L series Ballast
/ L series Ballast #1
roaf3x
Has anyone bought a new L8170 ballast box.
Trying to check price in NE.
Many Thanks
RD
/ L series Ballast #2
I paid $400 new for mine last fall. Philip.
/ L series Ballast #5
Philip, Did yours come with a lid or did you make yours?
LOL... That is not a lid. I filled it with concrete, then painted the top with color matched Kubota Orange concrete paint. Philip.
/ L series Ballast #6
lol, I didn't look close enough to catch that. I like it.
I've thought about how sometimes my BB is too big as a ballast and something more compact would be handy.
/ L series Ballast #7
I use a box blade with weight added to it. But sometimes it is in the way and a pain! If a lot of loader work is being done, a compact counter weight is the way to go...
/ L series Ballast #9
I have no idea, can you tell by the pictures? It does have extra long pins. Your local Kubota guy should be able to tell you. I am not a quick hitch guy. Philip.
/ L series Ballast #10
I don't have a qh (yet) but I am try ing to keep it in mind in case I do. It looks like maybe a qh upper hook would need some sort of adapter to grab the upper pin because the pin is recessed into the box a little.
Not sure though.
/ L series Ballast #11
Buddy with NH40D has quick hitch (but no hydraulic top link), he swears by it. I have hydraulic top link, and swear by it. On the GrandL series, with telescopic end links, telescopic slide stabilizers, and hydraulic top link, I just do not see how it could be that much easier to hook up a 3 point implement. I am sure others will disagree, and that's fine. (Maybe I am confusing quick hitch with Pat's easy system? I don't know? Just know I am happy with what I have) Philip.
/ L series Ballast #12
I don't know if I'll end up going with some sort of quick hitch like the speedco or landpride, time will tell as I collect implements and see how often I swap them. And how much trouble it is. I don't mind getting off each time, but don't want to wrestle. the telescoping arms will help.
But I am trying to in general buy implements that are qh compatible or could easily be made that way in case I go that route. My understanding is by buying an extra adapter, even implements like the box which don't have room for the top hook of a qh will work.
/ L series Ballast #13
I use front tractor weights with a 2pt connection on my quickhitch. About 1400#.Ballast 003.jpg
KBH Tender (A63118)
KBH Tender (A63118)
PALLET OF APPROX (10) SCISSOR LIFT CONTROLLERS (A62131)
PALLET OF APPROX...
2012 John Deere Z425 Zero Turn (A63116)
2012 John Deere...
KUBOTA L3130 TRACTOR (A62130)
KUBOTA L3130...
1995 Ford F-250  7.3L Powerstroke Diesel (2WD, Long Bed) (A63118)
1995 Ford F-250...
2013 VOLVO A25F 6X6 OFF ROAD DUMP TRUCK (A62129)
2013 VOLVO A25F...
