wr long or ??? for brush & logs?
/ wr long or ??? for brush & logs? #1
lwm
Los Gatos, CA
Kubota B21 TLB, 3 spool T&T, 6 foot blade, box scraper, post hole digger. Kubota M59 TLB, EA 8 foot scraper, 8 foot Gannon box scraper, WR Long OBG 1. Kubota KX161-3S Excavator, 12, 16, 24" buckets, 30" flail, hydraulic thumb. Very tole
Hi, M59 owner looking for something better than pallet forks to grab brush and logs. Brush is to move it to a chipper, logs is to move them and to hold them while cutting them up.
The M59 has about 4000 pounds of lift at the pivot so something that could use that lift would be nice.
I was leaning towards the wr long OBG-1 but would like to know what other people have found useful.
Thanks!
/ wr long or ??? for brush & logs? #4
I ordered a WR Long RBGD 84 grapple a little over three weeks ago that is on the truck to be delivered this week. RBG
Was going to order the same style you are considering but after using a friends who has a tree service, went with the RBG series.
I think the EA version is nice, but a little small for your tractor. Good luck and I'll be sure to post a new thread when it arrives.
/ wr long or ??? for brush & logs? #5
Thanks!
With that much lift capacity, you need the Monster Grapple:
Notice the high back that gives it a 51" high opening.
Mine is 6' wide. Making a burn pile.
Got it here: New Loflin Extrem Monster 72" 6' Grapple Root Rake Bucket Skid Loader Holland | eBay
/ wr long or ??? for brush & logs? #6
I saw that one, it looks smaller, opens less wide, handles less load, right?
It seems like EA was going after the smaller tractor market with that thing (and that's neat, nice they did that). But I've got a 59HP tractor, it's got a lot of lift. Isn't the wicked grapple a little light duty for that big of a tractor?
I have a EA Wicked grapple. It is more than enough grapple for my L4240. It is lightweight and made out of high grade steel. I am not sure if it would be enough for a M59, it is marketed for compact tractors. I would contact them before I purchased one and see what they say. A machine like the M59 is probably better suited to the WR Long OBG-1.
/ wr long or ??? for brush & logs? #7
The WR Long OBG1 and Wildkat Heavy Duty have openings to 47" and 46" respectively. These are above the typical 34" to 36" opening you see on home owner grapples. 4000 lbs is a lot of lift so keep that in mind on your choice to verify if the units are rated for that. My smallest loader is 3200 lbs at the pins and others run up to your 4,000 lb range so I know what you are dealing with. The EA stuff is marketed at the compact market and only opens to 34". That is small for your machine in my opinion. The Loflin mentioned is a beast, opening to 51". I had not seen that make before but if it is of reasonable weight and lift capacity, that is a good option. You are borderline Skidsteer in lift so I would stay away from the homeowner stuff. Xfaxman is kind of the large grapple expert on TBN, he won't steer you wrong. Islandtractor is the unquestioned smaller grapple expert, he may chime in as well.
/ wr long or ??? for brush & logs? #8
I originally got my WR Long RBG2-48 for picking up logs and brush/tree limbs after having some logging done at our previous home. I have also used it to build several stone walls.
I can't speak for the other brands, but I think WR Long's is a top quality product with excellent customer service. I liked their products enough to buy one of their 4in1 buckets 3 years ago when we built our house.
/ wr long or ??? for brush & logs? #9
Here are a few pics from last January.
/ wr long or ??? for brush & logs? #11
HOW did you manage to lift that log with a 7610?
How big is/was it?
It looks about 10'x20"
Through my computer screen, I can hear every bolt/loader mount on that tractor screaming for relief. :eek:
/ wr long or ??? for brush & logs? #12
OP-If you are going to handle lots of logs, don't go with the flat bottom style especially in the larger size. It takes a pretty large diameter log to actually get held between the jaws, which can be real aggravating if you are trying to hold it with the grapple and cut.
It's much easier picking a single log off a pile or placing it on a trailer with the RGB style, less likelihood the log will roll.
And if you want to grab a big brush pile to post a picture on here it has a 70" jaw opening, which beats the flat bottom style hands down.
The down side is not many people make them and they are pricy but I talked to Travis at ET and he said they are coming out with one fashioned after the Bradco for smaller tractors that should prove to be very popular. Good luck in your search!
I'm starting to lean towards that one too. Looks like it might grab brush better. Anyone tried both the RGB and the OBG and care to comment?
The comment that someone made about grabbing logs being harder with the OBG style resonates with me, seems like smaller ones would be a pain.
/ wr long or ??? for brush & logs? #14
I think the OBG would be more versatile you can dig out stump with it and it will grip a log better.
I think the RBG would be better for brush.
Sent from my Samsung SPH-L710 using TractorByNet
OBG may grip a big log better but because the tines don't mesh a smaller log will rattle around in there.
RPG is interesting, it looks like it cant roll backwards enough to act as a scoop, its more like fingers pointed straight down. The OBG might actually grab more brush if you are pushing up against a pile.
I wish there was a local dealer with a pile of brush that I could go play with :)
/ wr long or ??? for brush & logs? #16
I've owned two flat bottomed grapples, first a CA (Construction attachments) and then a MIE (Michigan Iron & Equipment) and liked them both. The MIE was really well made. Having gone without one for six months, I will say having ANY grapple is better than none!
The dealer just called and he's dropping off the grapple tonight on his way home, so there will be pictures....
Really looking forward to hearing what you think, I'll hold off until you report back. My only concern with the RBG is that you can't get under stuff. Might not be an issue but I'd love to hear from someone who has one.
/ wr long or ??? for brush & logs? #18
If the lower jaws are not very long, like the PalletForks.com rake grapple, you can't always pick up much with them. Wildkat, WR Long and others have longer lower teeth which helps grab the bottom of the load.
/ wr long or ??? for brush & logs? #19
The first noticeable difference between my last tractor/grapple combination (Kioti DK35/Michigan Iron & Equipment grapple) and this one is is I can tear up lots of ground with much less effort. I really should have waited for today when it was light but I couldn't! :laughing:
This grapple digs much better than any I have owned so far but then again the edge is basically a tooth bar with replaceable teeth and I'm using a much larger tractor. Hopefully I will be able to cut some holes in a few hedge rows. I have quite a few downed trees and will post some more photos later. It's going to be a good day....
/ wr long or ??? for brush & logs? #20
Notice how well his R4 front tires are standing up to the weight, no bulge. Anyone that asks about R1 vs R4 should look at that picture.
Grapple Mini Excavator Attachment (A61572)
Grapple Mini...
2024 DODGE RAM 2500 HEAVY DUTY PICKUP TRUCK 4x4 (A59912)
2024 DODGE RAM...
2006 GMC Savana 3500 Box Truck (A61573)
2006 GMC Savana...
UNUSED WOLVERINE RCR-12-84W-84" HYD ROCK RAKE (A64281)
UNUSED WOLVERINE...
2006 Ford E-450 (A64119)
2006 Ford E-450...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
