 PSD........ and just left it in a garage for the past 16 years? I think that is/was the end of the "classic" p.u. styling, and the best looking Ford ever. Imagine what that would be worth now or in another 10 years or so?
/ 7.3 role call #52
i wouldn't mind having one. ;)
/ 7.3 role call #55
Mostly because I like the looks of steel lines but also for streamlined flow and less chance of leaks. Intake air heater is a useless airflow interrupter for me and something that could cause a problem. Fuel bowl/heater I never really liked it's location and likes to leak. I will have better filtration under the truck with the spin ons. The EBPV is doing the classic rod oil leak so it's flying to the dumpster along with it's EBPV exhaust choking butterfly. My non EBPV turbo pedestal should be here soon. I'm mostly cleaning up engine bay, improve reliability, de-fording an international engine lol.
Interesting this thread happened to come up now. my son is trying to help a friend get their 1988 F250 Lariat (6.9 or 7.3 ) diesel up and running for hunting season.
it has been sitting for a few months and has a charging problem, also pulls the batteries down when parked, looks like the alternator has been changed. son says it is hard starting , but after looking it only has one battery, and i see it will need to add the second one , and will charge and load test the other. soo..
1 i will get a new battery or two, and remove the alternator and have it tested..
2 Now for the hard starting, if the engine has good cranking speed do these engines normally start easily or do they need working glow plugs even in warm weather- will check them and power transfer from glow plug controller on start cycle
We just brought it home ( on a trailer being towed by the 03 Dodge Cummins)
-making up for the Dodge being brought back home on a roll back powered by one of these 7.3s of newer vintage
when my Dodge stranded us in February- in 25 degree weather with no coats (water pump puked) so I certainly can't knock these 7.3s
Just wondering if anyone has any tips- if there are any common problem areas that relate to the hard starting and or charging and battery draining on this vintage of Ford If I don't get it up and running quickly I will start another thread
Thanks everybody
/ 7.3 role call #56
Just wondering if anyone has any tips- if there are any common problem areas that relate to the hard starting and or charging and battery draining on this vintage of Ford. If I don't get it up and running quickly I will start another thread.
Thanks everybody
Try posting on Diesel Stop. There's forums there for several Ford diesels and lots of helpful guys there. I've received lots of valuable advice there the last couple of years.
Ford Diesels - Diesel Forum - TheDieselStop.com
/ 7.3 role call #57
Thanks everybody
Check the return lines and injectors. Mine would leak causing long cranks to purge air and start. They make kits that include new lines, o rings, and copper washers.
/ 7.3 role call #58
Dan, the '88 will be a 7.3.
You need two batteries, and I always replace them as a pair.
Unless the ambient temperature is really warm, (like 80-90 degrees) these engines need a working glow plug system. You can get the plugs and controller (if needed) at the Navistar/International truck dealer. It's cheaper than the same parts from Ford.
Like Buck said, check the fuel return lines. Any visible fuel leak needs to be fixed.
/ 7.3 role call #59
For me it would be a 03 F350 SRW 7.3 4x4. To me thats the holy grail of F Series.
Chris
/ 7.3 role call #60
Thanks everybody
Seems to me I remember wiring harnesses and relays associated to injectors and glow plugs along with the glow plug timer.
Chris
2014 Freightliner 114SD T/A Dump Truck (A61573)
2014 Freightliner...
2018 Sundowner FD-306 REV A 24ft. T/A Enclosed Gooseneck Trailer (A64194)
2018 Sundowner...
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A64194)
2015 GMC 3500 HD...
2017 Bobcat T550 Compact Track Loader Skid Steer (A61572)
2017 Bobcat T550...
(2) UNUSED UNVERFERTH 8-10 WHEEL SPACERS (A64280)
(2) UNUSED...
2019 Ford Explorer AWD SUV (A61574)
2019 Ford Explorer...
